07-09-2022, 15:52 | #15841 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Cochabamba Age: 38
Member: 87396 Status: Offline Thanks Meter: 64 | Engine version 1.0.0.5113 Searching phone; For an successful connection do the following: 1. Connect the phone powered off with the battery inside to the usb cable Phone detected (@oem186.inf,%usbcomm_dl%;SPRD U2S Diag) (Driver version: 4.19.38.135) Preparing to sync; Port opened [COM23]; Entering diagnostic mode; Done; Chip type: 0000:0000 Platform Version: MOCORTM_18B_W21.20.4_Debug Project Version: sharkl3_pub BASE Version: FM_BASE_18B_W21.20.4 HW Version: sc9863A_modem 05-20-2021 09:21:14 Build number: BOLD_M7_TIGO-user 10 QP1A.190711.020 188 release-keys Friendly Name: NTUxNzFCMDA4NjJFOTIzODZGQzc1RjBFOTFDRDg4NkYwNURGND VFMQ== PHONE INFO: NONE BT ADDR: NONE SW IMEI[0]: 350741- SW IMEI[1]: 867400- SW IMEI[2]: 867400- SW IMEI[3]: 867400- SIMLOCK FLAG: ON BKP saved to : BKP_000000-00-000000-0_350741-00-000000-0_00000000_9_07_2022_10_46_35.spd SIM_LOCK TYPE: 2 IMEI: 350741-00-000000-0 UNLOCK CODE: 13829969 Code reading finished; Remove battery and cable; Log file saved to: LOG_9_07_2022_10_46_43.txt Time needed - 00:00:13 |
07-15-2022, 19:42 | #15842 (permalink) |
Freak Poster Join Date: Nov 2016 Location: GB
Member: 2647569 Status: Offline Sonork: micaw Thanks Meter: 118 | Nokia 105 4G successfully unlocked thanks to @yuranc8 Select Nokia 110 4G Code: Code: Engine version 1.0.0.5113 Searching phone; For an successful connection do the following: 1. Connect the phone powered off with the battery inside to the usb cable Phone detected (@oem40.inf,%sprd.diag%;SPRD DIAG) (Driver version: 4.19.38.135) Preparing to sync; Port opened [COM7]; Entering diagnostic mode; Done; Chip type: 9818:0001 Platform Version: MOCOR_20A_MP_KN4_W21.30.6_Release Software Version: 13.00.17.01 BASE Version: FM_BASE_20A_THIN_MODEM_KN4_W21.30.6 HW Version: UMS9117 buildtime:09-10-2021 16:53:28 Platform Version: MOCOR_20A_MP_KN4_W21.30.6_Release Software Version: 13.00.17.01 BASE Version: FM_BASE_20A_THIN_MODEM_KN4_W21.30.6 HW Version: UMS9117 Build number: buildtime:09-10-2021 16:53:28 Friendly Name: RjRDNEYyN0I2MkE1NzFFRDc1NzcyRDk3QTQ5QTUzODhBNEQzMjJBQg== PHONE INFO: NONE BT ADDR: FF:FF:FF:FF:FF:FF SW IMEI[0]: 358530-92-337663-0 SW IMEI[1]: 358530-92-387663-9 SW IMEI[2]: 867400-02-031663-8 SW IMEI[3]: 867400-02-031664-6 SIMLOCK FLAG: ON BKP saved to : BKP_000000-00-000000-0_358530-92-337663-0_98180001_15_07_2022_20_14_46.spd SIM_LOCK TYPE: 4 Analysing data; Please WAIT ! OK; PHONE ID: MDA5MTMwNjUwMjQ5YzRiZg== Security check result: 0 Connecting to server; Authorisation process started; Furious Multipurpose Credits: 10 Done; Requesting data from server ! Wait please ... Done; Phone unlocked; Remove battery and cable; Log file saved to: LOG_15_07_2022_20_16_43.txt Time needed - 00:02:02 Sent from my SM-G973F using Tapatalk |
07-16-2022, 23:03 | #15843 (permalink) |
No Life Poster Join Date: Mar 2011 Location: dominican republic Age: 45
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 573 | TCL T767W UNLOCK DONE Using library Brom_DLL_v7.2116.0 Engine version 1.0.0.5790 Searching phone; (insert the USB cable in the powered off phone or insert the USB cable in the powered off phone while keeping volume down pressed) Phone detected (MediaTek USB Port_V1632 (COM11)) Preparing to start meta mode; Requesting authorization; Searching for debug port; (be sure drivers from support were installed) Meta mode entered; Baseband Chip: MT6833 Sw version: Hw Version: alps-mp-r0.mp3-V2.124_tct.tmo.r0mp3.k6833v1.64_P18 Baseband Chip: MT6833 Sw version: MOLY.NR15.R3.MP.V40.5.P57 Hw Version: TK_MD_HW Reading phone info; IMEI 1: 016062-00-078357-3 IMEI 2: 000000-00-000000-0 Checking server support license; Checking sml; OK; Checking sml ext; Phone unlocked; Remove battery and cable; Time needed - 00:01:06 Log file saved to: LOG_16_07_2022_18_01_49.txt |
07-16-2022, 23:21 | #15844 (permalink) |
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 573 | T-Mobile REVVL 5G UNLOCK DONE Using library Brom_DLL_v7.2116.0 Engine version 1.0.0.5790 Searching phone in normal mode; [connect the phone powered off with volume down and up pressed to the usb cable] Phone detected (MTK USB Port (COM22)) (Driver version: 2.0.0.6) Preparing to start flash mode; Preparing to open COM22 Device hw code: 0989 Device hw sub code: 8A00 Device hw version: CA00 Device sw version: 0000 Device secure boot: True Device serial link authorization: True Device download agent authorization: True Disabling watchdog timer; Done; Exploited; Sec code uploaded; Executed; Vodka time; Ready to party; Connecting; Downloading DA; Initializing; Rid: f3702f1e785eea445b96530f0efc6c50 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6833 [CA00, 00, 6833, 00] BB ID: QjZCQzk4RDM5QUQxMzcyRjE0NkYyRUZFMEQ3MTQ0N0E= HW_STORAGE_UFS: 0x51483948 0x43413435 0x444D4D50 0x00005241 [SIZE=0xEE6000000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x1D2000000 SIZE: 0xD127F8000 SPECIAL NOTE: If you are using windows 10 x64 be sure that the installed mtk driver version is 3.0.1504.0 . Any different drivers will create random read bugs on newer chipset phones. As usual the correct drivers come inside OTSMart archive inside the "usb_driver" folder Searching data; Contents saved to : D:\01-FURIOUS GOLD DONGLE\01-furious gold nuevos 10-04-2020 the-king-of-unlocking\OTSmart_v1.0.0.5790_LUiS_Edition\REVVL+_ BKP_REVVL V+ 5G_f3702f1e785eea445b96530f0efc6c50_16_07_2022_17_ 01_48.osp Re-init; Done; Searching phone in normal mode; [connect the phone powered off with volume down and up pressed to the usb cable] Phone detected (MTK USB Port (COM22)) (Driver version: 2.0.0.6) Preparing to start flash mode; Preparing to open COM22 Device hw code: 0989 Device hw sub code: 8A00 Device hw version: CA00 Device sw version: 0000 Device secure boot: True Device serial link authorization: True Device download agent authorization: True Disabling watchdog timer; Done; Exploited; Sec code uploaded; Executed; Vodka time; Ready to party; Connecting; Downloading DA; Initializing; Rid: f3702f1e785eea445b96530f0efc6c50 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6833 [CA00, 00, 6833, 00] BB ID: QjZCQzk4RDM5QUQxMzcyRjE0NkYyRUZFMEQ3MTQ0N0E= HW_STORAGE_UFS: 0x51483948 0x43413435 0x444D4D50 0x00005241 [SIZE=0xEE6000000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x1D2000000 SIZE: 0xD127F8000 SPECIAL NOTE: If you are using windows 10 x64 be sure that the installed mtk driver version is 3.0.1504.0 . Any different drivers will create random read bugs on newer chipset phones. As usual the correct drivers come inside OTSMart archive inside the "usb_driver" folder Phone unlocked; Remove battery and cable; Time needed - 00:22:58 |
The Following User Says Thank You to chipscell25 For This Useful Post: |
07-20-2022, 06:46 | #15845 (permalink) |
Guest
Posts: n/a
Member: | Using library Brom_DLL_v7.1813.3 Engine version 1.0.0.5790 Searching phone in normal mode; [connect the phone powered off with volume down and up pressed to the usb cable] Phone detected (MediaTek USB Port (COM19)) (Driver version: 3.0.1504.0) Preparing to start flash mode; Preparing to open COM19 Connecting; Downloading DA; Initializing; Rid: 5d80b90160190375a1e3796b886bf6fd Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6765 [CA00, 00, 6765, 00] BB ID: MjhBN0IwMjBCN0YyNjE1NzFENUI4MzcxNTYyMTRFNDg= HW_STORAGE_EMMC: 0x53030188 0x3233444C 0x3F0D5547 0x71C62692 [SIZE=0x73AC00000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x230000000 SIZE: 0x5064FBE00 Searching data; File not found; Phone unlocked; Remove battery and cable; Time needed - 00:00:01 Log file saved to: LOG_20_07_2022_09_08_00.txt bout not unlock |
07-30-2022, 11:19 | #15846 (permalink) |
Freak Poster Join Date: May 2007 Location: Meetiyagoda
Member: 504925 Status: Offline Thanks Meter: 55 | huawei y5 2018 DRA-L01 100% unlock Done FG OTSmart Using library Brom_DLL_v7.1813.3 Engine version 1.0.0.5490 Searching phone in normal mode; [connect the phone powered off with volume down and up pressed to the usb cable] Phone detected (MediaTek USB Port (COM25)) (Driver version: 3.0.1504.0) Preparing to start flash mode; Preparing to open COM25 Device hw code: 0699 Device hw sub code: 8A00 Device hw version: CA00 Device sw version: 0000 Device secure boot: True Device serial link authorization: True Device download agent authorization: False Disabling watchdog timer; Done; Exploited; Sec code uploaded; Executed; Vodka time; Ready to party; Connecting; Downloading DA; Initializing; Rid: 2d3c91462286e7ab0a6480eba322c593 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6739 [CA00, 00, 6739, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333645 0x44350442 0x698526F2 [SIZE=0x3A4A00000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0xEC000000 SIZE: 0x2B6DFBE00 Searching data; Phone unlocked; Remove battery and cable; Time needed - 00:00:01 Log file saved to: LOG_30_07_2022_15_41_28.txt |
The Following User Says Thank You to kalumetech For This Useful Post: |
09-09-2022, 01:45 | #15847 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Australia
Member: 177568 Status: Offline Thanks Meter: 147 | Optus X Start 3 (ZTE P501) unlock done Engine version 1.0.0.5127 Searching phone; For an successful connection do the following: 1. Connect the phone powered off with the battery inside to the usb cable Phone detected (@oem76.inf,%dvcdsc%;SCI USB2Serial) (Driver version: 1.5.6.1) Preparing to sync; Port opened [COM33]; Entering diagnostic mode; Done; Chip type: 0000:0000 Platform Version: MOCORTM_20A_W20.47.1_P25_Debug Project Version: sharklp BASE Version: 4G_MODEM_20A_W20.47.1_P25 HW Version: sc9832e_modem 01-11-2022 11:46:19 Build number: OPT_AU_R_Z3052OV1.0.0B06 Friendly Name: QTI0MjE4OTAxMEVDN0Q3NzI2MTUwQjhCRUREQTAzQTRFMDBFRj c4MQ== PHONE INFO: NONE BT ADDR: NONE SW IMEI[0]: 861170-06-xxxxxx-x SW IMEI[1]: 111111-11-111111-9 SW IMEI[2]: 867400-02-xxxxxx-x SW IMEI[3]: 867400-02-xxxxxx-x SIMLOCK FLAG: ON BKP saved to : BKP_000000-00-000000-0_861170-06-xxxxxx-x_00000000_9_09_2022_10_39_29.spd SIM_LOCK TYPE: 4 Analysing data; Please WAIT ! Starting auth; Getting data; Sending data; OK Check Done; PHONE ID: RDY2NkQ4NDUxNjNCRDU5ODNDNTBBQjE4MjJFNEIyQzM= Security check result: 0 Connecting to server; Authorisation process started; Furious Multipurpose Credits: 3 Done; Requesting data from server ! Wait please ... Done; Phone unlocked; Remove battery and cable; Log file saved to: LOG_9_09_2022_10_40_08.txt Time needed - 00:00:44 |
09-12-2022, 11:13 | #15848 (permalink) |
No Life Poster Join Date: Nov 2006 Location: colombo
Member: 399781 Status: Offline Thanks Meter: 94 | micromax x088+ password done Using library Brom_DLL_v5.1428.0 EMI Settings Loaded; Searching phone; (for some models keep SPACE or * (STAR) key pressed before inserting the cable) Phone detected (MediaTek USB Port_V1632 (COM7)) Preparing to start flash mode; Connecting; Downloading DA; Initializing; Requesting baudrate change; Done; DEVICE INFO: BB CHIP: MT6261_S0000 [CA00, 00, 6261, 05] MEMORY: Unnamed Flash [EF:70:16] [SIZE=0x00400000] FAT INFO: 0x00295000 SIZE: 0x00069000 Formatting file system now... Done; Time needed - 00:00:48 |
09-20-2022, 21:11 | #15849 (permalink) |
Freak Poster Join Date: Feb 2017 Location: D.R
Member: 2684440 Status: Offline Thanks Meter: 218 | LOGIC A5 UNLOCK DONE First in the world... Engine version 1.0.0.5130 Searching phone; For an successful connection do the following: 1. Power on the phone and power it off and leave the battery inside 2. Keep pressed firmly the boot key 3. Insert the usb cable inside the phone while keeping pressed the boot key Phone detected (@oem133.inf,%usbcomm_dl%;SPRD U2S Diag) (Driver version: 4.19.38.134) Preparing to sync; Port opened [COM101]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: Spreadtrum Boot Block version 1.2 Starting FDL2; FDL2 sent; Chip type: 6562:0001 Starting auth; HW IMEI : 000000-00-000000-0 Memory [CS0]: 00EF:0040:0016 - SIZE : 00400000 [000050DA389E6B10:0000] Reading phone info; PHONE INFO: NONE BT ADDR: 7D:60:2C:6D:3A:07 SW IMEI[0]:******** SW IMEI[1]:******** SW IMEI[2]: ******** SW IMEI[3]: ******** SIMLOCK FLAG: OFF FIXED NV BASE: 103B0000 Uncompressing; Done; Re-programming; FLS programmed; Done; Remove battery and cable; Log file saved to: LOG_20_09_2022_15_55_43.txt Time needed - 00:06:08 Last edited by .:hack3r2k:.; 09-20-2022 at 21:17. |
09-21-2022, 19:15 | #15850 (permalink) |
No Life Poster Join Date: Oct 2013 Location: Cote Ivoire ABJ,tvlle, LBJ.23 Age: 39
Member: 2041210 Status: Offline Thanks Meter: 541 | Unlock network Telstar E smart 2.1 with credit done Engine version 1.0.0.5130 Searching phone; For an successful connection do the following: 1. Power on the phone and power it off and leave the battery inside 2. Keep pressed firmly volume DOWN key 3. Insert the usb cable inside the phone while keeping pressed volume DOWN Phone detected (@oem95.inf,%usbcomm_dl%;SPRD U2S Diag) (Driver version: 4.19.38.134) Preparing to sync; Port opened [COM10]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: Spreadtrum Boot Block version 1.1 Starting FDL2; FDL2 sent; Starting auth; HW IMEI : 000000-00-000000-0 Analysing data; Please WAIT ! OK; PHONE INFO: NONE PHONE ID: MDA5MTExZTkwYTIyMGM4OQ== BT ADDR: FF:FF:FF:FF:FF:FF SW IMEI[0]: 869061-04-190198-6 SW IMEI[1]: 867400-02-031662-0 SW IMEI[2]: 867400-02-031663-8 SW IMEI[3]: 867400-02-031664-6 SIMLOCK FLAG: ON Reading NV; NV saved to : NV_000000-00-000000-0_869061-04-190198-6_98550000_21_09_2022_09_55_03.spd Gathering security data; Security check result: 0 Connecting to server; Authorisation process started; Furious Multipurpose Credits: 1 Done; Requesting data from server ! Wait please ... Re-programming; Security programmed; Sync NV; Done; Phone unlocked; Remove battery and cable; Log file saved to: LOG_21_09_2022_09_55_22.txt Time needed - 00:07:12 Engine version 1.0.0.5130 Searching phone; For an successful connection do the following: 1. Connect the phone powered off with the battery inside to the usb cable Phone detected (@oem95.inf,%usbcomm_dl%;SPRD U2S Diag) (Driver version: 4.19.38.134) Preparing to sync; Port opened [COM10]; Entering diagnostic mode; Done; Chip type: 0000:0000 Platform Version: MOCORTM_20A_W20.47.1_P11_Debug Project Version: sharklp BASE Version: 4G_MODEM_20A_W20.47.1_P11 HW Version: sc9832e_modem 05-26-2021 18:02:41 Build number: TLS_AU_Z3052TV1.0.0B11 Friendly Name: NzcwOTVDOTlDNEM0ODE5QkU2REQ1RkZBQzhCRUNDNjkwNUVFQT gzNA== PHONE INFO: NONE BT ADDR: NONE SW IMEI[0]: 861956-05-005111-0 SW IMEI[1]: 111111-11-111111-9 SW IMEI[2]: 867400-02-031663-8 SW IMEI[3]: 867400-02-031664-6 SIMLOCK FLAG: ON BKP saved to : BKP_000000-00-000000-0_861956-05-005111-0_00000000_21_09_2022_11_24_41.spd SIM_LOCK TYPE: 4 Analysing data; Please WAIT ! Starting auth; Getting data; Sending data; OK Check Done; PHONE ID: OEJBQ0ExMEE2MTNCQjFBRUUxQjIyRTIwNDY1QUFEQTc= Security check result: 0 Connecting to server; Authorisation process started; Furious Multipurpose Credits: 1 Done; Requesting data from server ! Wait please ... Done; Phone unlocked; Remove battery and cable; Log file saved to: LOG_21_09_2022_11_25_22.txt Time needed - 00:00:46 |
09-21-2022, 19:15 | #15851 (permalink) |
09-26-2022, 18:34 | #15852 (permalink) |
Freak Poster Join Date: Nov 2001 Location: Portugal Age: 43
Member: 7557 Status: Offline Thanks Meter: 26 | TCL T671H frp done As always Daniel is great person Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@oem229.inf,%qcomdevice90080%;Qualcomm HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM6 Connecting; Loading; Init; Port opened; Hello Received; MSM_ID: 0x001360E1 OEM_ID: 0x0042 MODEL_ID: 0x005D PK_HASH: 0C812BDBAC88BF2090C3F0CD82B9D35FBDA017E728E8800345 FFE8B8EBFBA200600909F6AB67AA08BC3A3ED39E1492D70C81 2BDBAC88BF2090C3F0CD82B9D35FBDA017E728E8800345FFE8 B8EBFBA200600909F6AB67AA08BC3A3ED39E1492D70C812BDB AC88BF2090C3F0CD82B9D35FBDA017E728E8800345FFE8B8EB FBA200600909F6AB67AA08BC3A3ED39E1492D7 BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory size 58,5 GB, target id 0000 IMEI: 355122660495899 PTH: 11 PTS: BB8 PROV_ID: T671H-2ALCWE12-1 SBTADDR: DC:9B6:B0:A7:54 SWIFIADDR: DC:9B6:8A:98:04 HS_PN: SAA2GC00C11C SSN: CLLC08CMNFE02FH Work id: 22021984 Done; Starting frp erase operation; Erasing; Done; FRP Removed ! Log file saved to: LOG_26_09_2022_18_30_00.txt Time needed - 00:00:56 |
10-11-2022, 21:18 | #15853 (permalink) |
Freak Poster Join Date: May 2007 Location: cameroon
Member: 516860 Status: Offline Sonork: chickiesmp Thanks Meter: 12 | After sitting around for about a year, i was helped remotely and my 3 pieces of alcatel 8084 got recovered. Thanks to hack3r2k |
The Following User Says Thank You to chickiesmp For This Useful Post: |
10-18-2022, 17:15 | #15854 (permalink) |
Banned Join Date: Nov 2010 Location: :::LONDON:::
Member: 1442994 Status: Offline Thanks Meter: 899 | Using library Brom_DLL_v7.1813.3 Engine version 1.0.0.5943 Searching phone; (insert the USB cable in the powered off phone or insert the USB cable in the powered off phone while keeping volume down pressed) or insert the USB cable in the powered off phone while keeping volume down+up pressed) Phone detected (MediaTek USB Port (COM9)) Preparing to start meta mode; Requesting authorization; Searching for debug port; (be sure drivers from support were installed) Meta mode entered; Baseband Chip: MT6765 Sw version: Hw Version: alps-mp-r0.mp1-V8.107.1_tct.tmo.r0mp1.k61v1.64.bsp_P10 Baseband Chip: MT6765 Sw version: MOLY.LR12A.R3.MP.V166.P21 Hw Version: TK_MD_L4_HW Reading phone info; IMEI 1: 016000-00-113977-5 IMEI 2: 000000-00-000000-0 Checking server support license; Checking sml; OK; Checking sml ext; OK; Checking nonce; Checking unlock_code; Checking sign; Calculating; Ok; Phone unlocked; Remove battery and cable; Time needed - 00:00:42 Log file saved to: LOG_18_10_2022_17_09_09.txt |
The Following User Says Thank You to AbDuLlAH kHaWaR For This Useful Post: |
10-21-2022, 06:15 | #15855 (permalink) |
Member: 399781 Status: Offline Thanks Meter: 94 | nokia 225 4g unlock done Engine version 1.0.0.5137 Searching phone; For an successful connection do the following: 1. Connect the phone powered off with the battery inside to the usb cable Phone detected (@oem235.inf,%usbcomm_dl%;SPRD U2S Diag) (Driver version: 4.19.38.135) Preparing to sync; Port opened [COM40]; Entering diagnostic mode; Done; Chip type: 9818:0001 Platform Version: MOCOR_20A_MP_W20.41.6_Release Software Version: 11.00.17.02 BASE Version: FM_BASE_20A_THIN_MODEM_W20.41.6 HW Version: UMS9117 buildtime:11-12-2020 15:14:13 Platform Version: MOCOR_20A_MP_W20.41.6_Release Software Version: 11.00.17.02 BASE Version: FM_BASE_20A_THIN_MODEM_W20.41.6 HW Version: UMS9117 Build number: buildtime:11-12-2020 15:14:13 Friendly Name: RThGOEREMEI1OEY3M0M0NENDODAzRkIxRTM5QUZCQUY5ODZFMU M3Mw== PHONE INFO: NONE BT ADDR: 7A:60:5A:CA:9E:CC SW IMEI[0]: 353192-11-223105-3 SW IMEI[1]: 353192-11-273105-2 SW IMEI[2]: 867400-02-031663-8 SW IMEI[3]: 867400-02-031664-6 SIMLOCK FLAG: ON BKP saved to : BKP_000000-00-000000-0_353192-11-223105-3_98180001_20_10_2022_11_21_45.spd SIM_LOCK TYPE: 4 Analysing data; Please WAIT ! OK; PHONE ID: MDA5MDRhNWIwODE1ODJiNw== Security check result: 0 Connecting to server; Authorisation process started; Furious Multipurpose Credits: 1 Done; Requesting data from server ! Wait please ... Done; Phone unlocked; Remove battery and cable; |
