11-23-2020, 10:30 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Africa.uganda
Member: 562975 Status: Offline Sonork: better tomorow Thanks Meter: 249 | D-light M100. Phone detected (@oem77.inf,%vcom_preloader%;MediaTek PreLoader USB VCOM (Android)) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on MediaTek USB VCOM (Android) (COM8); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6580B, E00 Sw version: MOLY.WR8.W1449.MD.WG.MP.V199 Hw Version: GINREEN_O1MP2_K80_BSP_HSPA_HW Reading phone info; IMEI: 861681-04-------- Reading simlock info; Locked to: C1C-1C code_cat_n: 12345678 enabled: no tries: 5 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Unlocking SIM2 too. Time needed - 00:01:02 Log file saved to: LOG_23_11_2020_01_25_16.txt DA file needed. plus full unlock if possible |
The Following User Says Thank You to ibrajinja For This Useful Post: |
11-23-2020, 17:53 | #3 (permalink) |
Member: 562975 Status: Offline Sonork: better tomorow Thanks Meter: 249 | After that procedure i did first. it has FRP, but i have tried with OTsmart to remove frp.this is what i got. Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off with volume down and up pressed to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM6)) (Driver version: 3.0.1504.0) Preparing to start flash mode; Preparing to open COM6 Connecting; Downloading DA; Initializing; ERROR: Connection failed ! ERROR: BOOT_PHONE; |
11-24-2020, 07:05 | #5 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,571 | Quote:
Must connect with vol up and down pressed ! You didnt do that !!! Sent from my iPhone using Tapatalk Pro | |
11-29-2020, 09:40 | #6 (permalink) | |
Freak Poster Join Date: Jul 2014 Location: Tanzania
Member: 2231042 Status: Offline Thanks Meter: 65 | Quote:
