09-30-2020, 23:01 | #1 (permalink) |
No Life Poster Join Date: Dec 2008 Location: just around
Member: 914220 Status: Offline Thanks Meter: 206 | blade a3 lite error For an successful connection do the following: 1. Power on the phone and power it off and leave the battery inside 2. Keep pressed firmly volume DOWN key 3. Insert the usb cable inside the phone while keeping pressed volume DOWN Phone detected (@oem360.inf,%usbcomm_dl%;SPRD U2S Diag) (Driver version: 2.0.0.131) Preparing to sync; Port opened [COM376]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; ERROR: Sync failed; |
10-01-2020, 07:12 | #2 (permalink) |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,570 | Wrong model selected. If is australian model must select Z3051T. If still error connect phone in diag mode using one of the generic methods and paste log and i will tell you what exactly to select Br |
