Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > FuriousGold
FuriousGold FuriouS GOLD Support Area | Powered by FuriousTeam
Old 05-31-2014, 11:18   #1 (permalink)
Member: 1280253
Thanks Meter: 142
Alcatel J320 dual SIM unlock Problem [SOLVED]
hi team,
I have Alcatel J320 Dual SIM from UNITEL Angola .... the phone is personalized to the operator .... Strange thing is that both the Master and slave slots are locked .... i managed to unlock the master slot using MTKReader_v1.0.0.470 however i am not able to unlock the slave ....
Can you or anyone help with this ....
br/manbir
Old 05-31-2014, 14:17   #2 (permalink)
Member: 1280253
Thanks Meter: 142
One Touch J320
J320 - 3CC6AO3
863335022467514
Can you provide code for this ????
br/manbir
Old 06-02-2014, 07:25   #3 (permalink)
.:hack3r2k:.'s Avatar
Member: 15022
Sonork: 100.53452
Thanks Meter: 61,568
read flash using otzflasher and attach here. select 639g model
Old 06-02-2014, 12:07   #4 (permalink)
Member: 1280253
Thanks Meter: 142
Unhappy
Hello, thank you for your response , i tried also all ways to read this model however it does not get detected at all ... all drivers are correctly installed and i have tried com port cables as well ...
more ideas pls ....
br / manbir
Old 06-02-2014, 16:51   #5 (permalink)
Member: 15022
Sonork: 100.53452
more ideas pls ....
br / manbir
Open it and tell me what cpu inside
Old 06-02-2014, 17:54   #6 (permalink)
Member: 1280253
Thanks Meter: 142
following are the logs of the sucessful unlock after which the master slot was unlocked ... problem is that the MTK module only picks up the master slot to unlock and the Baseband Chip is MT6572, E01
Searching phone;
Phone detected (@oem274.inf,%vcom_preloader%;PreLoader USB VCOM (Android))
Preparing to start meta mode;
Searching for debug port; (be sure drivers from support were installed)
Debug Port found on Android Gadget VCOM Driver (COM346);
Preparing to connect meta mode;
Meta mode entered;
Baseband Chip: MT6572, E01
Sw version: MOLY.WR8.W1315.MD.WG.MP.V1.P5
Hw Version: WINGTECH72_WET_JB3_HSPA_HW
Reading phone info;
IMEI: 863335-02-221437-9
Reading simlock info;
Locked to: 631-02
code_cat_n: 12345678 enabled: no tries: 10
code_cat_ns: 56781234 enabled: no tries: 10
code_cat_sp: 11112222 enabled: no tries: 10
code_cat_c: 33334444 enabled: no tries: 10
code_cat_sim: 55556666 enabled: no tries: 10
code_cat_ns_sp: 77778888 enabled: no tries: 10
code_cat_sim_c: 99990000 enabled: no tries: 10
Time needed - 00:00:41
Old 06-02-2014, 22:10   #7 (permalink)
Member: 15022
Sonork: 100.53452
You can use OTSmart to read this phone.
The truth is still inside the c0de ...
Old 11-06-2014, 17:37   #8 (permalink)
kikodog's Avatar
Member: 37736
Sonork: 100.108250
Thanks Meter: 222
i have some problema solved with new version...
The Following User Says Thank You to kikodog For This Useful Post:
Old 03-25-2015, 15:32   #9 (permalink)
DUSKnenixs's Avatar
Member: 5169
Thanks Meter: 684
Searching phone;
Phone detected (PreLoader USB VCOM Port)
Debug Port found on Mobistel Cynus T1-CDC Serial (COM40);
Meta mode entered;
Reading phone info;
IMEI: 863335-02-xxxxxx-8
Locked to: 631-02
code_cat_n: 12345678 enabled: yes tries: 0
code_cat_ns: 56781234 enabled: no tries: 5
code_cat_sp: 11112222 enabled: no tries: 5
code_cat_c: 33334444 enabled: no tries: 5
code_cat_sim: 55556666 enabled: no tries: 5
code_cat_ns_sp: 77778888 enabled: no tries: 5
code_cat_sim_c: 99990000 enabled: no tries: 5
Unlocking SIM2 too.
Time needed - 00:00:40
The Following User Says Thank You to DUSKnenixs For This Useful Post:
Old 04-14-2015, 17:21   #10 (permalink)
Member: 2378886
Smile
hi team,
I have the same problem then "MANBIR"
I like to unlocked it all, i don't now how. If anyone can help me, it would be nice
Regards
Old 04-15-2015, 08:02   #11 (permalink)
Member: 15022
Sonork: 100.53452
Originally Posted by gost-mindelo View Post
hi team,
Regards
Buy furiousgold and unlock it !
Old 04-15-2015, 12:40   #12 (permalink)
Member: 2378886
Hi Hack3rr2k
Thanks for reply, but what is furiousgold. The software, the hardware or both and how it's work. I'm not a pro, just buy my phone in Angola " Angola Unitel" and now in Capverd "Unitel T+". The phone is blocked for Unitel.
Regards
Old 04-15-2015, 14:25   #13 (permalink)
Member: 15022
Sonork: 100.53452
Hi Hack3rr2k
Regards
If you have no idea what is then why you post here ? Go to an service center and get it unlocked. Here it's an paid product section
br
Old 04-15-2015, 19:09   #14 (permalink)
Member: 2378886
I think you have don't endestand my problem, paid or not it's not the problem. Her no service center can unlock it. Every site i visit no one have a code for my phone. Only here tock about it. If is possible to unlock remotely, it's will be great
Regards
Page generated in 0.21866 seconds with 8 queries
