10-01-2014, 14:01 | #1 (permalink) |
Freak Poster Join Date: Jul 2003 Location: Martinique
Member: 34356 Status: Offline Thanks Meter: 9 | problem for unlock alcatel ot-4015x (SOLVED) can you give me a solution for this model : alcatel ot-4015x provider id : 4015x-2argfa1 i try with OTsmart, chose pop c1 or ot-4015 but when i connect my phone i have this message : Using library Brom_DLL_v7.1413.5 Searching phone; Phone detected (PreLoader USB VCOM Port) Preparing to start flash mode; Preparing to open COM62 ERROR: Comport open failed ! ERROR: BOOT_PHONE; any solution ?? thank |
10-01-2014, 14:51 | #2 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,568 | Quote:
because the drivers are not installed properly. watch the video If you cant manage im online on skype Last edited by .:hack3r2k:.; 10-01-2014 at 15:54. | |
The Following User Says Thank You to .:hack3r2k:. For This Useful Post: |
04-04-2017, 08:31 | #4 (permalink) |
No Life Poster Join Date: Nov 2006 Location: pakistan Age: 39
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (Lenovo DA USB VCOM (Android)) TRYING TO OPEN COM5; DEVICE INFO: BB CHIP: MT6572_S00 [CA01, 00, 6572, FF] HW_STORAGE_EMMC: 0x504E01FE 0x34394A31 0xCE871248 0x0BB18C61 [SIZE=0xE9B00000] IMEI1 [OTP 0001]: 866651-02-336728-0 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 4015X-2AE5GB1 USRDATA INFO: 0x5D680000 SIZE: 0x8C480000 Searching data; Locked to [SIM1]: 234-30 code_cat_n: 6675867325 enabled: yes tries: 3 code_cat_ns: 4246455758 enabled: no tries: 10 code_cat_sp: 7182001960 enabled: no tries: 10 code_cat_c: 4953142314 enabled: no tries: 10 code_cat_sim: 0788937707 enabled: no tries: 10 code_cat_ns_sp: 53297761 enabled: no tries: 5 code_cat_sim_c: 86817778 enabled: no tries: 5 Phone unlocked; Remove battery and cable; Time needed - 00:00:15 |
The Following User Says Thank You to iftikhar_246 For This Useful Post: |
