Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > FuriousGold
FuriousGold FuriouS GOLD Support Area | Powered by FuriousTeam
Old 03-20-2009, 13:54   #286 (permalink)
Member: 317043
Thanks Meter: 25
MD-2 New Firmware unlock OK
MD-2 New Firmware unlock with success:
Software engine version: 1.0.0.1726
Searching phone ...
MODEL : QCOM SERIES 2
COMPILED DATE : Dec 27 2007 15:39:00
RELEASE DATE : Apr 13 2007 15:00:00
FIRMWARE INFO : P621C1V1.1.0B06
IMEI : 35xxxxxxxxxxxxxxxxxxxx
BLUETOOTH ADDR : F2 9B 7C 73 1E 00
MEMORY ID : 00AD:0078
MEMORY NAME : hynix_hyg0sgh0mf3
MEMORY INFO : 0200:0020:133B
INIT NAND ROUTINES;
NAND INIT MADE;
PROCESS STARTED;
READING;
ERASING;
WRITING;
UNLOCK CODE: 1449991912312139
ENTER USING: *983*865625#
RESET !
Time needed - 00.00.06
The Following 2 Users Say Thank You to darkinside For This Useful Post:
Old 03-21-2009, 09:53   #287 (permalink)
MGT SOFTWARE's Avatar
Member: 53263
Sonork: gsm master
Thanks Meter: 326
Vodafone 830 huawei unlock successfully
Your Becoming the first in the work again as usually thank you very much
Searching phone ...
MODEL : M6275AOEMS
Download mode entered ...
Loading bootloader ...
Requesting random data ...
Completed ...
Memory Info: 00EC:0078
Nand init done;
Reading;
Imei : 35426800000000000000000
Reading;
SP saved to: SP_35426---------_A22_11.46.53_21.03.2009_HUAWEI.bin
Erasing;
Writing;
Unlocked !
Checking for password presence ...
Found 0 password(s) !
Done !
Time needed - 00:00:59
The Following User Says Thank You to MGT SOFTWARE For This Useful Post:
Old 03-21-2009, 11:41   #288 (permalink)
Member: 200548
Thanks Meter: 104
Thumbs up ku250 unlock sucessfull
Searching phone ...
MODEL : U250
COMPILED DATE : May 19 2007 02:54:00
RELEASE DATE : May 19 2007 14:00:00
FIRMWARE INFO : U250-MSM6245-V10a-MAY-19-2007-XX
IMEI : 35638501064138-4
BLUETOOTH ADDR : 34 BB 14 62 1C 00
MEMORY ID : 00AD:0076
MEMORY NAME : hynix_hyc0ueh0mf3p
MEMORY INFO : 0200:0020:0996
INIT NAND ROUTINES;
NAND INIT MADE;
READING SECURITY AREA;
READING SEC DATA;
SECURITY TESTS PASSED !
UNLOCKING PASSED !
LOCK HASH WRITTEN;
UNLOCKED !
Time needed - 00:00:07
thanx furious team
Old 03-21-2009, 19:04   #289 (permalink)
Member: 271980
Sonork: 100.1573370
Thanks Meter: 227
UnlocK ZTE momoDESING Successfully with Latest Update
Searching phone ...
COMPILED DATE : Sep 5 2007 22:23:00
FIRMWARE INFO : P621C1V1.1.0B01
IMEI : 357144010xxxxx-4
BLUETOOTH ADDR : 48 EE 17 EB 15 00
INIT NAND ROUTINES;
NAND INIT MADE;
PROCESS STARTED;
READING;
ERASING;
WRITING;
UNLOCK CODE: 9419129913095933
RESET !
Time needed - 00:00:06
Use Test Sim And change Pc Connection to USB
Old 03-22-2009, 07:00   #290 (permalink)
mianjabbar's Avatar
Member: 481915
Sonork: 100.1604233
Thanks Meter: 476
Vodafone 902T by Toshiba successfull unlock
VODAFONE 902T BY TOSHIBA SUCCESSFULL UNLOCK
here is log:
Searching phone...
Model: TOSHIBA
imei: 3556200071XXXXX
Working...Please Waite!
Phone unlocked!
Time needed - 00:00:09
Step by Step instructions:
1- Use original USB cable, which comes with phone or NEC N8
cable (Sharp unlock cable GX15,GX25 etc.)
2- Power ON phone and Connect USB cable to phone. Wait until Windows will find phone's usb & modem drivers and will finish drivers installation. Install USB & modem drivers "TS803, T904, T902 same"
WARNING : Drivers and software works only on Windows XP,Windows 2000.
3- Go to "Start"-Settings"-"Control Panel"-"System"-"Hardware"-"Device Manager"-"Modems" and look what ComPort is selected for "Vodafone 902T modem". Right click with mouse at "Vodafone 902T modem" in the opened submnenu select "Properties"
- in the "Properties" submenu select "Modem' Advance Port setting"
(it is good if usb port# is between 1-16).
5- Start software and select same ComPort. Press "Do Job"
here you can perform two types lock, but one in one step.
Step1 - security code (by checking check box SEC)
Step2 - network lock (no need checking check box of SEC)
6- WARNING : Software can't recognize phone if user code is set, in this case phone shows on display "Phone lock". For working with software you need to perform first step of unlock, dissable phone lock, try main code "9999" or ask phone's owner what phone code is set.
mianlinks
Old 03-22-2009, 07:47   #291 (permalink)
Registered User
Member: 650213
Sonork: 100.1581739:333
Thanks Meter: 133
unlock successfuly KF600
Press power on !
Starting communication ...
Platform: S-Gold3 ...
Preloader sent ....
Loader sent ....
CODE: 92736888
Power on phone with original sim.
Type 2945#*71001# and enter code.
Done !
Time needed - 00:00:13
FURIOUS ALWAYS GREAT
Old 03-22-2009, 09:59   #292 (permalink)
FullFLASHgSMPH's Avatar
Member: 161739
Sonork: 100.1584054
Thanks Meter: 3,338
ku250 italy
Software engine version: 1.0.0.1719
Searching phone ...
MODEL : U250
IMEI : 35638501032440-3
BLUETOOTH ADDR : 7E 8B 12 62 1C 00
INIT NAND ROUTINES;
NAND INIT MADE;
READING SEC DATA;
UNLOCKING PASSED !
LOCK HASH WRITTEN;
UNLOCKED !
Time needed - 00:00:04
Old 03-22-2009, 11:51   #293 (permalink)
hasnain's Avatar
Member: 265626
Sonork: 100.1591486
Thanks Meter: 2,982
MomoDesign MD-1 unlocked succesfully
Searching phone ...
MODEL : QCOM SERIES 1
COMPILED DATE : Oct 16 2006 10:23:00
RELEASE DATE : Aug 3 2006 00:00:00
FIRMWARE INFO : M6250D-VMSY-6.2.9343T
IMEI : 35209101513835-0
BLUETOOTH ADDR : 70 5E 14 40 12 00
MEMORY ID : 00EC:0036
MEMORY NAME : samsung_k9f1208
MEMORY INFO : 0200:0020:08C0
INIT NAND ROUTINES;
NAND INIT MADE;
PROCESS STARTED;
READING;
ERASING;
WRITING;
RESET !
Time needed - 00:00:30
Old 03-22-2009, 14:28   #294 (permalink)
SkyMobile05's Avatar
Member: 508860
Sonork: 1613186
Thanks Meter: 224
Smile Amoi MD-1 unlock done
Searching phone ...
IMEI : 35209101016821-2
BLUETOOTH ADDR : 42 FA 15 40 12 00
INIT NAND ROUTINES;
NAND INIT MADE;
PROCESS STARTED;
READING;
ERASING;
WRITING;
RESET !
unlock done thanx to furious
Old 03-22-2009, 14:37   #295 (permalink)
Member: 898887
Sonork: ramazoti
Thanks Meter: 210
succssefuly unlock Huawei u3300
succssefuly unlock Huawei u3300 thank you Mr heker for your help
MODEL : M6275AOEMS
Completed ...
Nand init done;
Reading;
Imei : 35343602032567-5
Reading;
SP saved to: SP_35343602032567_A1C_14.28.37_22.03.2009_HUAWEI.b in
Erasing;
Writing;
Unlocked !
Done !
Time needed - 00:00:58
Old 03-22-2009, 16:16   #296 (permalink)
SOHAIL BASHARAT's Avatar
Member: 748880
Thanks Meter: 1,705
UNLOCK DONE U300 BY FURIOUS GOLD
MODEL : U300
COMPILED DATE : Jun 16 2006 08:22:00
RELEASE DATE : Jun 16 2006 17:00:00
FIRMWARE INFO : U300-MSM6250A-V10c-JUN-16-2006-H3G-DU
IMEI : 35928800049412-8
BLUETOOTH ADDR : 41 22 4C 56 12 00
MEMORY ID : 0098:0076
MEMORY NAME : toshiba_ty90009800cogg
MEMORY INFO : 0200:0020:0900
LOADING INIT DATA;
RESETTING PHONE !
WAITING FOR PHONE TO POWER ON 30 SEC;
PHONE ONLINE;
SW VERSION: [OK] MODULE ERROR
IMEI: [OK] 35928800049412800
BLUETOOTH ADDR: [OK] 41224C561200
PLAYING MUSIC ... WAIT;
DOING CONFIG;
INJECTING VODKA;
INJECTING JUICE;
DRINKING;
DANCING;
STAT: ON
NAND UNLOCK DONE;
PROCESS STARTED;
READING;
ERASING;
WRITING;
READING;
ERASING;
WRITING;
UNLOCKED !
Time needed - 00:01:34
The Following 4 Users Say Thank You to SOHAIL BASHARAT For This Useful Post:
Old 03-22-2009, 20:26   #297 (permalink)
Registered User
Member: 350835
Thumbs up successfullyflashing lg kp500
yesterday i successfully flashed lg kp500
but unexpected no more information in furious support than " read code "
is furious support stop now ?
why we must look for our work in way we wonot it ?
i made it for free
and from direct cable
no more credits no more waiting for two hours to unlock or flashing
and i said that in order to see the furious team the best
because i still think
you are the best
please donot let me think at the contract ...............
Old 03-24-2009, 03:08   #298 (permalink)
Member: 161739
Sonork: 100.1584054
Thanks Meter: 3,338
tu500s full unlock
4 seconds done
Searching phone ...
MODEL : TU500
COMPILED DATE : Sep 19 2007 16:41:00
RELEASE DATE : Aug 28 2006 16:15:00
FIRMWARE INFO : TU500-MSM6275-V10b-SEP-19-2007-TEL-AU
IMEI : 35616301191401-3
BLUETOOTH ADDR : 00 1F E3 CF 3D F3
MEMORY NAME : toshiba_ty90009c00sogg
MEMORY SIZE : 38MB
PERFORMING OPERATION ...
READING NV ...
READY...
SW VERSION: [OK] TU500FL-V10b-01-505-01-00-00-00-SEP-19-2007+0
IMEI: [OK] 35616301191401300
BLUETOOTH ADDR: [OK] F33DCFE31F00
FORMAT: [OK] IDDE OK
br..............
Old 03-24-2009, 22:04   #299 (permalink)
pichi_balea's Avatar
Member: 668010
Thanks Meter: 117
Thumbs up unlock amoi-md1
thanx furious team
Old 03-25-2009, 06:49   #300 (permalink)
Cheater -Don't Deal with him-
Member: 283204
Sonork: 100.1577140
Thanks Meter: 1,098
again succsesfully unlock lg u880 with furious gold
here is log:
Searching phone ...
MODEL : U880
COMPILED DATE : Feb 20 2006 09:02:00
RELEASE DATE : Jul 3 2005 16:00:00
FIRMWARE INFO : U880-MSM6250-V10b_wm-FEB-08-2006-H3G-UK
IMEI : 35705000582190-9
BLUETOOTH ADDR : 8E A1 08 56 12 00
MEMORY ID : 0098:0079
MEMORY NAME : toshiba_ty9000ac10aobg
MEMORY INFO : 0200:0020:1980
LOADING INIT DATA;
RESETTING PHONE !
PHONE ONLINE;
IMEI: [OK] 35705000582190900
BLUETOOTH ADDR: [OK] 8EA108561200
DOING CONFIG;
INJECTING VODKA;
INJECTING JUICE;
DRINKING;
DANCING;
STAT: OFF
NAND UNLOCK DONE;
PROCESS STARTED;
READING;
ERASING;
WRITING;
READING;
ERASING;
WRITING;
UNLOCKED !
Time needed - 00:01:41
The Following 3 Users Say Thank You to Harkishan singh For This Useful Post:
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.23771 seconds with 10 queries
