08-25-2009, 07:50 | #1141 (permalink) |
Cheater -Don't Deal with him- Join Date: Feb 2009 Location: Gsx Check Source Age: 35
Member: 975047 Status: Offline Thanks Meter: 330 | Reading info ... IMEI: 351845036406414 Calculating ... MEP2 CODE: 5528701918681222 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! |
08-25-2009, 07:50 | #1142 (permalink) |
Member: 975047 Status: Offline Thanks Meter: 330 | Searching for usb device ... Reading info ... IMEI: 359675013416900 Calculating ... MEP2 CODE: 1013956712708001 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:33 |
08-25-2009, 07:52 | #1143 (permalink) |
Member: 975047 Status: Offline Thanks Meter: 330 | Searching for usb device ... Reading info ... IMEI: 352109032626106 Calculating ... MEP2 CODE: 8042672550218057 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:14 |
08-25-2009, 07:53 | #1144 (permalink) |
Member: 975047 Status: Offline Thanks Meter: 330 | Software engine version: 1.0.0.2440 Searching phone ... MODEL : QCOM SERIES 2 COMPILED DATE : Jun 22 2007 10:42:00 RELEASE DATE : Jun 20 2007 12:00:00 FIRMWARE INFO : F230 3.1 IMEI : 35561601015657-2 BLUETOOTH ADDR : 3C F4 15 EB 15 00 MEMORY ID : 00EC:0078 MEMORY NAME : samsung_k91g08 MEMORY INFO : 0200:0020:132D INIT NAND ROUTINES; NAND INIT MADE; PROCESS STARTED; READING; ERASING; WRITING; UNLOCK CODE: 9243939912070399 ENTER USING: *983*865625# RESET ! Time needed - 00:00:08 |
08-25-2009, 09:36 | #1145 (permalink) |
No Life Poster Join Date: Mar 2001 Location: ALBANIA(Tirana) Age: 51
Member: 3617 Status: Offline Thanks Meter: 579 | Alcatel OT-E227 Press power on shortly ... Starting communication ... BootRom v05.02 Authorising ... Sending certificate ... Sending preloader ... Preloader started ... Sending applet ... Changing baudrate ... Flash ID(0): 0001:2A7E:2400 IMEI: 3571800138128000 Requesting mepd info ... Saved: LOCOSTO_10.31.56_25.08.2009_SP.bin Direct unlock finished. 1 locks were cleared. Done ! Time needed - 00:00:24 |
08-25-2009, 10:44 | #1146 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Afghanistan Kabul
Member: 295886 Status: Offline Sonork: 100.1583369 Thanks Meter: 1,472 | L602i unlock successfully Software engine version: 1.0.0.2568 Searching phone ... MODEL : L602 COMPILED DATE : May 31 2007 16:25:00 RELEASE DATE : Oct 11 2006 11:00:00 FIRMWARE INFO : L602i-AMSS6293.48-V10a-MAY-30-2007-DCM-JP IMEI : 35501101301205-7 BLUETOOTH ADDR : 00 00 00 00 00 00 MEMORY ID : 0098:0079 MEMORY NAME : toshiba_ty9000ac10aobg MEMORY INFO : 0200:0020:1730 INIT NAND ROUTINES; NAND INIT MADE; READING; ERASING; WRITING; UNLOCKED ! Time needed - 00:00:26 |
08-25-2009, 10:49 | #1147 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Android developers
Member: 904753 Status: Offline Sonork: 100.1583681 Thanks Meter: 2,677 | FOMA L601i UNLOCK DONE REPORT... FOMA L601i UNLOCKING. LOG: Software engine version: 1.0.0.2568 Searching phone ... MODEL : L601 COMPILED DATE : Oct 19 2006 21:42:00 RELEASE DATE : Jul 4 2006 12:00:00 FIRMWARE INFO : L601i-AMSS6293.41-V10a-OCT-19-2006-DCM-JP IMEI : 35242701108523-9 BLUETOOTH ADDR : 00 00 00 00 00 00 MEMORY ID : 0098:0079 MEMORY NAME : toshiba_ty9000ac10aobg MEMORY INFO : 0200:0020:1980 INIT NAND ROUTINES; NAND INIT MADE; READING; ERASING; WRITING; UNLOCKED ! Time needed - 00:00:05 THANKS MR.Hack2r3k Br. Waqar |
The Following User Says Thank You to ..::Waqar::.. For This Useful Post: |
08-25-2009, 12:08 | #1148 (permalink) |
No Life Poster Join Date: Apr 2007 Location: SL3 LBF IN Kamoke(Gujranwala)
Member: 481915 Status: Offline Sonork: 100.1604233 Thanks Meter: 476 | VODAFONE V725 SUCCESSFULL UNLOCKED Searching phone ... MODEL : M6275A-OEMS Download mode entered ... Loading bootloader ... Memory Info: 00AD:0078 Requesting random data ... Sending data ... Authorisation started ... Authorisation passed ... Unlock Code: 7777777777777777 Done ! Time needed - 00:00:10 MIANLINKS |
08-25-2009, 16:27 | #1150 (permalink) |
Member: 3617 Status: Offline Thanks Meter: 579 | Blackberry 9500 vodafone Searching for usb device ... Reading info ... IMEI: 359484026030489 Calculating ... MEP: MEP-06814-004 MEP2 CODE: 4026788160224290 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:12 |
08-26-2009, 12:03 | #1151 (permalink) |
Freak Poster Join Date: Oct 2007
Member: 612770 Status: Offline Thanks Meter: 33 | Furious gold is the best tool t156 unlock Press power on ! Start auth ! SW Ver: P1.2nV01.05:ULC2GL Imei: 359428010432896 PhoneLock Reset success ! Unlocked ! Done ! Time needed - 00:00:02 |
08-26-2009, 13:12 | #1152 (permalink) |
Member: 295886 Status: Offline Sonork: 100.1583369 Thanks Meter: 1,472 | KP500 unlocked successfully Press power on ! Starting communication ... Platform: S-Gold3 ... Preloader sent .... Loader sent .... CODE: 02326065 Power on phone with original sim. Type 2945#*71001# and enter code. Done ! Time needed - 00:00:30 |
The Following User Says Thank You to Maiwand khan For This Useful Post: |
08-26-2009, 13:32 | #1154 (permalink) |
No Life Poster Join Date: Jul 2007 Location: PK
Member: 539052 Status: Offline Sonork: 100.1585495 Thanks Meter: 119 | 8310 successful unlock Searching for usb device ... Reading info ... IMEI: 358263@@@@@@@@ Calculating ... MEP: MEP-16472-001 MEP2 CODE: 6282792097871582 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:10 |
