Alcatel J320 dual SIM unlock Problem [SOLVED] hi team, I have Alcatel J320 Dual SIM from UNITEL Angola .... the phone is personalized to the operator .... Strange thing is that both the Master and slave slots are locked .... i managed to unlock the master slot using MTKReader_v1.0.0.470 however i am not able to unlock the slave .... Can you or anyone help with this .... br/manbir |
One Touch J320 J320 - 3CC6AO3 863335022467514 Can you provide code for this ???? br/manbir |
read flash using otzflasher and attach here. select 639g model Br;) |
more ideas pls .... br / manbir |
Open it and tell me what cpu inside Br;) |
following are the logs of the sucessful unlock after which the master slot was unlocked ... problem is that the MTK module only picks up the master slot to unlock and the Baseband Chip is MT6572, E01 Searching phone; Phone detected (@oem274.inf,%vcom_preloader%;PreLoader USB VCOM (Android)) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on Android Gadget VCOM Driver (COM346); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6572, E01 Sw version: MOLY.WR8.W1315.MD.WG.MP.V1.P5 Hw Version: WINGTECH72_WET_JB3_HSPA_HW Reading phone info; IMEI: 863335-02-221437-9 Reading simlock info; Locked to: 631-02 code_cat_n: 12345678 enabled: no tries: 10 code_cat_ns: 56781234 enabled: no tries: 10 code_cat_sp: 11112222 enabled: no tries: 10 code_cat_c: 33334444 enabled: no tries: 10 code_cat_sim: 55556666 enabled: no tries: 10 code_cat_ns_sp: 77778888 enabled: no tries: 10 code_cat_sim_c: 99990000 enabled: no tries: 10 Time needed - 00:00:41 |
You can use OTSmart to read this phone. The truth is still inside the c0de ... |
i have some problema solved with new version... |
Searching phone; Phone detected (PreLoader USB VCOM Port) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on Mobistel Cynus T1-CDC Serial (COM40); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6572, E01 Sw version: MOLY.WR8.W1315.MD.WG.MP.V1.P5 Hw Version: WINGTECH72_WET_JB3_HSPA_HW Reading phone info; IMEI: 863335-02-xxxxxx-8 Reading simlock info; Locked to: 631-02 code_cat_n: 12345678 enabled: yes tries: 0 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Unlocking SIM2 too. Time needed - 00:00:40 |
hi team, I have the same problem then "MANBIR" I have Alcatel J320 Dual SIM from UNITEL Angola .... the phone is personalized to the operator .... Strange thing is that both the Master and slave slots are locked .... I like to unlocked it all, i don't now how. If anyone can help me, it would be nice Regards :D |
Buy furiousgold and unlock it ! Br;) |
Hi Hack3rr2k Thanks for reply, but what is furiousgold. The software, the hardware or both and how it's work. I'm not a pro, just buy my phone in Angola " Angola Unitel" and now in Capverd "Unitel T+". The phone is blocked for Unitel. Regards |
br;) |
I think you have don't endestand my problem, paid or not it's not the problem. Her no service center can unlock it. Every site i visit no one have a code for my phone. Only here tock about it. If is possible to unlock remotely, it's will be great Regards |
