06-13-2009, 07:02 | #706 (permalink) |
Cheater -Don't Deal with him- Join Date: Feb 2009 Location: Gsx Check Source Age: 35
Member: 975047 Status: Offline Thanks Meter: 330 | Software engine version: 1.0.0.2440 Searching phone ... MODEL : U310 COMPILED DATE : Oct 12 2006 14:55:00 RELEASE DATE : May 9 2006 17:00:00 FIRMWARE INFO : U310-MSM6250A-V10a-OCT-12-2006-H3G-IT IMEI : 35281801084440-4 BLUETOOTH ADDR : B5 E2 3A A1 19 00 MEMORY ID : 0098:0076 MEMORY NAME : toshiba_ty90009800cogg MEMORY INFO : 0200:0020:0900 LOADING INIT DATA; RESETTING PHONE ! WAITING FOR PHONE TO POWER ON 30 SEC; PHONE ONLINE; SW VERSION: [OK] MODULE ERROR IMEI: [OK] 35281801084440400 BLUETOOTH ADDR: [OK] B5E23AA11900 PLAYING MUSIC ... WAIT; DOING CONFIG; INJECTING VODKA; INJECTING JUICE; DRINKING; DANCING; STAT: ON NAND UNLOCK DONE; PROCESS STARTED; READING; ERASING; WRITING; READING; ERASING; WRITING; UNLOCKED ! Time needed - 00:01:59 U250 Done Software engine version: 1.0.0.2440 Searching phone ... MODEL : KU250 COMPILED DATE : Aug 14 2007 00:26:00 RELEASE DATE : Jun 28 2007 15:00:00 FIRMWARE INFO : KU250-MSM6245-V10c-JUN-28-2007-XX IMEI : 35638501223179-6 BLUETOOTH ADDR : 7A 94 45 62 1C 00 MEMORY ID : 00AD:0076 MEMORY NAME : hynix_hyc0ueh0mf3p MEMORY INFO : 0200:0020:0996 INIT NAND ROUTINES; NAND INIT MADE; READING SECURITY AREA; READING SEC DATA; SECURITY TESTS PASSED ! UNLOCKING PASSED ! LOCK HASH WRITTEN; UNLOCKED ! Time needed - 00:00:07 |
06-13-2009, 08:22 | #707 (permalink) |
Member: 975047 Status: Offline Thanks Meter: 330 | F230 Done Software engine version: 1.0.0.2440 Searching phone ... MODEL : QCOM SERIES 2 COMPILED DATE : Jun 22 2007 10:42:00 RELEASE DATE : Jun 20 2007 12:00:00 FIRMWARE INFO : F230 3.1 IMEI : 35561601015657-2 BLUETOOTH ADDR : 3C F4 15 EB 15 00 MEMORY ID : 00EC:0078 MEMORY NAME : samsung_k91g08 MEMORY INFO : 0200:0020:132D INIT NAND ROUTINES; NAND INIT MADE; PROCESS STARTED; READING; ERASING; WRITING; UNLOCK CODE: 9243939912070399 ENTER USING: *983*865625# RESET ! Time needed - 00:00:08 |
06-13-2009, 15:23 | #709 (permalink) |
No Life Poster Join Date: Mar 2001 Location: ALBANIA(Tirana) Age: 51
Member: 3617 Status: Offline Thanks Meter: 580 | Blackberry 8800 T Mobile Searching for usb device ... Reading info ... IMEI: 354672016250621 Calculating ... MEP2 CODE: 3071769745655922 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:14 |
06-13-2009, 15:35 | #710 (permalink) |
Member: 3617 Status: Offline Thanks Meter: 580 | Blackberry 8310 AT&T usa Searching for usb device ... Reading info ... IMEI: 355085020730026 Calculating ... MEP2 CODE: 7197775820802031 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:15 |
06-13-2009, 16:40 | #711 (permalink) |
Member: 975047 Status: Offline Thanks Meter: 330 | 9500 Storm Done Searching for usb device ... Reading info ... IMEI: 352109032626106 Calculating ... MEP2 CODE: 8042672550218057 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:14 |
06-13-2009, 22:59 | #712 (permalink) |
Banned Join Date: Sep 2003 Location: Cambodia
Member: 39069 Status: Offline Sonork: 100.1606677 Thanks Meter: 190 | I laso unlocked done blackberry 9530: Searching for usb device ... Reading info ... IMEI: 352109035103525 Calculating ... MEP2 CODE: 4510122705100755 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:11 |
06-14-2009, 13:05 | #713 (permalink) |
No Life Poster Join Date: Nov 2008 Location: tunisia
Member: 898887 Status: Offline Sonork: ramazoti Thanks Meter: 210 | vodafone 710 done Searching phone ... MODEL : D618 V1.0 Download mode entered ... Loading bootloader ... Requesting random data ... Completed ... Init nand made; Reading; Imei : 35197901241512-1 Unlock code: 2352395615611620 Done ! Time needed - 00:00:59 |
06-14-2009, 14:02 | #714 (permalink) |
Freak Poster Join Date: Mar 2006 Location: egypt
Member: 243316 Status: Offline Sonork: 100.1574360 Thanks Meter: 25 | U370 disney mobile successfully unlocked Software engine version: 1.0.0.2440 Searching phone ... MODEL : U370 COMPILED DATE : Oct 15 2007 06:42:00 RELEASE DATE : May 17 2007 14:00:00 FIRMWARE INFO : U370W-MSM6245-V10a-OCT-15-2007-XX IMEI : 35839XXXXXXXXX-9 BLUETOOTH ADDR : FD 2C 01 75 1E 00 MEMORY ID : 0098:00C1 MEMORY NAME : toshiba_ty9000a800jogg MEMORY INFO : 0800:0040:0308 INIT NAND ROUTINES; NAND INIT MADE; READING SECURITY AREA; READING SEC DATA; SECURITY TESTS PASSED ! UNLOCKING PASSED ! LOCK HASH WRITTEN; UNLOCKED ! Time needed - 00:00:08 Thanx MAAS |
06-15-2009, 06:34 | #715 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Kotla arab ali khan Age: 57
Member: 623703 Status: Offline Sonork: 100.1614330 Thanks Meter: 439 | Cb630 at&t 2 pcs unlocked FG Software engine version: 1.0.0.2440 Searching phone ... MODEL : CB630 COMPILED DATE : Oct 16 2008 15:11:00 RELEASE DATE : Sep 18 2008 10:00:00 FIRMWARE INFO : CB630-MSM41204009-V10d-OCT-16-2008-ATT-US IMEI : 01157800018296-6 BLUETOOTH ADDR : 34 1C B7 FB 21 00 MEMORY ID : 0098:00CA MEMORY NAME : toshiba_tya000bc00dogg MEMORY INFO : 0800:0040:0690 INIT NAND ROUTINES; NAND INIT MADE; READING SECURITY AREA; READING SEC DATA; SECURITY TESTS PASSED ! UNLOCKING PASSED ! LOCK HASH WRITTEN; UNLOCKED ! Time needed - 00:00:09 |
06-15-2009, 09:54 | #716 (permalink) | ||
Freak Poster Join Date: Dec 2006 Location: indonesia
Member: 412834 Status: Offline Thanks Meter: 215 | succes unlock 2 huawei U526 B-MOBILE BRUNEI but Quote:
how to repair this??????? thx to FG team | ||
06-15-2009, 12:55 | #718 (permalink) |
Freak Poster Join Date: Jul 2008
Member: 817022 Status: Offline Thanks Meter: 78 | Blackberry 8300 / 8330 unlock done Greetings ....at last i've done it with my new furious box... newly activated... thanks to livewirecebu, mr. jay r treze, and ronald deang http://i465.photobucket.com/albums/r...eid/8300bb.jpg http://i465.photobucket.com/albums/r...eid/8830bb.jpg |
The Following User Says Thank You to blood rAyne For This Useful Post: |
06-16-2009, 10:31 | #719 (permalink) |
Cheater -Don't Deal with him- Join Date: May 2006 Age: 38
Member: 283204 Status: Offline Sonork: 100.1577140 Thanks Meter: 1,098 | <<<<Succsessfully unlock done lg cu920 with furious gold>>>> Here is log: Software engine version: 1.0.0.2440 Searching phone ... MODEL : CU920 COMPILED DATE : May 6 2008 10:38:00 RELEASE DATE : Jan 4 2008 15:00:00 FIRMWARE INFO : TU915-MSM4090201D-V10e-MAY-06-2008-RW-CA IMEI : 35497002043941-6 BLUETOOTH ADDR : CC 7F 31 A9 22 00 MEMORY ID : 0098:00CA MEMORY NAME : toshiba_tya000bc00dogg MEMORY INFO : 0800:0040:0696 INIT NAND ROUTINES; NAND INIT MADE; READING SECURITY AREA; READING SEC DATA; SECURITY TESTS PASSED ! UNLOCKING PASSED ! LOCK HASH WRITTEN; UNLOCKED ! Time needed - 00:00:06 Br: Harkishan |
The Following User Says Thank You to Harkishan singh For This Useful Post: |
06-16-2009, 16:08 | #720 (permalink) |
No Life Poster Join Date: May 2007 Age: 37
Member: 500858 Status: Offline Sonork: 1589054 Thanks Meter: 392 | kc550 Press power on ! Starting communication ... Platform: S-Gold3 ... Preloader sent .... Loader sent .... CODE: 79957704 Power on phone with original sim. Type 2945#*71001# and enter code. Done ! Time needed - 00:00:16 |
