08-12-2006, 23:18 | #1 (permalink) |
Banned Join Date: Aug 2004 Location: tunisia Age: 41
Member: 77845 Status: Offline Thanks Meter: 348 | BlackBerry 7100v help unlock BBPIN: 201B7873 Detected: RIM 7100 Series Colour GPRS Handheld Platform version: 1.8.0.83 Version too old or current firmware can not be used for unlocking. Time needed - 00:00:00 |
08-14-2006, 12:07 | #6 (permalink) |
Product Manager Join Date: May 2001 Location: Los Angeles
Member: 4584 Status: Offline Sonork: 100.69564 Thanks Meter: 15,093 | Check here to read step by step how to flash blackberry phones : http://www.furious-gold.com/tutorials/bb_flash.htm BR. Steve. |
08-14-2006, 17:37 | #9 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Rock'n in the Free-World Age: 53
Member: 226496 Status: Offline Thanks Meter: 11 | go to options/ sim card / then on bb keypad type m-e-p-p-shiftkey-2 ENTERING CODE: Now select Options menu on BB. Now you select SIM CARD menu. To be able to see this you have to type this on the keypad on phone : Type 'MEPD' for all models except 7100 in which case in case use 'MEPPD'. Usually u should see "active" NET lock. Now in order to disable this lock type 'MEP2' respectively 'MEPP2' if phone is 7100 and will appear a dialog asking for code. NOTE: You must use the "alt" or "shift" key to enable numbers so example would be: m-e-p-"shift-key"-2 Now you should see the place to enter your net unlock code.(if not, you didn't type in mep2 or mepp2 properly.) Here you must enter the "NET Unlock Code" that the bb unlocker showed you and hit return. |
08-14-2006, 20:32 | #10 (permalink) |
No Life Poster Join Date: Oct 2005 Location: BISKRA Age: 55
Member: 192230 Status: Offline Thanks Meter: 106 | hi ...................... please solve this probleme server down BBPIN: 201E8C36 Detected: RIM 7100 Series Colour GPRS Handheld Platform version: 1.8.0.91 Version too old or current firmware can not be used for unlocking. Time needed - 00:00:00 br louai2005 |
08-15-2006, 14:20 | #12 (permalink) | |
Member: 77845 Status: Offline Thanks Meter: 348 | You need to flash your blackberry Quote:
links for flash http://www.gsm-hacking.eu/files/BB-SERVER.EU/FLASHES/7100/7100M_PBr4[1].0.2_rel49_PL1.8.0.138_A4.0.2.35-Vodafone.exe gooooooooooooooood *****Furious Gold***** | |
Blackberry 7100V OR 7100t unlock HELP | abote didier | BlackBerry (RIM) | 0 | 03-03-2009 09:03 |
help for unlock blackberry 7100v with unlock code | samirtelecom | BlackBerry (RIM) | 2 | 12-13-2008 01:54 |
help to unlock Blackberry 7100v ? | GSM SNIPER | Easy-Unlocker | 3 | 04-23-2008 21:36 |
help unlock blackberry 7100v | hans salim | BlackBerry (RIM) | 1 | 02-20-2008 05:19 |
help to unlock blackberry 7100v | wejwej | BlackBerry (RIM) | 1 | 02-15-2008 17:20 |
