05-09-2021, 14:47 | #15706 (permalink) |
No Life Poster Join Date: Dec 2008 Location: just around
Member: 914220 Status: Offline Thanks Meter: 206 | lg k51 unlock too success Engine version 1.0.0.5212 Searching phone in emergency mode; [connect the phone in "Firmware Update" Mode. Hold the Volume Up on the powered off phone and enter the USB cable in order to enter it] Phone detected (USB\VID_1004&PID_6000&REV_0100) Preparing to start flash mode; Preparing to open COM149 Opened; Authorising; Authorized; LAF_ERROR_ACCESS_DENIED download_cable = 910K battery_level = 17 download_type = download_speed = 0 usb_version = UHS hardware_revision = rev_10 download_sw_version = device_sw_version = K500MM10l secure_device = S laf_sw_version = 1.1 device_factory_version = LMK500MMAT-02-V10l-310-160-NOV-21-2020-ARB00+0 device_factory_out_version = LMK500MMAT-00-V10l-310-160-NOV-21-2020-ARB00+0 pid = VP01S200921004018 imei = 354544115881xxx model_name = LM-K500MM device_build_type = U chipset_platform = mt6765 target_operator = LAO target_country = COM ap_factory_reset_status = 6 cp_factory_reset_status = 0 isDownloadNotFinish = 0 qem = 0 cupss_swfv = A1605897045-M1605897045-FFFFFFFFFFF-U1605903255-0 is_one_binary_dual_plan = 0 memory_size = 61087744 memory_id = GX6BAB bootloader_ver = MiniOS 3.0 islan_download = 0 skip_readwrite = 0 Starting; Setting secure mode; Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Getting security info; Setting secure mode; Done; Reading security; Done; Checking security; Phone it's going restart several times during this step; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Contents saved to : C:\Users\hola\Desktop\FURIOUS\PAACK 6\OTSmart_v1.0.0.5212_SEC_Edition\SEC_BKP_LG LM-K500MM_354544115881xxx.osp Working; Connecting to server; Authorisation process started; Furious Multipurpose Credits: 1 Done; Requesting data from server ! Wait please ... Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. ERROR: Scan port failed ! - Repeat the operation keeping pressed volume up during the whole procedure !!! Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; IMEI A: 354544-11-5881xxx IMEI B: 350305-26-000000-1 IMEI C: 350305-26-000000-1 WiFi ADDR: 30:FC:EB:7C:AB:57 BT ADDR: 48:90:2F:01:37:76 LOCK STATUS: 2 0 0 0 Unlock codes: NCK: 0000000000000000 NSCK: 0000000000000000 SPCK: 0000000000000000 CPCK: 0000000000000000 SIMCK: 0000000000000000 Enter the codes without a sim by using *#*#7465625#*#* Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Done; Phone unlocked; Starting Re-init operation; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. ERROR: Scan port failed ! - Repeat the operation keeping pressed volume up during the whole procedure !!! Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Erasing; Re-init operation completed; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Operation completed ! Setting secure mode; Done; Time needed - 00:07:34 Log file saved to: LOG_8_05_2021_17_44_42.txt |
05-12-2021, 14:23 | #15707 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Dominican Republic
Member: 2382052 Status: Offline Thanks Meter: 1,511 | REVV 4+ 5062Z FRP DONE Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@oem145.inf,%qcomdevice90080%;Qualcomm HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM53 Connecting; Loading; Init; Port opened; MSM_ID: 0x0010A0E1 OEM_ID: 0x0042 MODEL_ID: 0x0056 PK_HASH: BC602F6C059425EB26489E98C7F6F0FDB04D87352DA5C3CA09 50235CBAFA8A368714CA631D20DF5D1EB7632D676839D4BC60 2F6C059425EB26489E98C7F6F0FDB04D87352DA5C3CA095023 5CBAFA8A368714CA631D20DF5D1EB7632D676839D4BC602F6C 059425EB26489E98C7F6F0FDB04D87352DA5C3CA0950235CBA FA8A368714CA631D20DF5D1EB7632D676839D4 BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory size 58.2 GB, target id 0000 IMEI: 01572700198 PTH: 06 PTS: A94 PROV_ID: 5062Z-2AE4US11 SBTADDR: F0:51:36:F4:3B:30 SWIFIADDR: F0:51:36:EE:48:39 HS_PN: SAA2FF10C11C SSN: MJLC06CJQLD00JM Work id: 22021984 Done; Starting frp erase operation; Erasing; Done; FRP Removed ! Log file saved to: LOG_12_05_2021_09_16_16.txt Time needed - 00:00:53 |
05-12-2021, 15:50 | #15708 (permalink) |
Freak Poster Join Date: Jun 2013 Location: Zimbabwe, mutare
Member: 1957238 Status: Offline Thanks Meter: 80 | we hope some day you wanna add boot bypass authorisation for mtk secured boot in your otsmart tool so as to extend supported models for your tool and us work become more easier. |
05-12-2021, 15:50 | #15709 (permalink) |
05-15-2021, 13:01 | #15714 (permalink) | |
Banned Join Date: Nov 2010 Location: :::LONDON:::
Member: 1442994 Status: Offline Thanks Meter: 899 | https://www.youtube.com/watch?v=2F_v...FO%2CTRAVELFIT ALCATEL 1S 2020 5028Y UNLOCK DONE Quote:
05-15-2021, 22:12 | #15715 (permalink) | |
Member: 1442994 Status: Offline Thanks Meter: 899 | https://www.youtube.com/watch?v=BAVB...FO%2CTRAVELFIT HuAWEI Y5P DRA-LX9 HUAWEI AND GMAIL FRP RMOVED TOGETHER Quote:
05-16-2021, 11:34 | #15716 (permalink) | |
Member: 1442994 Status: Offline Thanks Meter: 899 | https://www.youtube.com/watch?v=8JtS...FO%2CTRAVELFIT HUAWEI HONOR 7S DUA-L22 FRP REMOVED... Quote:
05-18-2021, 14:39 | #15717 (permalink) |
No Life Poster Join Date: Jul 2001 Location: Planet earth
Member: 5169 Status: Offline Thanks Meter: 684 | revvl2 ot-5052w unlock 100% working Using library Brom_DLL_v7.1813.3 Engine version 1.0.0.5294 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek USB Port (COM24)) (Driver version: 2.0.1136.0) Preparing to start flash mode; Preparing to open COM24 Requesting authorization; Connecting; Downloading DA; Initializing; Rid: f558951e141e73e729174ef6e3c6c8b3 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6739 [CB00, 02, 6739, 00] BB ID: MTlGNjlGODNEQTFCRTEzN0VFMzYzMDVDQ0QwN0M5RUM= HW_STORAGE_EMMC: 0x51000115 0x4D333644 0xC6360142 0xEB162DD2 [SIZE=0x749400000] IMEI1 [OTP 0001]: 015246-00-000000-8 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 5052W-2ATBUSE USRDATA INFO: 0x133800000 SIZE: 0x6108FBE00 SPECIAL NOTE: If you are using windows 10 x64 be sure that the installed mtk driver version is 3.0.1504.0 . Any different drivers will create random read bugs on newer chipset phones. As usual the correct drivers come inside OTSMart archive inside the "usb_driver" folder Searching data; Checking server support license; Bruteforcing ... relax ;-) Buteforce took 00:00:00 Checking data integrity; Data integrity: OK; SIM_LOCK: PARTIAL_UNLOCK Rebuilding security; Phone unlocked; Remove battery and cable; Time needed - 00:00:02 Log file saved to: LOG_18_05_2021_14_00_51.txt |
05-18-2021, 16:24 | #15718 (permalink) | |
Member: 1442994 Status: Offline Thanks Meter: 899 | https://www.youtube.com/watch?v=p-_v...FO%2CTRAVELFIT HuAWEI Y6 2019 MRD-LX1 UNLOCK DONE WITH TESTPOINTS Quote:
05-18-2021, 16:24 | #15719 (permalink) | |
05-18-2021, 17:37 | #15720 (permalink) | |
Member: 1442994 Status: Offline Thanks Meter: 899 | https://www.youtube.com/watch?v=5JtJ...FO%2CTRAVELFIT NOKIA 2.2 UNLOCK WITH FURIOU SGOLD DONE FASTEST UNLOCKING TOOL Quote:
