04-11-2018, 10:32 | #1 (permalink) |
No Life Poster Join Date: Oct 2017
Member: 2766801 Status: Offline Thanks Meter: 182 | 5049W unlock problem [SOLVED] Using library Brom_DLL_v7.1733.4 Searching phone in normal mode; [connect the phone powered off with volume down pressed to the usb cable] Phone detected (MediaTek USB Port (COM54)) Preparing to start flash mode; Preparing to open COM54 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: ff4499f1dd89c22b9cf15cff898b3016 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem171.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM6; it doesnt pass what should i do guys, have tried installing d drivers |
04-11-2018, 13:08 | #5 (permalink) |
Member: 2766801 Status: Offline Thanks Meter: 182 | have got it to work when i tried it in window 7 32bit but i have another problem WHEN IT IS Bruteforcing.....relax ;-) it takes too much time and it Bruteforcing.....relax ;-) twice still yet it doesnt work here is my log Sent from my iPhone using Tapatalk |
04-11-2018, 13:12 | #6 (permalink) |
Member: 2766801 Status: Offline Thanks Meter: 182 | Using library Brom_DLL_v7.1733.4 Searching phone in normal mode; [connect the phone powered off with volume down pressed to the usb cable] Phone detected (MediaTek USB Port (COM15)) Preparing to start flash mode; Preparing to open COM15 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: 0888fc7ac8fa0215b9d20c36db2f1d11 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem22.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM16; DEVICE INFO: BB CHIP: MT6738 [CB00, 01, 6738, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333158 0xB2BB0742 0x097468F0 [SIZE=0x748800000] IMEI1 [OTP 0001]: 014976-00-279869-7 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5049W-2ATBUS1 USRDATA INFO: 0x120000000 SIZE: 0x6240FBE00 Searching data; Checking server support license; Bruteforcing ... relax ;-) Bruteforcing more ... relax more ;-) ERROR: BRUTEFORCE FAILED; WRONG SERIAL ENTERED MAYBE !? Time needed - 00:48:22 |
04-11-2018, 13:23 | #8 (permalink) |
Member: 2766801 Status: Offline Thanks Meter: 182 | i just tried it again and it worked Using library Brom_DLL_v7.1733.4 Searching phone in normal mode; [connect the phone powered off with volume down pressed to the usb cable] Phone detected (MediaTek USB Port (COM15)) Preparing to start flash mode; Preparing to open COM15 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: ff4499f1dd89c22b9cf15cff898b3016 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem22.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM16; DEVICE INFO: BB CHIP: MT6738 [CB00, 01, 6738, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333158 0xBE6A0742 0xB994A9D8 [SIZE=0x748800000] IMEI1 [OTP 0001]: 014976-00-314567-4 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5049W-2ATBUS1 USRDATA INFO: 0x120000000 SIZE: 0x6240FBE00 Searching data; Checking server support license; Bruteforcing ... relax ;-) Buteforce took 00:27:02 Checking data integrity; Data integrity: OK; SIM_LOCK: ENABLED Rebuilding security; Phone unlocked; Remove battery and cable; Time needed - 00:27:07 Sent from my iPhone using Tapatalk |
The Following User Says Thank You to successnbd For This Useful Post: |
04-11-2018, 13:46 | #10 (permalink) |
Member: 2766801 Status: Offline Thanks Meter: 182 | Using library Brom_DLL_v7.1733.4 Searching phone in normal mode; [connect the phone powered off with volume down pressed to the usb cable] Phone detected (MediaTek USB Port (COM15)) Preparing to start flash mode; Preparing to open COM15 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: 0888fc7ac8fa0215b9d20c36db2f1d11 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem22.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM16; DEVICE INFO: BB CHIP: MT6738 [CB00, 01, 6738, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333158 0xB2BB0742 0x097468F0 [SIZE=0x748800000] IMEI1 [OTP 0001]: 014976-00-279869-7 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5049W-2ATBUS1 USRDATA INFO: 0x120000000 SIZE: 0x6240FBE00 Searching data; Checking server support license; Bruteforcing ... relax ;-) Buteforce took 00:02:55 Checking data integrity; Data integrity: OK; Sent from my iPhone using Tapatalk |
