08-11-2019, 13:48 | #15241 (permalink) |
Freak Poster Join Date: Dec 2013 Location: Saudi Arbia
Member: 2080403 Status: Offline Sonork: 100.1645596 Thanks Meter: 52 | Huawei Y7 Prime FRP unlock don Dongle S/N: 7CF259A5 Before detection connect cable to usb and enable Manufacture mode ! Qualcomm and HiSilicon: *#*#2846579#*#* MTK: *#*#14789632#*#* Windows: ##2846579# ProjectMenu 1.Background setting 2.USB ports setting Select Manufacture mode (for MTK other/debug mode) 2019-08-11 17:28:27.975 Erase FRP start 2019-08-11 17:28:35.380 Reading phone info... 2019-08-11 17:28:35.899 Read phone info success! Model: LDN-L21 IMEI: 862288041697978 Firmware ver.: LDN-L21 8.0.0.159(C185 SN: 26EBB18C21157255 2019-08-11 17:28:35.930 Reading Certify data... 2019-08-11 17:28:36.115 Reading Certify data success! 2019-08-11 17:28:36.115 Signing Certify data... 2019-08-11 17:28:45.352 Erase FRP done! |
08-15-2019, 21:25 | #15242 (permalink) |
Freak Poster Join Date: Dec 2007
Member: 642071 Status: Offline Thanks Meter: 54 | zte z981 frp done MODEL : QCOM SERIES 50 COMPILED DATE : Jun 22 2016 10:45:00 RELEASE DATE : Jun 5 2016 23:00:00 FIRMWARE INFO : MPSS.TA.1.0.c3-00069-8952_GEN_PACK-1.55637.1.58990.1 IMEI : 86092************ BLUETOOTH ADDR : 00 00 00 00 00 00 FIRMWARE: MPCS_P895T20V1.0.0B13 close_event_report: OK; close_log_report: OK; close_message_report: OK; closing_com_port: OK; Starting the backup process; connect_server: OK; backup in progress: OK; Backup saved to: C:\Users\Dwight\Documents\PHONE\Furious Gold\Furious Gold Latest Software\QCOM_SMART_TOOL_v1.0.0.10659\860926039970 03_15_08_2019_15_20_29.bkp switching_download_mode: OK; closing_com_port: OK; Preparing to open COM76 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22F8 start_frp_reset: OK; frp_reset: OK; |
08-19-2019, 12:11 | #15243 (permalink) |
No Life Poster Join Date: Jun 2006 Location: ..::SL3 Unlock Source::.. Age: 38
Member: 293662 Status: Offline Sonork: 100.1622609 Thanks Meter: 317 | alcatel 1066G Unlock done Searching phone; For an successful connection do the following: 1. Power on the phone and power it off and leave the battery inside 2. Keep pressed firmly the boot key 3. Insert the usb cable inside the phone while keeping pressed the boot key Phone detected (@oem39.inf,%usbcomm_dl%;SPRD U2S Diag) Preparing to sync; Port opened [COM399]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: Spreadtrum Boot Block version 1.2 Starting FDL2; FDL2 sent; Chip type: 6562 FdlStat: 0001 Starting auth; HW IMEI : 000000-00-000000-0 Memory [CS0]: 00EF:0040:0016 - SIZE : 00400000 [00000048309BDB23:69FD] Reading phone info; PHONE INFO: 1066G-2AE8GB1 BT ADDR: 59:E6:80A:45:40 SW IMEI[0]: 015051-00-217016-1 SW IMEI[1]: 352751-01-952326-7 SW IMEI[2]: 358570-01-010389-3 SW IMEI[3]: 910575-60-140046-8 SIMLOCK FLAG: ON FIXED NV BASE: 103B8000 Reading NV; Reading security; NV saved to : NV_000000-00-000000-0_015051-00-217016-1_65620000_19_08_2019_17_07_55.spd IMEI: 015051-00-217016-1 UNLOCK CODE: NONE Gathering security data; Reading simlock; Done; Security check result: 0 Re-programming; Simlock programmed; NV programmed; Done; Phone unlocked; Remove battery and cable; Log file saved to: LOG_19_08_2019_17_08_16.txt Time needed - 00:00:58 |
08-20-2019, 15:21 | #15244 (permalink) |
No Life Poster Join Date: Jan 2006 Location: PORTUGAL
Member: 216446 Status: Offline Thanks Meter: 220 | ZTE A512 UNLOCK SUCESS Software engine version: 1.0.0.10850 Searching phone ... MODEL : QCOM SERIES 53 COMPILED DATE : Sep 3 2018 11:40:00 RELEASE DATE : May 27 2016 05:00:00 FIRMWARE INFO : MPSS.JO.1.2.c2-00081-8937_GENNS_PACK-1 IMEI : 86107003026621-8 BLUETOOTH ADDR : 00 00 00 00 00 00 FIRMWARE: PT_VDF_P817E52V1.0.0B37 close_event_report: OK; close_log_report: OK; close_message_report: OK; closing_com_port: OK; Starting the backup process; connect_server: OK; backup in progress: OK; Backup saved to: C:\Users\ETRONICS\Desktop\Unlock\furious\QCOM_SMAR T_TOOL_v1.0.0.10850 (2)\86107003026621_20_08_2019_15_17_37.bkp switching_download_mode: OK; closing_com_port: OK; Preparing to open COM10 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22D5 Looking for the interface; Port found [ZTE CDMA Handset Diagnostics Interface (COM62)] connect_server: OK; restore in progress: OK; SIM_LOCK REMOVED ! Log file saved to: LOG_20_08_2019_15_20_31.txt Time needed - 00:02:57 |
08-22-2019, 14:41 | #15245 (permalink) |
Junior Member Join Date: Feb 2011
Member: 1507732 Status: Offline Thanks Meter: 36 | FIG-LA1 FRP Done VIA TP Process identifier:4620471 Writing bootloader... Writing Kirin659_T0_A8.0_V1_3.dtwork... Writing Kirin659_T0_A8.0_V1_4.dtwork... Waiting for fastboot device... Device found: 35P4C1xxx7005754 Looking for a device in fastboot mode Device found: 35P4C1xxxx05754 Getting IMEI... Getting build number... Getting model ... Getting battery state... Getting backdoor info... Getting lock state info... Getting lock boot info... SN:3xxxxxxx IMEI:8658xxxxxxxx IMEI1:xxxxxxxxxx MEID:00000000000000 Build number: :FIG-LA1 9.1.0.121(C185E5R1P4) Model: FIG-LA1 Battery state: 0 OEM lock state info: FB LockState: UNLOCKED USER LockState: LOCKED OEM get bootinfo: unlocked Unlocking FRP... Writing FRP partition FRP partition UPDATE :FAIL partition error Writing FRP partition FRP partition UPDATE ...OK Software written 8/22/2019 6:37:25 PM Writing device finished OK |
The Following 2 Users Say Thank You to /\/\@ster For This Useful Post: |
08-27-2019, 15:30 | #15246 (permalink) |
No Life Poster Join Date: Dec 2001 Location: Barnsley UK Age: 56
Member: 7910 Status: Offline Thanks Meter: 57 | Huawei y6 2019 mrd-lx1 unlock success Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable with testpoint connected] Phone detected (MediaTek USB Port (COM39)) Preparing to start flash mode; Preparing to open COM39 Connecting; Downloading DA; Initializing; Rid: 1e5f4eeb1957831d2b8819d4381e3841 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6761 [CA01, 200, 6761, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333644 0x8B1F0142 0x7116C906 [SIZE=0x749400000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x110000000 SIZE: 0x637A00000 Searching data; Phone unlocked; Remove battery and cable; Time needed - 00:00:00 Log file saved to: LOG_27_08_2019_15_22_02.txt |
08-28-2019, 08:04 | #15247 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Asia Mobiles Repairing (Swabi)
Member: 435412 Status: Offline Sonork: 100.1608142 Thanks Meter: 289 | FInallly 6c pro Is Supported Flashing Flashing Code: Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM6)) Preparing to start flash mode; Preparing to open COM6 Connecting; Downloading DA; Initializing; Rid: 778c9bb4551d368f3694e30fbf6ca09e Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6750 [CB00, 01, 6750, 00] HW_STORAGE_EMMC: 0x484A0190 0x61344742 0xB24ED432 0x0B6497AE [SIZE=0x748800000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x15E800000 SIZE: 0x5E83FBE00 Loading the file ... Cfg done ... Downloading bootloader... Done; Downloading images... Done; Success; Time needed - 00:05:34 6c Pro Jmm-L22 Imei Repair Code: Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM6)) Preparing to start flash mode; Preparing to open COM6 Connecting; Downloading DA; Initializing; Rid: 778c9bb4551d368f3694e30fbf6ca09e Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6750 [CB00, 01, 6750, 00] HW_STORAGE_EMMC: 0x484A0190 0x61344742 0xB24ED432 0x0B6497AE [SIZE=0x748800000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x15E800000 SIZE: 0x5E83FBE00 Searching data; Checking data; NEW IMEI1: 111111-11-111111-9 OLD IMEI1: 865612-54-564785-9 NEW IMEI2: 111111-11-111111-9 OLD IMEI2: 865612-54-564784-9 NEW IMEI1: 111111-11-111111-9 OLD IMEI1: 865612-54-564785-9 NEW IMEI2: 222222-22-222222-8 OLD IMEI2: 865612-54-564784-9 IMEI repaired; Remove battery and cable; Time needed - 00:00:02 Special Thanks To Sir Mr.:hack3r2k:. |
The Following User Says Thank You to asia_gsm For This Useful Post: |
08-28-2019, 08:24 | #15248 (permalink) |
Freak Poster Join Date: Jan 2012 Location: Sylhet Korim Ullah Market Age: 28
Member: 1714226 Status: Offline Sonork: 100.1683394 Thanks Meter: 243 | Alcatel 5099y Unlock done by OTSmart Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek USB Port (COM63)) Preparing to start flash mode; Preparing to open COM63 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: 2e59c6df02c56cd0a114e64d1c3cc8ae Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM41; DEVICE INFO: BB CHIP: MT6737T [CA00, 00, 321, 05] HW_STORAGE_EMMC: 0x51000115 0x4D333645 0xAA1D0342 0x9B955AD2 [SIZE=0x3A4A00000] IMEI1 [OTP 0001]: 353937-09-064199-0 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5099Y-2BTWGB1 USRDATA INFO: 0xEE000000 SIZE: 0x2B2280000 Searching data; Locked to [SIM1]: 234-10 code_cat_n: 8157595936498579 enabled: yes tries: 10 code_cat_ns: 0515192764992779 enabled: no tries: 0 code_cat_sp: 8157595936498579 enabled: yes tries: 10 code_cat_c: 8157595936498579 enabled: no tries: 0 code_cat_sim: 8157595936498579 enabled: no tries: 0 Phone unlocked; Remove battery and cable; Time needed - 00:00:04 Log file saved to: LOG_28_08_2019_13_22_20.txt |
The Following User Says Thank You to rubelgsm For This Useful Post: |
08-29-2019, 22:47 | #15249 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Dominican Republic
Member: 2382052 Status: Offline Thanks Meter: 1,511 | alcatel 4044l unlock done Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@oem226.inf,%qcomdevice90080%;Qualcomm HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM28 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD size 3.6 GB IMEI: 01496000150124-5 PTH: 04 PTS: K4M PROV_ID: 4044L-2DOSUS1 SBTADDR: 5C:77:76:5D:F0:E8 SWIFIADDR: 5C:77:76:4F:23:B0 HS_PN: SAA61UHAE20C SSN: MHKF14CFGIB027P Bruteforcing data; This operation can take up to 30 minutes !!! Done; Work id: 3563E0CF Done; Stype: 00000001 SECURITY: XNK4U1M0CL00 Size: 000002D7 Backup saved to: 01496000150124-5 Unlocking; SIM_LOCK REMOVED ! Log file saved to: LOG_29_08_2019_17_46_35.txt Time needed - 00:13:05 |
08-31-2019, 11:21 | #15250 (permalink) |
Freak Poster Join Date: May 2014 Location: Africa
Member: 2179221 Status: Offline Sonork: 100.1685104 Thanks Meter: 66 | Huawei w1-u00 unlock done 2019-08-31 10:58:56.202 FlyCaptain Huawei Module v2.0.0.0184 2019-08-31 10:58:56.204 Dongle S/N: 91261461 Before detection connect cable to usb and enable Manufacture mode ! Qualcomm and HiSilicon: *#*#2846579#*#* MTK: *#*#14789632#*#* Windows: ##2846579# ProjectMenu 1.Background setting 2.USB ports setting Select Manufacture mode (for MTK other/debug mode) 2019-08-31 10:59:19.522 Autodetect started! 2019-08-31 10:59:19.562 Compatible COM ports not found! 2019-08-31 10:59:19.568 ERROR! Phone not found ! 2019-08-31 11:00:06.954 Autodetect started! 2019-08-31 11:00:07.073 Found COM port: COM367 2019-08-31 11:00:07.077 Open port COM367 (Qualcomm WinMobile Diagnostics 319B (COM367))... 2019-08-31 11:00:07.184 Start read phone info! 2019-08-31 11:00:07.196 Connecting to server... 2019-08-31 11:00:11.019 Connected! 2019-08-31 11:00:11.022 Read data from server... 2019-08-31 11:00:15.036 Read data from server success! 2019-08-31 11:00:29.207 Read secure info... 2019-08-31 11:00:29.250 Read basic info... 2019-08-31 11:00:29.331 Autodetect started! 2019-08-31 11:00:29.427 Found COM port: COM367 2019-08-31 11:00:29.512 Connecting to server... 2019-08-31 11:00:32.645 Connected! 2019-08-31 11:00:32.649 Read data from server... 2019-08-31 11:00:35.039 Read data from server success! 2019-08-31 11:00:35.042 Open COM port COM367 (Qualcomm WinMobile Diagnostics 319B (COM367))... 2019-08-31 11:00:47.560 Read secure info... 2019-08-31 11:00:47.905 Read basic info... 2019-08-31 11:00:48.117 Unlocking start 2019-08-31 11:00:53.866 Read data from server... 2019-08-31 11:00:57.785 Read data from server success! 2019-08-31 11:00:57.790 Writing security data... 2019-08-31 11:01:00.435 Write security data success! 2019-08-31 11:01:01.410 Unlock done! 2019-08-31 11:01:01.416 Job finished! 2019-08-31 11:01:05.731 Detect phone done! IMEI: 868624012672356 Firmware ver.: 1030.5613.07500.05700 Firmware model: W1_U00 Custom SN: 021YPM4C34000254 WiFi MAC: A4:99:47:4C:09:FE BlueTooth MAC: A4:99:47:4B:F6:29 IMEI 1 Sim Lock status: NET: locked, unlock retry counts: 0 NETSUB: unlocked SP: unlocked 2019-08-31 11:03:40.015 Autodetect started! 2019-08-31 11:03:40.095 Found COM port: COM367 2019-08-31 11:03:40.100 Open port COM367 (Qualcomm WinMobile Diagnostics 319B (COM367))... 2019-08-31 11:03:40.203 Start read phone info! 2019-08-31 11:03:40.217 Read secure info... 2019-08-31 11:03:40.265 Read basic info... 2019-08-31 11:03:40.347 Detect phone done! IMEI: 868624012672356 Firmware ver.: 1030.5613.07500.05700 Firmware model: W1_U00 Custom SN: 021YPM4C34000254 WiFi MAC: A4:99:47:4C:09:FE BlueTooth MAC: A4:99:47:4B:F6:29 IMEI 1 Sim Lock status: NET: unlocked NETSUB: unlocked SP: unlocked 2019-08-31 11:03:52.026 Autodetect started! 2019-08-31 11:03:52.105 Found COM port: COM367 2019-08-31 11:03:52.110 Open port COM367 (Qualcomm WinMobile Diagnostics 319B (COM367))... 2019-08-31 11:03:52.216 Start read phone info! 2019-08-31 11:03:52.231 Read secure info... 2019-08-31 11:03:52.278 Read basic info... 2019-08-31 11:03:52.359 Detect phone done! IMEI: 868624012672356 Firmware ver.: 1030.5613.07500.05700 Firmware model: W1_U00 Custom SN: 021YPM4C34000254 WiFi MAC: A4:99:47:4C:09:FE BlueTooth MAC: A4:99:47:4B:F6:29 IMEI 1 Sim Lock status: NET: unlocked NETSUB: unlocked SP: unlocked |
09-02-2019, 09:06 | #15251 (permalink) |
Member: 2179221 Status: Offline Sonork: 100.1685104 Thanks Meter: 66 | Flash Zte Z820 Done with furiousGold Box Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off with volume up pressed to the usb cable] Phone detected (MediaTek USB Port (COM3)) Preparing to start flash mode; Preparing to open COM3 Connecting; Downloading DA; Initializing; Rid: 8c6d0e7c322ed2fc8b499406dd5b6fca Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED DEVICE INFO: BB CHIP: MT6735M [CA00, 00, 335, 05] HW_STORAGE_EMMC: 0x484A0190 0x65314738 0x28800705 0xB3528AA4 [SIZE=0x1D2C00000] IMEI1 [OTP 00FF]: 867117-02-013439-5 IMEI2 [OTP 00FF]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0xD6000000 SIZE: 0x60000000 Loading the file ... Cfg done ... Formatting file system now... Done; Formatting SECCFG partition now... Done; Formatting FRP partition now... Done; Formatting NVDATA partition now... Done; Formatting METADATA partition now... Done; Downloading bootloader... Done; Downloading images... Done; Success; Time needed - 00:42:51 Log file saved to: LOG_2_09_2019_08_32_59.txt FlashTool Fail Miracle box : DA ERROR Fail UMT : DA NO EXIST FAIL AVENGERS : ... Bcom... fail FuriousGold Box : Time needed - 00:42:51 and DOOOOOOONNNNNNEEE |
09-02-2019, 16:33 | #15252 (permalink) |
Member: 2382052 Status: Offline Thanks Meter: 1,511 | huawei fig-lx3 frp done Fly Captain Huawei Resurrector 0.0.0.38 user:57A96656 Device detected: COM542: HUAWEI USB COM 1.0 (COM542) BOOTLOADER File to update: Kirin659_T0_A8.0_V1 02/09/2019 11:22:22 a.m. Starting to write device... Process identifier:4644966 Writing bootloader... Writing Kirin659_T0_A8.0_V1_3.dtwork... Writing Kirin659_T0_A8.0_V1_4.dtwork... Waiting for fastboot device... Device found: LDG4C18613000228 Looking for a device in fastboot mode Device found: LDG4C18613000228 Getting IMEI... Getting build number... Getting model ... Getting battery state... Getting backdoor info... Getting lock state info... Getting lock boot info... SN:LDG4C18613000228 IMEI:8658410381 IMEI1:000000000000000 MEID:00000000000000 Build number: :FIG-LX3 8.0.0.122(C25) Model: FIG-LX3 Battery state: 3205mv OEM lock state info: FB LockState: UNLOCKED USER LockState: LOCKED OEM get bootinfo: unlocked Unlocking FRP... Writing FRP partition FRP partition UPDATE :FAIL partition error Writing FRP partition FRP partition UPDATE ...OK Software written 02/09/2019 11:22:54 a.m. Writing device finished OK |
09-02-2019, 23:25 | #15253 (permalink) |
Member: 2382052 Status: Offline Thanks Meter: 1,511 | HUAWEI ANE-LX3 DOWNGRADE DONE FROM 9 TO 8 WRITE OEM INFO ANE-L23 USE BOOTLOADER KIRIM 659 Fly Captain Huawei Resurrector 0.0.0.38 user:57A96656 Looking for a device in upgrade mode COM548: Android Adapter PCUI (COM548) COM549: DBAdapter Reserved Interface (COM549) 02/09/2019 11:59:50 p.m. Starting to write device in UPGRADE mode... Device found: 6NUDU18828002047 02/09/2019 11:59:56 p.m. start to write update file File to update: UPDATE.APP File size: 4,339,279,260 bytes Current version(CURVER): ANE-BD 1.0.0.999 Process identifier:4645952 Validating file... Detecting port... Preparing to write... Writing file 1 of 34: SHA256RSA...OK Writing file 2 of 34: CRC...OK Writing file 3 of 34: CURVER...OK Writing file 4 of 34: VERLIST...OK Writing file 5 of 34: PACKAGE_TYPE...OK Writing file 6 of 34: EFI...OK Writing file 7 of 34: XLOADER...OK Writing file 8 of 34: FW_LPM3...OK Writing file 9 of 34: FASTBOOT...OK Writing file 10 of 34: MODEMNVM_UPDATE...OK Writing file 11 of 34: TEEOS...OK Writing file 12 of 34: TRUSTFIRMWARE...OK Writing file 13 of 34: SENSORHUB...OK Writing file 14 of 34: FW_HIFI...OK Writing file 15 of 34: KERNEL...OK Writing file 16 of 34: RAMDISK...OK Writing file 17 of 34: RECOVERY_RAMDISK...OK Writing file 18 of 34: RECOVERY_VENDOR...OK Writing file 19 of 34: ERECOVERY_KERNEL...OK Writing file 20 of 34: ERECOVERY_RAMDISK...OK Writing file 21 of 34: ERECOVERY_VENDOR...OK Writing file 22 of 34: RECOVERY_VBMETA...OK Writing file 23 of 34: ERECOVERY_VBMETA...OK Writing file 24 of 34: DTS...OK Writing file 25 of 34: MODEM_FW...OK Writing file 26 of 34: VBMETA...OK Writing file 27 of 34: ODM...OK Writing file 28 of 34: CACHE...OK Writing file 29 of 34: SYSTEM...OK Writing file 30 of 34: CUST...OK Writing file 31 of 34: VENDOR...OK Writing file 32 of 34: VERSION...OK Writing file 33 of 34: PRODUCT...OK Writing file 34 of 34: USERDATA...OK Software written 03/09/2019 06:19:51 p.m. Writing device finished OK |
09-04-2019, 15:51 | #15255 (permalink) |
Registered User Join Date: Mar 2008 Location: @ blacksheep digital
Member: 731353 Status: Offline Thanks Meter: 254 | Hisense u605 network lock done using world famous box Searching phone; For an successful connection do the following: 1. Connect the phone powered off with the battery inside to the usb cable Phone detected (@oem186.inf,%usbcomm_dl%;SPRD U2S Diag) Preparing to sync; Port opened [COM268]; Entering diagnostic mode; Done; Chip type: 0000:0000 Platform Version: MOCORTM_17C_W18.23.4_P20_Debug Project Version: pike2_pub BASE Version: FM_BASE_17C_W18.23.4_P20 HW Version: sc7731e_modem 02-25-2019 18:03:32 Build number: sp7731e_fs280_project-user 8.1.0 OPM2.171019.012 26112 release-keys PHONE INFO: BT ADDR: FF:FF:FF:FF:FF:FF SW IMEI[0]: 867790-04-XXX-X SW IMEI[1]: 867400-02-XXXX-X SW IMEI[2]: 867400-02-XXXX-X SW IMEI[3]: 867400-02-X-6XXXX SIMLOCK FLAG: ON SIM_LOCK TYPE: 3 IMEI: 867790-04-195950-1 UNLOCK CODE: 44940458 Done; Phone unlocked; Remove battery and cable; Log file saved to: LOG_4_09_2019_16_47_04.txt Time needed - 00:00:05 |
The Following 2 Users Say Thank You to bigjef1 For This Useful Post: |
