01-07-2021, 08:25 | #15631 (permalink) |
No Life Poster Join Date: Nov 2006 Location: pakistan Age: 39
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM_V1632 (Android) (COM3)) (Driver version: 3.0.1504.0) Preparing to start flash mode; Preparing to open COM3 Connecting; Downloading DA; Initializing; Rid: 2d9c349feebef7800e158e2b0d825763 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6765 [CA00, 00, 6765, 00] HW_STORAGE_EMMC: 0x684A0190 0x50613943 0x27C20133 0xF5C60225 [SIZE=0xE91000000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x148800000 SIZE: 0xD434FBE00 Searching data; Checking data; NVRAM integrity check passed; Formatting NVDATA partition now... Done; IMEI repaired; Remove battery and cable; Time needed - 00:00:19 Log file saved to: LOG_7_01_2021_12_14_47.txt |
01-07-2021, 08:29 | #15632 (permalink) |
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | tecno spark 4 imei rapeir done Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM_V1632 (Android) (COM3)) (Driver version: 3.0.1504.0) Preparing to start flash mode; Preparing to open COM3 Connecting; Downloading DA; Initializing; Rid: 2d9c349feebef7800e158e2b0d825763 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6765 [CA00, 00, 6765, 00] HW_STORAGE_EMMC: 0x684A0190 0x50613943 0x27C20133 0xF5C60225 [SIZE=0xE91000000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x148800000 SIZE: 0xD434FBE00 Searching data; Checking data; NVRAM integrity check passed; Formatting NVDATA partition now... Done; IMEI repaired; Remove battery and cable; Time needed - 00:00:19 Log file saved to: LOG_7_01_2021_12_14_47.txt |
01-08-2021, 20:29 | #15633 (permalink) |
No Life Poster Join Date: Jan 2006 Location: PORTUGAL
Member: 216446 Status: Offline Thanks Meter: 220 | Amn-lx9 unlock done TESTPOITS Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable with testpoint connected] Phone detected (MediaTek USB Port (COM132)) (Driver version: 3.0.1504.0) Preparing to start flash mode; Preparing to open COM132 Connecting; Downloading DA; Initializing; Rid: b9d1f04991078a3f3dc6b94a3e0f48dd Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6761 [CA01, 200, 6761, 00] BB ID: RDUwNUQ3Q0ExN0I0QkIyRTUyMTdDRDMzRkZDOTM0MzU= HW_STORAGE_EMMC: 0x484A0190 0x61344741 0xAC00D432 0xA357AA14 [SIZE=0x3AC000000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0xEE000000 SIZE: 0x2BD200000 Searching data; Phone unlocked; Remove battery and cable; Time needed - 00:00:01 Log file saved to: LOG_8_01_2021_18_40_25.txt |
01-13-2021, 21:17 | #15634 (permalink) |
No Life Poster Join Date: Oct 2006 Location: Republica Dominicana Age: 40
Member: 381487 Status: Offline Sonork: 100.1659930 Thanks Meter: 160 | lg k40 imei repair. Using library Brom_DLL_v7.1813.3 Engine version 1.0.0.5188 Searching phone in emergency mode; [connect the phone in "Firmware Update" Mode. Hold the Volume Up on the powered off phone and enter the USB cable in order to enter it] Phone detected (USB\VID_1004&PID_6000&REV_0100) Preparing to start flash mode; Preparing to open COM34 Opened; Authorising; Authorized; LAF_ERROR_ACCESS_DENIED download_cable = 910K battery_level = 43 download_type = download_speed = 0 usb_version = UHS hardware_revision = rev_11 download_sw_version = device_sw_version = X420HM20x secure_device = S laf_sw_version = 1.1 device_factory_version = LMX420HMAT-00-V20g-722-310-OCT-30-2020+0 device_factory_out_version = LMX420HMAT-00-V20g-722-310-OCT-30-2020+0 pid = HB30S191020003334 imei = 353389103714184 model_name = LM-X420HM device_build_type = U chipset_platform = mt6765 target_operator = LAO target_country = COM ap_factory_reset_status = 6 cp_factory_reset_status = 0 isDownloadNotFinish = 0 qem = 0 cupss_swfv = A1604060961-M1604060961-FFFFFFFFFFF-U1604065416-0 is_one_binary_dual_plan = 0 memory_size = 61071360 memory_id = QX63MB bootloader_ver = MiniOS 3.0 islan_download = 0 skip_readwrite = 0 Starting; Setting secure mode; Done; Linux localhost 4.9.117+ #1 SMP PREEMPT Fri Oct 30 18:03:15 IST 2020 armv7l Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Getting security info; Setting secure mode; Done; Reading security; Done; Checking security; Phone it's going restart several times during this step; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Done; Contents saved to : C:\Users\Juegos\Desktop\SEC_BKP_LG LM-X420HM_35338910.osp Working; Connecting to server; Authorisation process started; Furious Multipurpose Credits: 1 Done; Requesting data from server ! Wait please ... Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; IMEI A: 353389-10-37 IMEI B: 350305-26-00 IMEI C: 350305-26-00 WiFi ADDR: 98:B8:BA:0E:C80 BT ADDR: 98:B8:BA:A0:40:79 LOCK STATUS: 0 0 0 0 Done; Working; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; IMEI1 repaired; Starting Re-init operation; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Erasing; Re-init operation completed; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Operation completed ! Setting secure mode; Done; Time needed - 00:04:59 Log file saved to: LOG_13_01_2021_16_57_08.txt |
01-14-2021, 16:38 | #15635 (permalink) |
Member: 216446 Status: Offline Thanks Meter: 220 | alcatel 1s frp done - spd tool Searching phone; For an successful connection do the following: 1. Power on the phone and power it off 2. Keep pressed firmly volume UP key 3. Insert the usb cable inside the phone while keeping pressed volume UP Phone detected (@oem321.inf,%usbcomm_dl%;SPRD U2S Diag) (Driver version: 2.0.0.114) Preparing to sync; Port opened [COM81]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: (c)2019, FuriouSTeaM Starting FDL2; FDL2 sent; Starting auth; memory_type: IF_TYPE_MMC dev_no: 0 part_type: PART_TYPE_UNKNOWN vendor: Man 0000f4 Snr 0000034c product: Biwin revision: 1.0 memory_size: 28.8 GB HW IMEI : 000000-00-000000-0 PHONE INFO: NONE PHONE ID: MTAwYjQ5ODIwMDkwMzlhNg== BT ADDR: NONE SW IMEI[0]: 353827-11-228065-5 SW IMEI[1]: 353827-11-228066-3 SW IMEI[2]: 867400-02-031663-8 SW IMEI[3]: 867400-02-031664-6 SIMLOCK FLAG: OFF Starting format; Formatted; Done; Remove battery and cable; Log file saved to: LOG_14_01_2021_15_34_13.txt Time needed - 00:00:25 |
01-15-2021, 04:30 | #15636 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Australia
Member: 177568 Status: Offline Thanks Meter: 147 | LG K42 unlock done Using library Brom_DLL_v7.1813.3 Engine version 1.0.0.5188 Searching phone in emergency mode; [connect the phone in "Firmware Update" Mode. Hold the Volume Up on the powered off phone and enter the USB cable in order to enter it] Phone detected (USB\VID_1004&PID_6000&REV_0100) Preparing to start flash mode; Preparing to open COM9 Opened; Authorising; Authorized; LAF_ERROR_ACCESS_DENIED download_cable = 910K battery_level = 19 download_type = download_speed = 0 usb_version = UHS hardware_revision = rev_11 download_sw_version = device_sw_version = K420YM10b secure_device = S laf_sw_version = 1.1 device_factory_version = LMK420YMAT-01-V10a-505-03-SEP-01-2020+0 device_factory_out_version = LMK420YMAT-00-V10a-505-03-SEP-01-2020+0 pid = 0B9FD026RLAM00N26 imei = 356590110419587 model_name = LM-K420YM device_build_type = U chipset_platform = mt6765 target_operator = LAO target_country = COM ap_factory_reset_status = 6 cp_factory_reset_status = 0 isDownloadNotFinish = 0 qem = 0 cupss_swfv = A1598977124-M1598977124-FFFFFFFFFFF-U1598979934-0 is_one_binary_dual_plan = 0 memory_size = 122159104 memory_id = G1J9P8 bootloader_ver = MiniOS 3.0 islan_download = 0 skip_readwrite = 0 Starting; Setting secure mode; Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Getting security info; Setting secure mode; Done; Reading security; Done; Checking security; Phone it's going restart several times during this step; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Done; Contents saved to : C:\Unlocking Softwares\FuriousGold\OTSmart\OTSmart_v1.0.0.5188_ SEC_Edition\SEC_BKP_LG K42_35659xxxxxxxxxx.osp Working; Connecting to server; Authorisation process started; Furious Multipurpose Credits: 6 Done; Requesting data from server ! Wait please ... Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; IMEI A: 356590-11-xxxxxx-x IMEI B: 350305-xx-000000-1 IMEI C: 350305-xx-000000-1 WiFi ADDR: C8:F3:19:97:CB:F9 BT ADDR: A0:4F:85:22:C3:81 LOCK STATUS: 1 0 0 0 Unlock codes: NCK: 0000000000000000 NSCK: 0000000000000000 SPCK: 0000000000000000 CPCK: 0000000000000000 SIMCK: 0000000000000000 Enter the codes without a sim by using *#*#7465625#*#* Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Done; Phone unlocked; Starting Re-init operation; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Erasing; Re-init operation completed; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Operation completed ! Setting secure mode; Done; Time needed - 00:05:54 Log file saved to: LOG_15_01_2021_14_24_17.txt |
01-18-2021, 14:34 | #15637 (permalink) |
No Life Poster Join Date: Oct 2005 Location: TITI 2002 SERVIS CELULAR PG/AL
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | med-lx9n remove huwaei id Done; Searching phone in normal mode; [connect the phone powered off to the usb cable with testpoint connected] Phone detected (MediaTek USB Port (COM123)) (Driver version: 3.0.1504.0) Preparing to start flash mode; Preparing to open COM123 Connecting; Downloading DA; Initializing; Rid: 761240bdca1d6cbc45e33ed2ada77a34 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6765 [CA00, 00, 6765, 00] BB ID: NEM1OUUzNEQ3QTAyNUE5NUJFMzU1NEYzRTQ2NkREMTc= HW_STORAGE_EMMC: 0x684A0190 0x50613843 0x3600013E 0x2F57BB03 [SIZE=0xE91000000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x136800000 SIZE: 0xD58E00000 Huawei ID removed ; Formatting FRP partition now... Done; Factory Reset Protection successfully removed ! Time needed - 00:03:13 Log file saved to: LOG_18_01_2021_14_25_19.txt |
01-20-2021, 13:36 | #15638 (permalink) |
Freak Poster Join Date: May 2014 Location: Africa
Member: 2179221 Status: Offline Sonork: 100.1685104 Thanks Meter: 66 | Alcatel OT-4034D Boot Dead, restor with flash Searching phone in emergency mode; [connect the phone powered off with volume down pressed to the usb cable] Phone detected (MediaTek USB Port (COM9)) (Driver version: 3.2.0.0) Preparing to start flash mode; Preparing to open COM9 Connecting; Downloading DA; Initializing; Rid: 463979474ac10eb3f59ec74f5f10c747 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem111.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM18; DEVICE INFO: BB CHIP: MT6580 [CA00, 00, 6580, 05] HW_STORAGE_EMMC: 0x504E01FE 0x34394A31 0xA300124D 0x71C46AF8 [SIZE=0xE9B00000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x58800000 SIZE: 0x60000000 SPECIAL NOTE: If you are using windows 10 x64 be sure that the installed mtk driver version is 3.0.1504.0 . Any different drivers will create random read bugs on newer chipset phones. As usual the correct drivers come inside OTSMart archive inside the "usb_driver" folder Loading the file ... Cfg done ... Formatting file system now... Done; Formatting SECCFG partition now... Done; Formatting FRP partition now... Done; Formatting NVDATA partition now... Done; Formatting METADATA partition now... Done; Downloading bootloader... Done; Downloading images... Done; Success; Time needed - 00:05:12 Log file saved to: LOG_20_01_2021_13_22_04.txt |
01-21-2021, 16:24 | #15639 (permalink) |
Member: 216446 Status: Offline Thanks Meter: 220 | Vfd895n unlocked ....vodafone smart prime 6 POWER OFF CONNECT USB ...CLICK FIREHORSE MODE ...SELECT MODEL ...DO JOB....NOW CONNECT PHONE USING VOL + AND - CONNECT USB Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@oem4.inf,%qcomdevice90080%;Qualcomm HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM48 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory size 7.3 GB, target id 8916 IMEI: 35690706198068-2 PTH: 13 PTS: W5B PROV_ID: V895N-2GVDPT1 SBTADDR: D0:9D:AB:97:F1:77 SWIFIADDR: D0:9D:AB:97:F1:78 HS_PN: SAA6197AAS0C SSN: 3PKC33CBDJY024P Work id: 0E37B50D Setup 1; Done; Setup 2; Done; Setup 3; Done; Uploading; Done; SECURITY: X9W5FFB0BG00 Size: 00000430 Backup saved to: 35690706198068-2 Backup file(s) removed; Checking the simlock; Magic ok; Unlocking; SIM_LOCK REMOVED ! Log file saved to: LOG_21_01_2021_15_20_56.txt Time needed - 00:00:59 |
01-21-2021, 17:00 | #15640 (permalink) |
Member: 216446 Status: Offline Thanks Meter: 220 | Vodafone vfd500 turbo smart 7 Using library Brom_DLL_v7.1522.2 Engine version 1.0.0.5188 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM63)) (Driver version: 3.2.0.0) Preparing to start flash mode; Preparing to open COM63 Connecting; Downloading DA; Initializing; Rid: b5960402bf37297920fb63c761705314 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem182.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM79; DEVICE INFO: BB CHIP: MT6735M_S00 [CA00, 00, 335, FF] HW_STORAGE_EMMC: 0x46000115 0x4D32584E 0xABB30142 0x7F1489AC [SIZE=0x1D2880000] IMEI1 [OTP 0001]: 357911-07-425695-6 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: V500-2AVDPT1 USRDATA INFO: 0xBD000000 SIZE: 0x111480000 Searching data; Locked to [SIM1]: 268-01 code_cat_n: 6964784741020011 enabled: yes tries: 6 code_cat_ns: 0216475741819958 enabled: no tries: 10 code_cat_sp: 9316979060367129 enabled: no tries: 10 code_cat_c: 0474518311713504 enabled: no tries: 10 code_cat_sim: 8733937104852222 enabled: no tries: 10 code_cat_ns_sp: 4334251357550664 enabled: no tries: 5 code_cat_sim_c: 4253568976129409 enabled: no tries: 5 Phone unlocked; Remove battery and cable; Time needed - 00:00:09 Log file saved to: LOG_21_01_2021_15_58_36.txt |
01-22-2021, 16:22 | #15641 (permalink) |
No Life Poster Join Date: Dec 2008 Location: just around
Member: 914220 Status: Offline Thanks Meter: 206 | shark duo plus unlocked Searching phone; For an successful connection do the following: 1. Remove battery and usb cable 2. Insert the usb cable in the phone 3. Keep pressed the boot key and insert the battery Phone detected (@oem360.inf,%usbcomm_dl%;SPRD U2S Diag) (Driver version: 2.0.0.131) Preparing to sync; Port opened [COM61]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: (c)2014, FuriouSTeaM GSM DEVELOPEMENT Chip type: 6531:0001 Starting auth; HW IMEI : 000000-00-000000-0 Memory [CS0]: 00EF:0040:0016 - SIZE : 00400000 Reading phone info; PHONE INFO: NONE BT ADDR: 03:15:11:22:63:80 SW IMEI[0]: 351910-07-4120xxx SW IMEI[1]: 352751-01-9523xxx SW IMEI[2]: 358570-01-0103xxx SW IMEI[3]: 910575-60-1400xxx SIMLOCK FLAG: OFF FIXED NV BASE: 303B0000 Uncompressing; Done; Re-programming; FLS programmed; Done; Remove battery and cable; Log file saved to: LOG_22_01_2021_11_13_44.txt Time needed - 00:02:15 |
01-23-2021, 14:32 | #15642 (permalink) |
No Life Poster Join Date: Mar 2018 Location: Future.... ✌️
Member: 2825953 Status: Offline Thanks Meter: 246 | Y6p Huawei ID Removed Model: MED-LX9 Firmware ver.: MED-L09 10.1.0.186(C16E5R2P2) SN: WPQBB20527212660 Vendor: mtn Country: za Using library Brom_DLL_v7.1813.3 Searching phone in normal mode; [connect the phone powered off to the usb cable with testpoint connected] Phone detected (MediaTek USB Port (COM4)) (Driver version: 3.2.0.0) Preparing to start flash mode; Preparing to open COM4 Connecting; Downloading DA; Initializing; Rid: b220f238ad4b2390c9505b81914f4a59 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6765 [CA00, 00, 6765, 00] BB ID: RDM0REY2NzAzQTY5Qzk0Mjg5RjJCMkFDMUFCQUZEQUI= HW_STORAGE_EMMC: 0x684A0190 0x50613843 0xBC00013E 0x3D47DCDA [SIZE=0xE91000000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x158800000 SIZE: 0xD36E00000 SPECIAL NOTE: If you are using windows 10 x64 be sure that the installed mtk driver version is 3.0.1504.0 . Any different drivers will create random read bugs on newer chipset phones. As usual the correct drivers come inside OTSMart archive inside the "usb_driver" folder Contents saved to : D:\Software\OTSmart_v1.0.0.5011_SEC_Edition\PART_O EMINFO_HUAWEI Y6P_b220f238ad4b2390c9505b81914f4a59_22_01_2021_17 _16_35.osp Formatting OEMINFO partition now... Done; Done; Searching phone in normal mode; [connect the phone powered off to the usb cable with testpoint connected] Phone detected (MediaTek USB Port (COM4)) (Driver version: 3.2.0.0) Preparing to start flash mode; Preparing to open COM4 Connecting; Downloading DA; Initializing; Rid: b220f238ad4b2390c9505b81914f4a59 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6765 [CA00, 00, 6765, 00] BB ID: RDM0REY2NzAzQTY5Qzk0Mjg5RjJCMkFDMUFCQUZEQUI= HW_STORAGE_EMMC: 0x684A0190 0x50613843 0xBC00013E 0x3D47DCDA [SIZE=0xE91000000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x158800000 SIZE: 0xD36E00000 SPECIAL NOTE: If you are using windows 10 x64 be sure that the installed mtk driver version is 3.0.1504.0 . Any different drivers will create random read bugs on newer chipset phones. As usual the correct drivers come inside OTSMart archive inside the "usb_driver" folder Current cust: mtn/za Huawei ID removed ; Formatting FRP partition now... Done; Factory Reset Protection successfully removed ! Time needed - 00:03:47 Log file saved to: LOG_22_01_2021_17_20_20.txt |
01-23-2021, 15:00 | #15643 (permalink) |
Member: 914220 Status: Offline Thanks Meter: 206 | alcatel 5026E unlocked success Using library Brom_DLL_v7.1813.3 Engine version 1.0.0.5188 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek USB Port (COM253)) (Driver version: 3.0.1504.0) Preparing to start flash mode; Preparing to open COM253 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: ce12e594db6498abb1059bebb06c75b9 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6765 [CA00, 00, 6765, 00] HW_STORAGE_EMMC: 0x534E0113 0x4B394A30 0xAD1F1038 0x0D87EAB2 [SIZE=0xE91000000] IMEI1 [OTP 0000]: 354059-11-082980-9 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: 5029E-2CRGDO11 USRDATA INFO: 0x193000000 SIZE: 0xCF8CFBE00 Searching data; File not found; Phone unlocked; Remove battery and cable; Time needed - 00:00:01 Log file saved to: LOG_23_01_2021_09_28_19.txt |
01-25-2021, 13:51 | #15644 (permalink) |
No Life Poster Join Date: Apr 2001 Location: AGADIR Morocco
Member: 3936 Status: Offline Thanks Meter: 237 | K51S unlocked successfully Using library Brom_DLL_v7.1813.3 Searching phone in emergency mode; [connect the phone in "Firmware Update" Mode. Hold the Volume Up on the powered off phone and enter the USB cable in order to enter it] Phone detected (USB\VID_1004&PID_6000&REV_0409) Preparing to start flash mode; Preparing to open COM15 Opened; Authorising; Authorized; LAF_ERROR_ACCESS_DENIED download_cable = 910K battery_level = 99 download_type = download_speed = 0 usb_version = UHS hardware_revision = rev_10 download_sw_version = device_sw_version = K510EMW10f secure_device = S laf_sw_version = 1.1 device_factory_version = LMK510EMWAT-64-V10f-EEA-XX-SEP-10-2020+0 device_factory_out_version = LMK510EMWAT-00-V10f-EEA-XX-SEP-10-2020+0 pid = WI20S201016065973 imei = 353266113655393 model_name = LM-K510EMW device_build_type = U chipset_platform = mt6765 target_operator = LAO target_country = COM ap_factory_reset_status = 6 cp_factory_reset_status = 0 isDownloadNotFinish = 0 qem = 0 cupss_swfv = A1599700482-M1599700482-FFFFFFFFFFF-U1599703449-0 is_one_binary_dual_plan = 0 memory_size = 122142720 memory_id = hC8aP> bootloader_ver = MiniOS 3.0 islan_download = 0 skip_readwrite = 0 Starting; Setting secure mode; Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Getting security info; Setting secure mode; Done; Reading security; Done; Checking security; Phone it's going restart several times during this step; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Done; Contents saved to : C:\Program Files\FURIOUS-GOLD\PACK6\OTSmart\SEC_BKP_LG K51S_353266113655393.osp Working; Connecting to server; Authorisation process started; Done; Requesting data from server ! Wait please ... Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; IMEI A: 353266-11-xxxxxxx-3 IMEI B: 353266-11-xxxxxxx-1 IMEI C: 350305-26-xxxxxxx-1 WiFi ADDR: 30:FC:EB:22:68:6C BT ADDR: 30:FC:EB:BD0:EF LOCK STATUS: 4 6 0 0 Unlock codes: NCK: 0000000000000000 NSCK: 0000000000000000 SPCK: 0000000000000000 CPCK: 0000000000000000 SIMCK: 0000000000000000 Enter the codes without a sim by using *#*#7465625#*#* Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Done; Phone unlocked; Starting Re-init operation; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Erasing; Re-init operation completed; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Operation completed ! Setting secure mode; Done; Time needed - 00:04:18 Log file saved to: LOG_25_01_2021_11_27_40.txt |
01-25-2021, 21:45 | #15645 (permalink) |
Member: 914220 Status: Offline Thanks Meter: 206 | joy tab alcatel 9029z unlockes success Using library Brom_DLL_v7.1813.3 Engine version 1.0.0.5188 Searching phone; (insert the USB cable in the powered off phone or insert the USB cable in the powered off phone while keeping volume down pressed) Phone detected (MediaTek USB Port (COM403)) Preparing to start meta mode; Requesting authorization; Searching for debug port; (be sure drivers from support were installed) Meta mode entered; Baseband Chip: MT6739 Sw version: Hw Version: alps-mp-p0.mp1-V5.112_tcl.p0mp1.tb8765ap1.64.bsp_P9 Baseband Chip: MT6739 Sw version: MOLY.LR12A.R3.MP.V65.2.P2 Hw Version: TK_MD_BASIC_HW Reading phone info; IMEI 1: 015608-00-393369-7 IMEI 2: N/A Working; Unlocking; Phone unlocked; Remove battery and cable; Time needed - 00:00:38 Log file saved to: LOG_25_01_2021_16_40_31.txt Last edited by frankcelular1; 01-25-2021 at 21:49. Reason: model show |
