01-17-2023, 06:47 | #15871 (permalink) |
No Life Poster Join Date: May 2006 Location: Sudan
Member: 281857 Status: Offline Thanks Meter: 214 | ZTE F286 user code successfully removed EMI Settings Loaded; COM opened ok; Press power and keep it pressed now ! Connecting; Downloading DA; Initializing; Requesting baudrate change; Done; DEVICE INFO: BB CHIP: MT6276W_S0101 [CB00, 101, 6276, 05] MEMORY: [Elite SMT] NAND_FM64D1G12A_5BAGE [C8:B1:80] [SIZE=0x08000000] FAT INFO: 0x02000000 SIZE: 0x06000000 Formatting file system now... Done; Time needed - 00:01:15 Log file saved to: LOG_17_01_2023_07_19_43.txt use OTZFlasher select ZTE T403 tick format file system connect done ! |
The Following User Says Thank You to Sudan-Mobiles For This Useful Post: |
01-25-2023, 22:50 | #15873 (permalink) |
Junior Member Join Date: Sep 2012 Location: Honduras
Member: 1806573 Status: Offline Sonork: tchinorck Thanks Meter: 3 | ZTE Blade a31 Lite Unlock Furious ZTE Blade a31 Lite Unlock Furious de claro honduras desbloqueo de red con Furious consume 1 credito... zte blade a31 lite furios.jpg Engine version 1.0.0.5175 Searching phone; For an successful connection do the following: 1. Connect the phone powered off with the battery inside to the usb cable Phone detected (@oem138.inf,%usbcomm_dl%;SPRD U2S Diag) (Driver version: 4.20.42.134) Preparing to sync; Port opened [COM52]; Entering diagnostic mode; Done; Chip type: 0000:0000 Platform Version: MOCORTM_20A_W20.47.1_P17_Debug Project Version: sharklp BASE Version: 4G_MODEM_20A_W20.47.1_P17 HW Version: sc9832e_modem 09-02-2021 19:06:04 Build number: CLA_LA_S_P932F21V1.0.0B09 Friendly Name: MTdBQTU2QjY0ODRENzcxNUNFQTBFRkU0QTI2Njk4MzVBRDFDRE YwRA== PHONE INFO: NONE BT ADDR: NONE SW IMEI[0]: 868651-05-101439-8 SW IMEI[1]: 111111-11-111111-9 SW IMEI[2]: 867400-02-031663-8 SW IMEI[3]: 867400-02-031664-6 SIMLOCK FLAG: ON BKP saved to : BKP_000000-00-000000-0_868651-05-101439-8_00000000_25_01_2023_15_38_48.spd SIM_LOCK TYPE: 4 Analysing data; Please WAIT ! Starting auth; Getting data; Sending data; OK Check Done; PHONE ID: MTExOEE1REJBMEUwQTIxRDM5REVGNzlERjgxOEQwM0Y= Security check result: 0 Connecting to server; Authorisation process started; Furious Multipurpose Credits: 8 Done; Requesting data from server ! Wait please ... Done; Phone unlocked; Remove battery and cable; Log file saved to: LOG_25_01_2023_15_39_29.txt Time needed - 00:00:45 |
The Following 3 Users Say Thank You to tchinorck For This Useful Post: |
02-20-2023, 17:34 | #15874 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Madeira Island Age: 47
Member: 85718 Status: Offline Thanks Meter: 449 | Zte Blade A530 FRP remove Using library Brom_DLL_v7.1813.3 Engine version 1.0.0.5464 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek USB Port (COM9)) (Driver version: 3.0.1504.0) Preparing to start flash mode; Preparing to open COM9 Connecting; Downloading DA; Initializing; Rid: 2f12b98cd7d4e6a6c789ecc7274ba71d Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6739 [CA00, 00, 6739, 00] HW_STORAGE_EMMC: 0x51000115 0x4D333645 0x4DFD0342 0x07A586DE [SIZE=0x3A4A00000] PROVIDER: N/A USRDATA INFO: 0x120000000 SIZE: 0x282DFBE00 Factory Reset Protection successfully removed ! Time needed - 00:00:00 Log file saved to: LOG_20_02_2023_16_24_17.txt |
The Following User Says Thank You to ct3im For This Useful Post: |
02-21-2023, 16:17 | #15875 (permalink) |
Registered User Join Date: Apr 2015 Location: Cuba
Member: 2381725 Status: Offline Thanks Meter: 126 | TCL 5087z Unlock sucess latest Security Path!!! Using library Brom_DLL_v7.1813.3 Engine version 1.0.0.5995 Searching phone; (insert the USB cable in the powered off phone or insert the USB cable in the powered off phone while keeping volume down pressed) or insert the USB cable in the powered off phone while keeping volume down+up pressed) Phone detected (MediaTek USB Port_V1632 (COM11)) Preparing to start meta mode; Requesting authorization; Searching for debug port; (be sure drivers from support were installed) Meta mode entered; Baseband Chip: MT6765 Sw version: Hw Version: alps-mp-r0.mp1-V8.107.1_tct.tmo.r0mp1.k61v1.64.bsp_P14 Baseband Chip: MT6765 Sw version: MOLY.LR12A.R3.MP.V166.P26 Hw Version: TK_MD_L4_HW Reading phone info; IMEI 1: 016000-00-000000-0 IMEI 2: 000000-00-000000-0 Checking server support license; Checking sml; OK; Checking sml ext; OK; Checking nonce; Checking unlock_code; Checking sign; Calculating; Ok; Phone unlocked; Remove battery and cable; Time needed - 00:00:49 |
The Following 2 Users Say Thank You to Emsel For This Useful Post: |
02-23-2023, 17:44 | #15877 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Africa.uganda
Member: 562975 Status: Offline Sonork: better tomorow Thanks Meter: 247 | Alcatel 9015B done Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@oem173.inf,%vendordevice90080%;Qualcomm HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM7 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory size 7.3 GB, target id 8909 IMEI: 0147320006****-0 PTH: 03 PTS: RE4 PROV_ID: 9015B-2ALZCA1 SBTADDR: 4C:4E:03:10:48:A3 SWIFIADDR: 4C:4E:03:04:AF:9E HS_PN: SAA1FDBAC10C SSN: Z9KC07CEOFA01NL Bruteforcing data; This operation can take up to 30 minutes !!! Done; Work id: 09E8D39D Done; Stype: 00000001 SECURITY: X5R0UD00CL00 Size: 000002B9 Backup saved to: 014732000*****-0 Backup file(s) removed; Unlocking; SIM_LOCK REMOVED ! Log file saved to: LOG_23_02_2023_19_29_01.txt Time needed - 00:18:35 |
02-27-2023, 21:44 | #15878 (permalink) |
Freak Poster Join Date: Jan 2010
Member: 1219775 Status: Offline Thanks Meter: 46 | ZTE Blade A31 Unlocked successfully Engine version 1.0.0.5221 Searching phone; For an successful connection do the following: 1. Connect the phone powered off with the battery inside to the usb cable Phone detected (@oem176.inf,%usbcomm_dl%;SPRD U2S Diag) (Driver version: 2.0.0.114) Preparing to sync; Port opened [COM24]; Entering diagnostic mode; Done; Chip type: 0000:0000 Platform Version: MOCORTM_20A_W20.47.1_P34_Debug Project Version: sharkl3_pub BASE Version: 4G_MODEM_20A_W20.47.1_P34 HW Version: sc9863A_modem 11-17-2022 20:28:35 Build number: FLOW_JM_P963F70V1.0.0B07 Friendly Name: OEIwMkE4OUM0OEExQzg0NjJGRkE2N0JDQjlERkY1MUEwOEY4NE M5RQ== PHONE INFO: NONE BT ADDR: NONE SW IMEI[0]: 864210-05-758413-8 SW IMEI[1]: 867400-02-031662-0 SW IMEI[2]: 867400-02-031663-8 SW IMEI[3]: 867400-02-031664-6 SIMLOCK FLAG: ON BKP saved to : BKP_000000-00-000000-0_864210-05-758413-8_00000000_27_02_2023_15_35_06.spd SIM_LOCK TYPE: 4 Analysing data; Please WAIT ! Starting auth; Getting data; Sending data; OK Check Done; PHONE ID: ODFDNjMxQTU1Qjc4OTA2QTZBNkREMzdCQUZBRTI4MkY= Security check result: 0 Connecting to server; Authorisation process started; Furious Multipurpose Credits: 5 Done; Requesting data from server ! Wait please ... Done; Phone unlocked; Remove battery and cable; Log file saved to: LOG_27_02_2023_15_35_53.txt Time needed - 00:00:52 |
03-06-2023, 09:14 | #15879 (permalink) |
No Life Poster Join Date: Dec 2012 Location: SRI LANKA
Member: 1857049 Status: Offline Sonork: 100.1627774 Thanks Meter: 208 | Zte t503 unlock done Engine version 1.0.0.5223 Searching phone; For an successful connection do the following: 1. Connect the phone powered off with the battery inside to the usb cable Phone detected (@oem134.inf,%usbcomm_dl%;SPRD U2S Diag) (Driver version: 4.20.42.138) Preparing to sync; Port opened [COM41]; Entering diagnostic mode; Done; Chip type: 0000:0000 Platform Version: MOCORTM_18A_W19.08.2_P15.02_Debug Project Version: sharkle_Smart_Phone BASE Version: FM_BASE_18A_W19.08.2_P15.02 HW Version: sc9832e_modem 11-23-2019 17:26:53 Build number: T503V1.0.0B14 Friendly Name: QjVGQzc1MUZCRjJDRTRCMUI2NzUzMDgzNTMzNkQ3QTI1NEE3Qj BEQQ== PHONE INFO: NONE BT ADDR: FF:FF:FF:FF:FF:FF SW IMEI[0]: 869766-04-022019-2 SW IMEI[1]: 867400-02-031662-0 SW IMEI[2]: 867400-02-031663-8 SW IMEI[3]: 867400-02-031664-6 SIMLOCK FLAG: ON BKP saved to : BKP_000000-00-000000-0_869766-04-022019-2_00000000_6_03_2023_13_33_48.spd SIM_LOCK TYPE: 4 Analysing data; Please WAIT ! Starting auth; Getting data; Sending data; OK Check Done; PHONE ID: RDgyN0U3RUFCRTJCNDcyOTMzREFCM0YzMjM2NEY0ODA= Security check result: 0 Connecting to server; Authorisation process started; Furious Multipurpose Credits: 2 Done; Requesting data from server ! Wait please ... Done; Phone unlocked; Remove battery and cable; |
The Following User Says Thank You to samindapowerson For This Useful Post: |
03-16-2023, 11:52 | #15880 (permalink) |
Freak Poster Join Date: Feb 2013 Location: Sudan-Khartoum
Member: 1890557 Status: Offline Thanks Meter: 9 | nokia 6310 ta-1400 REMOVE SECURITY CODE done Engine version 1.0.0.5175 Searching phone; For an successful connection do the following: 1. Power on the phone and power it off and leave the battery inside 2. Keep pressed firmly the boot key 3. Insert the usb cable inside the phone while keeping pressed the boot key Phone detected (@oem0.inf,%usbcomm_dl%;SPRD U2S Diag) (Driver version: 2.0.0.131) Preparing to sync; Port opened [COM15]; Mobile type: Spreadtrum Boot Block version 1.2 Connected; Starting; FDL sent; Syncing; Loader version: Spreadtrum Boot Block version 1.2 Starting FDL2; FDL2 sent; Chip type: 6562:0001 Starting auth; HW IMEI : 000000-00-000000-0 Memory [CS0]: 00EF:0060:0018 - SIZE : 01000000 [00009256429B06B6:0000] Reading phone info; PHONE INFO: 12.00.11.00_IM23POS00BH00 BT ADDR: F6:4F:6E:67:29:E0 SW IMEI[0]: 359952-********-* SW IMEI[1]: 359952-********-* SW IMEI[2]: 358570-********-* SW IMEI[3]: 910575-********-* SIMLOCK FLAG: OFF FIXED NV BASE: 10CB0000 Searching fs start and end addr; Formatting 10CB8000-11000000; Starting format; Formatted; Done; Remove battery and cable; Log file saved to: LOG_8_03_2023_16_31_21.txt Time needed - 00:05:12 |
03-18-2023, 17:45 | #15881 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Central America
Member: 746276 Status: Offline Sonork: 100.1609752 Thanks Meter: 675 | Wiko U316AT locked to Assurance Wireless, successfully unlocked. |
The Following User Says Thank You to netmobile For This Useful Post: |
03-23-2023, 15:13 | #15882 (permalink) |
No Life Poster Join Date: Sep 2009 Location: 9ja
Member: 1110430 Status: Offline Thanks Meter: 104 | Qubo password reset GENERIC METHOD 3 Engine version 1.0.0.5221 Searching phone; For an successful connection do the following: 1. Connect the phone powered off with the battery inside to the usb cable Phone detected (@oem55.inf,%usbcomm_dl%;SPRD U2S Diag) (Driver version: 4.20.42.134) Preparing to sync; Port opened [COM77]; Entering diagnostic mode; Done; Chip type: 0000:0000 Platform Version: MOCORTM_17C_W18.41.3_P21.01_Debug Project Version: pike2_pub BASE Version: FM_BASE_17C_W18.41.3_P21.01 HW Version: sc7731e_modem 08-03-2019 15:29:34 Build number: P6-user 9 P00610 1566276814 release-keys Friendly Name: MDYzQjRCOUE0RjUwNDBDQjg4QkNFRjIzMDcxNENFODI1M0Y5Qj UzOA== PHONE INFO: NONE BT ADDR: FF:FF:FF:FF:FF:FF SW IMEI[0]: 869105-02-815437-2 SW IMEI[1]: 869105-02-815438-0 SW IMEI[2]: 867400-02-031663-8 SW IMEI[3]: 867400-02-031664-6 SIMLOCK FLAG: OFF Starting factory reset; Modem imei: 869105028154372 Working; Done ! Log file saved to: LOG_23_03_2023_14_56_58.txt Time needed - 00:00:13 |
04-12-2023, 15:41 | #15885 (permalink) |
No Life Poster Join Date: Oct 2005 Location: TITI 2002 SERVIS CELULAR PG/AL
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | 2038X-3BTWGB1 Phone unlocked Engine version 1.0.0.5136 Searching phone; For an successful connection do the following: 1. Remove battery and usb cable 2. Insert the usb cable in the phone 3. Keep pressed the boot key and insert the battery Phone detected (@oem100.inf,%usbcomm_dl%;SPRD U2S Diag) (Driver version: 2.0.0.131) Preparing to sync; Port opened [COM22]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: Spreadtrum Boot Block version 1.1 Starting FDL2; FDL2 sent; Chip type: 7702:0000 Starting auth; Memory NAND [CS0]: 0098:00B1 - SIZE : 08000000 EFUSE HASH: 0000000000000000000000000000000000000000 EFUSE LOCK STATUS: 000E 000E 000E 000E 000E HW IMEI : 000000-00-000000-0 Reading phone info; PHONE INFO: 2038X-3BTWGB1 BT ADDR: 03:65:59:5A1:84 SW IMEI[0]: 355735-08-956211-2 SW IMEI[1]: 352751-01-265893-0 SW IMEI[2]: 358570-01-010389-3 SW IMEI[3]: 910575-60-140046-8 SIMLOCK FLAG: ON FIXED NV BASE: 40040000 Reading NV; NV saved to : NV_000000-00-000000-0_355735-08-956211-2_77020000_12_04_2023_16_33_58.spd IMEI: 355735-08-956211-2 UNLOCK CODE: 1117639296864125 Re-programming; NV programmed; Done; Phone unlocked; Remove battery and cable; Log file saved to: LOG_12_04_2023_16_34_44.txt Time needed - 00:01:13 |
The Following 2 Users Say Thank You to genci titi 2002 For This Useful Post: |
