05-22-2020, 07:58 | #16 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,570 | Quote:
Update Verlist to server on file load NOT checked Bypass version check NOT checked These options must be CHECKED | |
The Following User Says Thank You to .:hack3r2k:. For This Useful Post: |
05-22-2020, 11:49 | #17 (permalink) |
No Life Poster Join Date: Feb 2009 Location: CMB/Ceylon
Member: 962029 Status: Offline Sonork: OEM Lock : ON Thanks Meter: 4,129 | Fly Captain Huawei Resurrector 0.0.0.51 user:5BD41A6D Standard update Not Reboot NOT cheked Update Verlist to server on file load checked Try Rescue Recovery checked Bypass version check checked Old slow algo checked Force OTA NOT checked Looking for a device in upgrade mode COM702: Android Adapter PCUI (COM702) COM700: DBAdapter Reserved Interface (COM700) 5/22/2020 4:17:53 PM Starting to write device in UPGRADE mode... Device found: 0123456789ABCDEF 5/22/2020 4:17:56 PM start to write update file File to update: C:\Users\mr.3\Desktop\Temp\Berlin-L21HNC185B392_Firmware_7.0.0_r1_EMUI5.0.4_05014CMP (Support.**************)\Software\SDupdate_Package \dload\UPDATE.APP File size: 3,732,942,864 bytes Current version(CURVER): BLN_Global_5.0_oversea_meafnaf Process identifier:5122069 Validating file... Detecting port... Preparing to write... Bypass version checked Checking partition ... Writing file 1 of 24: SHA256RSA...OK Writing file 2 of 24: CRC...OK Writing file 3 of 24: CURVER...OK Writing file 4 of 24: VERLIST...OK Error downloading file 5 of 24 This file not suitable for flashing Error writing software 5/22/2020 4:18:24 PM Writing device finished with ERROR same error |
05-22-2020, 11:54 | #18 (permalink) |
Member: 962029 Status: Offline Sonork: OEM Lock : ON Thanks Meter: 4,129 | File size: 1,161,891,468 bytes Current version(CURVER): BLN_Global_5.0_oversea_meafnaf Package Type: OFFLINE_UPDATE Checking partition: VERLIST File size: 1,161,891,468 bytes Current version(CURVER): BLN_Global_5.0_oversea_meafnaf Updating server with VERLIST from file: update_BLN-L21_hw_meafnaf.app Updating server with VERLIST result: OK Fly Captain Huawei Resurrector 0.0.0.51 user:5BD41A6D Standard update Not Reboot NOT cheked Update Verlist to server on file load checked Try Rescue Recovery NOT checked Bypass version check checked Old slow algo NOT checked Force OTA NOT checked Looking for a device in upgrade mode COM702: Android Adapter PCUI (COM702) COM700: DBAdapter Reserved Interface (COM700) 5/22/2020 4:20:44 PM Starting to write device in UPGRADE mode... Device found: 0123456789ABCDEF Old slow algo NOT selected 5/22/2020 4:20:46 PM start to write update file File to update: C:\Users\mr.3\Desktop\Temp\Berlin-L21HNC185B392_Firmware_7.0.0_r1_EMUI5.0.4_05014CMP (Support.**************)\Software\SDupdate_Package \dload\UPDATE.APP File size: 3,732,942,864 bytes Current version(CURVER): BLN_Global_5.0_oversea_meafnaf Process identifier:5122082 BLN-Al10 honor phone |
05-22-2020, 13:11 | #19 (permalink) |
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,570 | Try fastboot+rescue selected. Also you must flash both files (firmware + customization). Not just firmware as you selected Br |
05-23-2020, 07:41 | #21 (permalink) |
No Life Poster Join Date: Nov 2017 Location: Russian
Member: 2778414 Status: Offline Thanks Meter: 342 | The mistake you have is that you went the other way. When you asked for the first time, I gave a link to the c432 vendor firmware and gave advice to flash it for you, so do as I wrote and advised |
05-25-2020, 17:21 | #22 (permalink) |
Member: 962029 Status: Offline Sonork: OEM Lock : ON Thanks Meter: 4,129 | But I downloaded the c185 meafnaf , I didn’t flash c432 And I selected vendor as meafnaf but still unable to flash the file I’ll download c432 and post result C432 vendor is eu right ? |
05-29-2020, 07:06 | #26 (permalink) |
Member: 962029 Status: Offline Sonork: OEM Lock : ON Thanks Meter: 4,129 | File size: 3,733,932,636 bytes Current version(CURVER): BLN_Global_5.0_oversea_channel Package Type: OFFLINE_UPDATE Revision: 0 Checking partition: VERLIST File size: 3,733,932,636 bytes Current version(CURVER): BLN_Global_5.0_oversea_channel Updating server with VERLIST from file: UPDATE.APP Updating server with VERLIST result: OK File size: 1,194,787,792 bytes Current version(CURVER): BLN_Global_5.0_oversea_channel Package Type: OFFLINE_UPDATE Checking partition: VERLIST File size: 1,194,787,792 bytes Current version(CURVER): BLN_Global_5.0_oversea_channel Updating server with VERLIST from file: update_BLN-L21_hw_eu.app Updating server with VERLIST result: OK Fly Captain Huawei Resurrector 0.0.0.51 user:5BD41A6D Standard update Not Reboot NOT cheked Update Verlist to server on file load checked Try Rescue Recovery checked Bypass version check checked Old slow algo checked Force OTA NOT checked Looking for a device in upgrade mode No devices detected in upgrade mode Device found: 0123456789ABCDEF Detecting recovery partition File size: 3,733,932,636 bytes Current version(CURVER): BLN_Global_5.0_oversea_channel RECOVERY partition found 5/26/2020 1:06:47 PM Starting to try Rescue Recovery... Looking for a device in fastboot mode Device found: 0123456789ABCDEF Getting IMEI... Getting build number... Getting model ... Getting battery state... Getting backdoor info... Getting lock state info... Getting lock boot info... IMEI:863604037058786 IMEI1:863604038542465 Build number: :BLN-AL10C00B172 Model: BLN-L21 Vendor/Country: hw/eu Battery state: 3798mv OEM lock state info: FB LockState: UNLOCKED USER LockState: LOCKED OEM get bootinfo: unlocked Process identifier:5125981 Erasing ver .. . Getting lock state info... Erasing ver .. . File size: 3,733,932,636 bytes Current version(CURVER): BLN_Global_5.0_oversea_channel Writing rescue_recovery partition RESCUE_RECOVERY partition update ...OK Uptade recovery parttion OK USB Device REMOVAL Type: @oem48.inf,%hwfastboot%;Android Sooner Single ADB Interface VidPid: VID_18D1&PID_D00D Instance id: 0123456789ABCDEF Looking for device in upgrade mode... USB Device INSERTION Type: @oem45.inf,%busfilter.devicedesc%;USB Composite Device VidPid: VID_12D1&PID_107E Instance id: 0123456789ABCDEF Looking for device in upgrade mode... COM702: Android Adapter PCUI (COM702) COM700: DBAdapter Reserved Interface (COM700) Enter recovery mode OK 5/26/2020 1:09:07 PM Starting to write device in UPGRADE mode... Device found: 0123456789ABCDEF 5/26/2020 1:09:09 PM start to write update file File to update: C:\Users\mr.3\Desktop\Temp\Berlin_L21HNC432B380_Fi rmware_7.0.0_r1_EMUI5.0.3_05014CSA\Software\SDupda te_Package\dload\UPDATE.APP File size: 3,733,932,636 bytes Current version(CURVER): BLN_Global_5.0_oversea_channel Process identifier:5125992 Validating file... Detecting port... Preparing to write... Bypass version checked Checking partition ... Writing file 1 of 24: SHA256RSA... Writing file 1 of 24: SHA256RSA...OK Writing file 2 of 24: CRC... Writing file 2 of 24: CRC...OK Writing file 3 of 24: CURVER... Writing file 3 of 24: CURVER...OK Writing file 4 of 24: VERLIST... Writing file 4 of 24: VERLIST...OK Error downloading file 5 of 24 This file not suitable for flashing Error writing software 5/26/2020 1:09:35 PM Writing device finished with ERROR USB Device REMOVAL Type: @oem45.inf,%busfilter.devicedesc%;USB Composite Device VidPid: VID_12D1&PID_107E Instance id: 0123456789ABCDEF |
05-29-2020, 14:06 | #27 (permalink) | |
Hi, Pls try https://mega.nz/file/8a4VWBwJ#gWXCpT...re1ZKfVgpEEPSk . I hope to work ok now ! Br | |
05-30-2020, 06:10 | #28 (permalink) |
Member: 962029 Status: Offline Sonork: OEM Lock : ON Thanks Meter: 4,129 | same error Standard update Not Reboot NOT cheked Update Verlist to server on file load checked Try Rescue Recovery checked Bypass version check checked Old slow algo NOT checked Force OTA NOT checked Looking for a device in upgrade mode No devices detected in upgrade mode Device found: 0123456789ABCDEF Detecting recovery partition File size: 3,733,932,636 bytes Current version(CURVER): BLN_Global_5.0_oversea_channel RECOVERY partition found 5/30/2020 10:31:50 AM Starting to try Rescue Recovery... Looking for a device in fastboot mode Device found: 0123456789ABCDEF Getting IMEI... Getting build number... Getting model ... Getting battery state... Getting backdoor info... Getting lock state info... Getting lock boot info... IMEI:863604037058786 IMEI1:863604038542465 Build number: :HL2BLNTMBD001031 Model: HUAWEI Vendor/Country: hw/eu Battery state: 3226mv OEM lock state info: FB LockState: UNLOCKED USER LockState: LOCKED OEM get bootinfo: unlocked Process identifier:5133582 Erasing ver .. . Getting lock state info... Erasing ver .. . File size: 3,733,932,636 bytes Current version(CURVER): BLN_Global_5.0_oversea_channel Writing rescue_recovery partition RESCUE_RECOVERY partition update ...OK Uptade recovery parttion OK USB Device REMOVAL Type: @oem48.inf,%hwfastboot%;Android Sooner Single ADB Interface VidPid: VID_18D1&PID_D00D Instance id: 0123456789ABCDEF USB Device INSERTION Type: @oem48.inf,%hwfastboot%;Android Sooner Single ADB Interface VidPid: VID_18D1&PID_D00D Instance id: 0123456789ABCDEF USB Device REMOVAL Type: @oem48.inf,%hwfastboot%;Android Sooner Single ADB Interface VidPid: VID_18D1&PID_D00D Instance id: 0123456789ABCDEF USB Device INSERTION Type: @oem45.inf,%busfilter.devicedesc%;USB Composite Device VidPid: VID_12D1&PID_107E Instance id: 0123456789ABCDEF Looking for device in upgrade mode... COM702: Android Adapter PCUI (COM702) COM700: DBAdapter Reserved Interface (COM700) Enter recovery mode OK 5/30/2020 10:37:16 AM Starting to write device in UPGRADE mode... Device found: 0123456789ABCDEF Old slow algo NOT selected 5/30/2020 10:37:18 AM start to write update file File to update: C:\Users\mr.3\Desktop\Temp\Berlin_L21HNC432B380_Fi rmware_7.0.0_r1_EMUI5.0.3_05014CSA\Software\SDupda te_Package\dload\UPDATE.APP File size: 3,733,932,636 bytes Current version(CURVER): BLN_Global_5.0_oversea_channel Process identifier:5133585 Validating file... Detecting port... Preparing to write... Bypass version checked Checking partition ... Writing file 1 of 24: SHA256RSA...OK Writing file 2 of 24: CRC...OK Writing file 3 of 24: CURVER...OK Writing file 4 of 24: VERLIST...OK Procesing .. .. Error downloading file 5 of 24 This file not suitable for flashing Error writing software 5/30/2020 10:37:53 AM Writing device finished with ERROR |
05-30-2020, 06:28 | #29 (permalink) |
Member: 2778414 Status: Offline Thanks Meter: 342 | I see log Build number: :HL2BLNTMBD001031 Model: HUAWEI The error with virelist is due to the fact that he cannot understand which model. Have you tried flashing a service firmware via a memory card? dload method. You’ve been fighting him for a week now. |
