Alcatel 2053D no service after flash! [SOLVED] Hello! A customer ask me to put romania language on alcatel 2053D, version 2053D-2AALIB1. There was 50 phones. I tested first 2-3 phones and seems to be ok with firmware from suport. Now the phones are with "no service" message on screen. I made factory reset, write initial firmware .....nothing change, only "no service" message on screen. Any ideeas? Best regards, DanV |
Because must repair the imei after for secured devices. Br;) Sent from my iPhone using Tapatalk Pro |
All phones has original imei. I must repare imei even it is ok? |
Yes repair it. Br;) Sent from my iPhone using Tapatalk Pro |
Yes, must repair it after flash Sent from my iPhone using Tapatalk Pro |
Thx for quick answer! I will post here the results. Just on question I have :-). Phones are dual sim, on the back label are 2 imeis, normaly. But software read 4 imeis. Which one of them I must repair, the first 2, on the label or more? look here a log for example: Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: Spreadtrum Boot Block version 1.2 Starting FDL2; FDL2 sent; Chip type: 6562:0001 Starting auth; HW IMEI : 000000-00-000000-0 Memory [CS0]: 00EF:0040:0016 - SIZE : 00400000 [0000410544995A29:0000] Reading phone info; PHONE INFO: 2053D-2*ALIB1 BT ADDR: 2B:F6:71:2E:E6:E0 SW IMEI[0]: 359162-09-008493-5 SW IMEI[1]: 359162-09-008494-3 SW IMEI[2]: 358570-01-010389-3 SW IMEI[3]: 910575-60-140046-8 SIMLOCK FLAG: OFF FIXED NV BASE: 103B8000 Best regards, DanV |
First two Sent from my iPhone using Tapatalk Pro |
i have 2053x have same issue. even imei repair still no service. Connected; Starting; FDL sent; Syncing; Loader version: Spreadtrum Boot Block version 1.2 Starting FDL2; FDL2 sent; Chip type: 6562:0001 Starting auth; HW IMEI : 000000-00-000000-0 Memory [CS0]: 00C8:0060:0016 - SIZE : 00400000 [00001201529A1004:0000] Reading phone info; PHONE INFO: 2053X-2*OFUS1 BT ADDR: 2B:F6:71:2E:E6:E0 SW IMEI[0]: 359161-09-276623-4 SW IMEI[1]: 359162-09-008494-3 SW IMEI[2]: 358570-01-010389-3 SW IMEI[3]: 910575-60-140046-8 SIMLOCK FLAG: OFF FIXED NV BASE: 103B8000 Reading NV; NV saved to : NV_000000-00-000000-0_359161-09-276623-4_65620000_29_09_2020_10_02_19.spd Re-programming; NV programmed; Done; IMEI[1] repaired; Remove battery and cable; Log file saved to: LOG_29_09_2020_10_02_56.txt |
1. Write flash. 2. Write NV file from suport 3. Write imei 1 and Imei2 ..... Phone will be ok! |
but still shows no service. its 2053x . not 2035D and its 1 sim phone. |
Did you actually checked it had signal before !? What its the provider id from the back sticker ? Sent from my iPhone using Tapatalk Pro |
1 Attachment(s) Its box packed . i recevid and it was no service. than i unlocked .. still no service. i flash and imei write but still same. i attach box details. |
Ok so as i understand phone had no service from start right ?! Have you tried writing 2053X-2[X=A]OFUS1_EN_FR_BRAZILIAN_LATINESP.spd ? Br;) |
