12-08-2009, 13:59 | #1891 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Al-Madina Communication Age: 46
Member: 206532 Status: Offline Sonork: 100.1622270 Thanks Meter: 875 | Start auth ! SW Ver: P1.2PU03V01.01 Imei: 353081037558858 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_17.58.59_08.12.2009_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:36 |
The Following User Says Thank You to alis For This Useful Post: |
12-08-2009, 14:23 | #1892 (permalink) |
Junior Member Join Date: Nov 2008
Member: 907026 Status: Offline Thanks Meter: 0 | sagem my411c unlock by red code Press power on shortly ... Starting communication ... MCU ID: 09B001179C8B46C1000000000000B86F ROM HASH: 62FB6505AC902905678D99DD748702EE ROM VER: 05.02 Authorising ... Sending preloader ... Exploiting ... Preloader started ... Sending applet ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Changing baudrate ... Flash ID(0): 0001:317E:4100 Reading unbinded data; Unbinded flash data done; Unbinded eeprom data done; Plain datadone; Model: my411C Hash: 00002C18 Algo: 05 Firmware: EMN,BL: 160108 1742 Imei: 357970012534171 Phone code: 0000 Prod. code: 253043447 Id calculation done; CODES: NET LO CODE: 0981699611 NET HI CODE: 2059635931 Done ! Time needed - 00:02:05 |
12-08-2009, 15:18 | #1894 (permalink) |
No Life Poster Join Date: May 2007 Location: InsidE AndroiD Age: 37
Member: 503161 Status: Offline Sonork: 100.1584069 Thanks Meter: 474 | another one done Connect phone powered on ! Start auth ! SW Ver: P1.2PU03V01.01 Imei: 353----------- Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_19.17.00_08.12.2009_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:37 |
12-08-2009, 16:25 | #1895 (permalink) |
No Life Poster Join Date: Dec 2003 Location: MX-KEY is the BEST NOKIA TOOL
Member: 46042 Status: Offline Sonork: 100.1575650 Thanks Meter: 93 | Press power on shortly ... Starting communication ... MCU ID: 1710020C62A75DC10000000000009A34 ROM HASH: 62FB6505AC902905678D99DD748702EE ROM VER: 05.02 Authorising ... Sending preloader ... Exploiting ... Preloader started ... Sending applet ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Changing baudrate ... Flash ID(0): 0001:2D7E:2F00 Reading unbinded data; Unbinded flash data done; Unbinded eeprom data done; Plain datadone; Model: my411Cv Hash: 00005680 Algo: 05 Firmware: EVN,SE: 230707 1109 Imei: 35657********** Phone code: 1234 Prod. code: 987014789 Id calculation done; CODES: NET LO CODE: 2648351648 NET HI CODE: 3709509728 Done ! Time needed - 00:02:24 |
12-08-2009, 16:44 | #1896 (permalink) |
Member: 206532 Status: Offline Sonork: 100.1622270 Thanks Meter: 875 | Connect phone powered on ! Start auth ! SW Ver: P1.2PU03V01.01 Imei: 353081037572933 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_20.42.41_08.12.2009_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:32 |
12-09-2009, 05:25 | #1897 (permalink) |
Freak Poster Join Date: Nov 2005
Member: 200548 Status: Offline Thanks Meter: 104 | bb8220 unlock sucessfull by furious Searching for usb device ... Reading info ... IMEI: 358453028713971 Calculating ... MEP: MEP-04104-007 MEP2 CODE: 3772890122540019 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:22 |
12-09-2009, 05:27 | #1898 (permalink) |
Member: 200548 Status: Offline Thanks Meter: 104 | bb8320 unlock done again Searching for usb device ... Reading info ... IMEI: 359181011745655 Calculating ... MEP: MEP-07723-003 MEP2 CODE: 8443278168870076 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:21 |
12-09-2009, 05:28 | #1899 (permalink) |
Member: 200548 Status: Offline Thanks Meter: 104 | bb9000 unlocking done Searching for usb device ... Reading info ... IMEI: 353906030367438 Calculating ... MEP: MEP-04104-007 MEP2 CODE: 9290368649266171 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:22 |
12-09-2009, 05:29 | #1900 (permalink) |
Member: 200548 Status: Offline Thanks Meter: 104 | bb8320 unlock done again Searching for usb device ... Reading info ... IMEI: 356200027055330 Calculating ... MEP: MEP-04104-007 MEP2 CODE: 0470512558171891 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:24 |
12-09-2009, 07:27 | #1901 (permalink) |
Member: 206532 Status: Offline Sonork: 100.1622270 Thanks Meter: 875 | Connect phone powered on ! Start auth ! SW Ver: P1.2nV01.05:ULC2GL Imei: 359428010010742 PhoneLock Reset success ! Unlocked ! Done ! Time needed - 00:00:04 |
12-09-2009, 08:34 | #1902 (permalink) |
Member: 907026 Status: Offline Thanks Meter: 0 | Successfully imei change lg kf700 Software engine version: 1.0.0.3311 Searching phone ... MODEL : KF700 COMPILED DATE : Apr 28 2008 17:21:00 RELEASE DATE : Feb 22 2008 09:00:00 FIRMWARE INFO : KF700-MSM6280-V10b-APR-28-2008-XX IMEI : 35335702159213-1 BLUETOOTH ADDR : 82 71 95 6B 1F 00 MEMORY ID : 0098:00CA MEMORY NAME : toshiba_tya000bc00bogg MEMORY INFO : 0800:0040:069C INIT NAND ROUTINES; NAND INIT MADE; READING SECURITY AREA; READING SEC DATA; IMEI PASSED ! INFO HASH WRITTEN; LOCK HASH WRITTEN; INFO FIXED Time needed - 00:00:21 |
12-09-2009, 09:31 | #1903 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Kotla arab ali khan Age: 56
Member: 623703 Status: Offline Sonork: 100.1614330 Thanks Meter: 439 | Connect phone powered on ! Start auth ! SW Ver: P1.2PU03V01.01 Imei: 353081036936998 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_13.16.23_09.12.2009_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:15 |
12-09-2009, 09:57 | #1904 (permalink) |
Member: 623703 Status: Offline Sonork: 100.1614330 Thanks Meter: 439 | Connect phone powered on ! Start auth ! SW Ver: P1.2PU03V01.01 Imei: 353081038549286 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_13.54.30_09.12.2009_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:16 |
12-09-2009, 09:57 | #1905 (permalink) |
Member: 206532 Status: Offline Sonork: 100.1622270 Thanks Meter: 875 | Connect phone powered on ! Start auth ! SW Ver: P1.2PU03V01.01 Imei: 353081036805268 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_13.30.12_09.12.2009_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:48 |
