06-16-2009, 16:09 | #721 (permalink) |
No Life Poster Join Date: May 2007 Age: 37
Member: 500858 Status: Offline Sonork: 1589054 Thanks Meter: 392 | Press power on ! Starting communication ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Baud rate changed ok ! Flash ID(0): 0098:004A:0002 READING INFO ... WAIT ! (CAN TAKE ~60s) DATE: JUN 07 2006 OPERATOR: 234-33 VERSION: V10c REVISION: 44 FIRMWARE: KG800P64FL IMEI: 35542501395911900 LOCK: ON Phone unlocked. Phone reseted ! Time needed - 00:00:27 |
06-16-2009, 16:10 | #722 (permalink) |
Member: 500858 Status: Offline Sonork: 1589054 Thanks Meter: 392 | Software engine version: 1.0.0.2440 Searching phone ... MODEL : U300 COMPILED DATE : Jul 14 2006 10:00:00 RELEASE DATE : Jul 14 2006 17:00:00 FIRMWARE INFO : U300-MSM6250A-V10e-JUL-14-2006-H3G-UK IMEI : 35928800125628-6 BLUETOOTH ADDR : 38 4D 51 56 12 00 MEMORY ID : 0098:0076 MEMORY NAME : toshiba_ty90009800cogg MEMORY INFO : 0200:0020:0900 LOADING INIT DATA; RESETTING PHONE ! WAITING FOR PHONE TO POWER ON 30 SEC; PHONE ONLINE; SW VERSION: [OK] MODULE ERROR IMEI: [OK] 35928800125628600 BLUETOOTH ADDR: [OK] 384D51561200 PLAYING MUSIC ... WAIT; DOING CONFIG; INJECTING VODKA; INJECTING JUICE; DRINKING; DANCING; STAT: ON NAND UNLOCK DONE; PROCESS STARTED; READING; ERASING; WRITING; READING; ERASING; WRITING; UNLOCKED ! Time needed - 00:01:37 |
06-16-2009, 16:10 | #723 (permalink) |
Member: 500858 Status: Offline Sonork: 1589054 Thanks Meter: 392 | Software engine version: 1.0.0.2440 Searching phone ... MODEL : KU990i COMPILED DATE : Mar 22 2009 14:51:00 RELEASE DATE : Mar 12 2009 17:00:00 FIRMWARE INFO : KU990i-MSM6280-V10c-MAR-12-2009-XX IMEI : 35994402705672-6 BLUETOOTH ADDR : 14 FA 4B A9 22 00 MEMORY ID : 0098:00CA MEMORY NAME : toshiba_tya000bc00bogg MEMORY INFO : 0800:0040:06C3 LOADING INIT DATA; RESETTING PHONE ! WAITING FOR PHONE TO POWER ON 30 SEC; PHONE ONLINE; SW VERSION: [OK] Invalid Module Software Version IMEI: [OK] 359944027056726 BLUETOOTH ADDR: [OK] 0022A94BFA14 PLAYING MUSIC ... WAIT; DOING CONFIG; NAND INIT MADE; READING SEC DATA; SECURITY TESTS PASSED ! UNLOCKING PASSED ! LOCK HASH WRITTEN; UNLOCKED ! Time needed - 00:01:27 |
06-16-2009, 16:13 | #724 (permalink) |
Member: 500858 Status: Offline Sonork: 1589054 Thanks Meter: 392 | kp170 Press power on button ... Phone detected ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Requesting baudrate change ... Baudrate changed ... Flash ID(0): 0001:227E:3C00 Searching flash image ... Reading flash image ... Unlock finished ! Done ! Time needed - 00:00:19 |
06-16-2009, 16:14 | #725 (permalink) |
Member: 500858 Status: Offline Sonork: 1589054 Thanks Meter: 392 | Software engine version: 1.0.0.2440 Searching phone ... MODEL : KU990 COMPILED DATE : Oct 16 2008 13:21:00 RELEASE DATE : Oct 16 2008 17:00:00 FIRMWARE INFO : KU990GO-MSM6280-V10a-OCT-16-2008-XX IMEI : 35994402425389-6 BLUETOOTH ADDR : 14 12 A9 A9 22 00 MEMORY ID : 0098:00CA MEMORY NAME : toshiba_tya000bc00bogg MEMORY INFO : 0800:0040:06C3 INIT NAND ROUTINES; NAND INIT MADE; READING SECURITY AREA; READING SEC DATA; SECURITY TESTS PASSED ! UNLOCKING PASSED ! LOCK HASH WRITTEN; UNLOCKED ! Time needed - 00:00:10 |
06-16-2009, 16:14 | #726 (permalink) |
Member: 500858 Status: Offline Sonork: 1589054 Thanks Meter: 392 | All Phone In One Day Smae Time With Fg kp170 Kp170 Press power on button ... Phone detected ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Requesting baudrate change ... Baudrate changed ... Flash ID(0): 0001:227E:3C00 Searching flash image ... Reading flash image ... Unlock finished ! Done ! Time needed - 00:00:37 |
06-16-2009, 16:15 | #727 (permalink) |
Member: 500858 Status: Offline Sonork: 1589054 Thanks Meter: 392 | kp501 Press power on ! Starting communication ... Platform: S-Gold3 ... Preloader sent .... Loader sent .... CODE: 05281548 Power on phone with original sim. Type 2945#*71001# and enter code. Done ! Time needed - 00:00:26 |
06-16-2009, 16:16 | #728 (permalink) |
Member: 500858 Status: Offline Sonork: 1589054 Thanks Meter: 392 | ks320 Press power on ! Starting communication ... Platform: S-Gold3 ... Preloader sent .... Loader sent .... CODE: 62607132 Power on phone with original sim. Type 2945#*71001# and enter code. Done ! Time needed - 00:00:16 |
The Following User Says Thank You to rose4u86 For This Useful Post: |
06-16-2009, 16:16 | #729 (permalink) |
Member: 500858 Status: Offline Sonork: 1589054 Thanks Meter: 392 | Kp170 Press power on button ... Phone detected ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Requesting baudrate change ... Baudrate changed ... Flash ID(0): 0001:227E:3C00 Searching flash image ... Reading flash image ... Unlock finished ! Done ! Time needed - 00:00:20 |
06-16-2009, 16:37 | #730 (permalink) |
No Life Poster Join Date: Mar 2001 Location: ALBANIA(Tirana) Age: 51
Member: 3617 Status: Offline Thanks Meter: 579 | Blackberry 8110 Vodafone spain Searching for usb device ... Reading info ... IMEI: 351961027196326 Calculating ... MEP2 CODE: 9375688442797854 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:13 |
06-16-2009, 17:24 | #731 (permalink) |
Member: 3617 Status: Offline Thanks Meter: 579 | Blackberry 8700g TIm ITALY Connecting to device ... Connected. Uploading communication module ... Waiting 25 seconds for you to start it ! Connecting to applet ... Connected ... IMEI: 357890002602939 COMPUTING ... PLEASE WAIT ! LOCK DATA: SIM Unlock Code: NONE Tries Left: 0 NET Unlock Code: 2064945008434005 Tries Left: 10 SNET Unlock Code: NONE Tries Left: 0 SP Unlock Code: NONE Tries Left: 0 CP Unlock Code: NONE Tries Left: 0 Waiting 25 seconds phone to power on ! Connecting to device ... Connected. Removing communication module ... Disconnecting. Time needed - 00:04:36 |
The Following User Says Thank You to Unlocker AL For This Useful Post: |
06-16-2009, 19:21 | #732 (permalink) |
Member: 3617 Status: Offline Thanks Meter: 579 | Blackberry 8820 Orange UK Searching for usb device ... Reading info ... IMEI: 353763012805780 Calculating ... MEP2 CODE: 37236104 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:13 |
06-16-2009, 19:24 | #733 (permalink) |
Member: 3617 Status: Offline Thanks Meter: 579 | Blackberry 8310 Vodafone UK Searching for usb device ... Reading info ... IMEI: 358263013423316 Calculating ... MEP2 CODE: 2641227815982853 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:14 |
06-17-2009, 12:52 | #734 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Kotla arab ali khan Age: 56
Member: 623703 Status: Offline Sonork: 100.1614330 Thanks Meter: 439 | foma 601i unlonk ok FG Software engine version: 1.0.0.2440 Searching phone ... MODEL : L601 COMPILED DATE : Oct 19 2006 21:42:00 RELEASE DATE : Jul 4 2006 12:00:00 FIRMWARE INFO : L601i-AMSS6293.41-V10a-OCT-19-2006-DCM-JP IMEI : 35242701128334-7 BLUETOOTH ADDR : 00 00 00 00 00 00 MEMORY ID : 0098:0079 MEMORY NAME : toshiba_ty9000ac10aobg MEMORY INFO : 0200:0020:1980 INIT NAND ROUTINES; NAND INIT MADE; READING; ERASING; WRITING; UNLOCKED ! Time needed - 00:00:08 |
The Following User Says Thank You to shahid41 For This Useful Post: |
06-17-2009, 23:44 | #735 (permalink) |
No Life Poster Join Date: Nov 2008 Location: tunisia
Member: 898887 Status: Offline Sonork: ramazoti Thanks Meter: 210 | u526 unlock ok Searching phone ... MODEL : D618 V1.0 Download mode entered ... Loading bootloader ... Requesting random data ... Completed ... Init nand made; Reading; Imei : 35638700003131-1 Unlock code: 1447241032264292 Done ! Time needed - 00:01:11 |
The Following User Says Thank You to ramazoti10 For This Useful Post: |
