12-22-2017, 19:19 | #3 (permalink) |
Freak Poster Join Date: Nov 2012
Member: 1835486 Status: Offline Thanks Meter: 28 | Using library Brom_DLL_v7.1712.1 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM8)) Preparing to start flash mode; Preparing to open COM8 Connecting; Downloading DA; Initializing; ERROR: Connection failed ! ERROR: BOOT_PHONE; |
12-22-2017, 19:35 | #6 (permalink) |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,569 | Must connect with vol up or down pressed ! A new fixed version added to the support area. Please delete the old version and download it again from the support: [x] FIXED HUAWEI CRO-Lxx SERIES BOOT BUG [x] FIXED 5049W / 5049Z / Z820 BRUTEFORCING PROCESS FOR SERIALS STARTING WITH 'S' Br |
12-22-2017, 19:35 | #7 (permalink) |
Insane Poster Join Date: Jan 2010
Member: 1198084 Status: Offline Thanks Meter: 42 | Rollback to stock Huawei Y3 2017 CRO-L03 firmware Download the official full firmware Download the huaweiupdateextract tool Download the huawei multi tool Install both tools Extract the downloaded firmware until you see the UPDATE.APP file Open the huawei extract tool and load UPDATE.APP Extract the following Files from the UPDATE.APP files: BOOT.img, CUST.img, RECOVERY.img,SYSTEM.img, USERDATA.img Copy or simply move those images into the HUAWEI Multi-Tool by Team MT/Unbrick directory Start phone into fastboot mode Start the Huawei Multi-Tool and enter “6” for Unbrick menu and Press Enter Type “N” for continue and press Enter Type “2” to Continue. The files are in /Unbrick and press Enter Just follow the instructions and your phone will be flashed with a stock firmware! After complete flashing stock firmware you can download the official update under Settings -> Updater! Current EMUI version list: EMUI 1.0 based on Android 4.0 Ice Cream Sandwich and 4.1.1 , 4.1.2 4.2.1 , 4.2.2 , 4.3 Jellybean (initial release) EMUI 2.0 based on Android 4.0 Ice Cream Sandwich, Androiod 4.1.1 , 4.1.2 4.2.1 , 4.2.2 , 4.3 Jellybean, Android 4.4.2 , 4.4.4 Kitkat (minor UI tweak) EMUI 3.0 based on Android 4.4.2 , 4.4.4 Kitkat and Android 5.0.1 , 5.0.2 Lollipop (minor UI tweak) EMUI 3.1based on Android 5.1.1 Lollipop EMUI 4.0 based on Android 6.0.1 Marshmallow EMUI 4.1 based on Android 6.1.1 Marshmallow EMUI 5.0 based on Android 7.0 Nougat EMUI 5.1 based on Android 7.1 Nougat Hope this will help you. flash with multi tool or furiousgold tool Last edited by mughal.zahoor; 12-22-2017 at 19:41. |
The Following User Says Thank You to mughal.zahoor For This Useful Post: |
12-22-2017, 19:52 | #8 (permalink) | |
Member: 1835486 Status: Offline Thanks Meter: 28 | Quote:
Using library Brom_DLL_v7.1712.1 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM8)) Preparing to start flash mode; Preparing to open COM8 Connecting; Downloading DA; Initializing; ERROR: Connection failed ! ERROR: BOOT_PHONE; | |
