Using library Brom_DLL_v7.1522.2 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM125)) Preparing to start flash mode; Preparing to open COM125 Connecting; Downloading DA; Initializing; Rid: 5b99713af376fcb9436d447506470cd6 Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem81.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM137; DEVICE INFO: BB CHIP: MT6735M_S00 [CA00, 00, 335, FF] HW_STORAGE_EMMC: 0x4E030188 0x64726143 0x2B503920 0x7763604B [SIZE=0x1CED00000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x99000000 SIZE: 0x35D00000 Searching data; Locked to [SIM1]: 250-99 code_cat_n: 12345678 enabled: yes tries: 99 code_cat_ns: 56781234 enabled: no tries: 100 code_cat_sp: 11112222 enabled: no tries: 100 code_cat_c: 33334444 enabled: no tries: 100 code_cat_sim: 55556666 enabled: no tries: 100 code_cat_ns_sp: 77778888 enabled: no tries: 100 code_cat_sim_c: 99990000 enabled: no tries: 100 Phone unlocked; Remove battery and cable; Time needed - 00:00:03 Log file saved to: LOG_29_05_2017_10_48_34.txt |
Huawei Y330-U05/U07 IMEI BLANK RESTORED DONE Huawei Y330-U05/U07 IMEI BLANK RESTORED DONE A.K.A BUCARE http://www.imageupload.co.uk/images/.../Y330FG.md.jpg |
ALCATEL 5065N UNLOCK DONE Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@oem399.inf,%qcomdevice90080%;Qualcomm HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM29 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD IMEI: 01470500264241-9 PTH: 03 PTS: N5S PROV_ID: 5065N-2CE4US1 SBTADDR: 28:BE:03:51:B6:10 SWIFIADDR: 28:BE:03:68:24:89 HS_PN: SAA34NBAA10C SSN: 98KJ11BD6LZ03K6 Work id: 068A76D5 Done; Stype: 00000001 SECURITY: X2N0UP00CL10 Size: 000002C3 Backup saved to: 01470500264241-9 Unlocking; SIM_LOCK REMOVED ! Log file saved to: LOG_29_05_2017_14_02_48.txt Time needed - 00:00:27 |
SAMSUNG G55OT1 UNLOCK DONE Using Version...1.0.0.0047 Selected Model GT-I5500 Selected Task SAMSUNG T-MOBILE UNLOCK Searching ADB device Please wait.. Device Detected... model:= SM-G550T1 Androids Version:= 6.0.1 Description Version:= on5ltemtr-user 6.0.1 MMB29K G550T1UVU2AQC4 release-keys Platform:= exynos3 [ universal3475 ] [ SHANNON308 ] Baseband:= G550T1UVU2AQC4 VER:= G550T1UVU2AQC4/G550T1TMK2AQC4/G550T1UVU2AQC4/G550T1UVU2AQC4 Carrier := TMK_USA AP UART Status := Disable. Security Patch := 01-03-2017 Network Mode := LTE Simstatus:= ABSENT ANDROID-ID = 920134c34a47249f_000025BAFA SU Version..2.76:SUPERSU Device is Secure Rooted..uid=0 System Permission is Read/Write... SAMSUNG ALL T-MOBILE UNLOCKING STARTED... Checking Data... Waiting for Loader... Loader Ok... Direct Unlock Success... !!! Success !!!! Restart Phone Manually if not done auto... Total Time Take...00:00:09 Log Saved |
BLU Z3 080 UNLOCK DONE Searching phone; For an successful connection do the following: 1. Remove battery and usb cable 2. Insert the usb cable in the phone 3. Keep pressed the boot key and insert the battery Phone detected (@oem383.inf,%dvcdsc%;SCI USB2Serial) Preparing to sync; Port opened [COM100]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: (c)2014, FuriouSTeaM GSM DEVELOPEMENT Chip type: 6531 FdlStat: 0001 Starting auth; HW IMEI : 000000-00-000000-0 Memory [CS0]: 00C8:0060:0016 - SIZE : 00400000 Reading phone info; PHONE INFO: NONE BT ADDR: 3E:B6:DA:02:F1:58 SW IMEI[0]: 359922-07-110182-0 SW IMEI[1]: 359922-07-110183-8 SW IMEI[2]: 358570-01-010389-3 SW IMEI[3]: 910575-60-140046-8 SIMLOCK FLAG: ON FIXED NV BASE: 303B8000 Reading NV; NV saved to : NV_000000-00-000000-0_359922-07-110182-0_65310001_29_05_2017_18_35_39.spd IMEI: 359922-07-110182-0 UNLOCK CODE: NONE Re-programming; NV programmed; Done; Phone unlocked; Remove battery and cable; Log file saved to: LOG_29_05_2017_18_36_01.txt Time needed - 00:00:29 |
ALCATEL 4060W UNLOCK DONE Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@oem408.inf,%qcdownloaddiag%;Qualcomm HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM10 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD IMEI: 01472400042441-5 PTH: 10 PTS: P5G PROV_ID: 4060W-2AWFUS1-R SBTADDR: 24:0D:C2:3A:FB:CF SWIFIADDR: 24:0D:C2:26:77:E5 HS_PN: SAA1HA0AA00C SSN: R9KB11BMPMZ01UX Bruteforcing data; This operation can take up to 30 minutes !!! Done; Work id: 08089CA0 Done; Stype: 00000001 SECURITY: X3P0UW04CL10 Size: 000002B7 Backup saved to: 01472400042441-5 Unlocking; SIM_LOCK REMOVED ! Log file saved to: LOG_29_05_2017_19_12_30.txt Time needed - 00:32:42 |
Alcatel 2051x unlock done with furious gold pack 2 spd Searching phone; For an successful connection do the following: 1. Remove battery and usb cable 2. Insert the usb cable in the phone 3. Keep pressed the boot key and insert the battery Phone detected (SCI USB2Serial) Preparing to sync; Port opened [COM44]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: (c)2014, FuriouSTeaM GSM DEVELOPEMENT Chip type: 6531 FdlStat: 0001 Starting auth; HW IMEI : 000000-00-000000-0 Memory [CS0]: 00C8:0060:0017 - SIZE : 00800000 Reading phone info; PHONE INFO: 2051X-3AVRGB1 BT ADDR: 1E:13:58:17:FD:CC SW IMEI[0]: 358329-07-259877-5 SW IMEI[1]: 352751-01-952326-7 SW IMEI[2]: 358570-01-010389-3 SW IMEI[3]: 910575-60-140046-8 SIMLOCK FLAG: ON FIXED NV BASE: 30658000 Reading NV; NV saved to : NV_000000-00-000000-0_358329-07-259877-5_65310001_30_05_2017_10_02_20.spd IMEI: 358329-07-259877-5 UNLOCK CODE: 16988890 or 3583290716988890 Re-programming; NV programmed; Done; Phone unlocked; Remove battery and cable; Log file saved to: LOG_30_05_2017_10_02_43.txt Time needed - 00:00:39 |
Ku990i unlock done wth furious gold Software engine version: 1.0.0.10472 Searching phone ... MODEL : KU990i COMPILED DATE : Mar 21 2009 15:44:00 RELEASE DATE : Feb 25 2009 17:00:00 FIRMWARE INFO : KU990iG-MSM6280-V10a-FEB-25-2009-XX IMEI : 35994402954705-2 BLUETOOTH ADDR : 13 9C E5 A9 22 00 MEMORY ID : 0098:00CA MEMORY NAME : toshiba_tya000bc00bogg MEMORY INFO : 0800:0040:06C3 LOADING INIT DATA; RESETTING PHONE ! WAITING FOR PHONE TO POWER ON 30 SEC; PHONE ONLINE; SW VERSION: [OK] Invalid Module Software Version IMEI: [OK] 359944029547052 BLUETOOTH ADDR: [OK] 0022A9E59C13 PLAYING MUSIC ... WAIT; DOING CONFIG; NAND INIT MADE; READING SEC DATA; SECURITY TESTS PASSED ! UNLOCKING PASSED ! LOCK HASH WRITTEN; UNLOCKED ! Log file saved to: LOG_30_05_2017_10_15_08.txt Time needed - 00:01:25 |
1st in the WORLD Vodafone Ultra 6 / 995n 1st in the World from Portugal - Tek4life.pt with big big help from .:hack3r2k:. Daniel Reset FRP done and Imei repair/change Vodafone ultra 6 / 996n Software engine version: 1.0.0.10512 Searching phone ... MODEL : QCOM SERIES 52 COMPILED DATE : Nov 16 2015 12:18:00 RELEASE DATE : Sep 28 2015 11:00:00 FIRMWARE INFO : MPSS.DPM.2.0.2.c1.12-00038-M8936FAAAANUZM-1 IMEI : 35873606076882-4 BLUETOOTH ADDR : 00 00 00 00 00 00 FIRMWARE: PT_MR2_VDF_P839V55V1.0.0B09 DONE; STARTING FRP RESET; close_event_report: OK; close_log_report: OK; close_message_report: OK; FRP REMOVED SUCCESSFULLY; Imei change/Repair (for testing if work) Software engine version: 1.0.0.10512 Searching phone ... MODEL : QCOM SERIES 52 COMPILED DATE : Nov 16 2015 12:18:00 RELEASE DATE : Sep 28 2015 11:00:00 FIRMWARE INFO : MPSS.DPM.2.0.2.c1.12-00038-M8936FAAAANUZM-1 IMEI : 35873606076882-4 BLUETOOTH ADDR : 00 00 00 00 00 00 FIRMWARE: PT_MR2_VDF_P839V55V1.0.0B09 DONE; Imei repair start; Imei successfully repaired;; RESET ! Imei repair end; |
DOGEE X9 PRO FRO Unlock Just unlocked FRP in Doogee X9 Pro with OTSmart, selected ROOK from EE. Using library Brom_DLL_v7.1522.2 Searching phone in normal mode; [connect the phone powered off to the usb cable] Phone detected (MediaTek PreLoader USB VCOM (Android) (COM7)) Preparing to start flash mode; Preparing to open COM7 Connecting; Downloading DA; Initializing; Rid: 977b87ce3e79f2a293c8f74d84feb95d Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem283.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM8; DEVICE INFO: BB CHIP: MT6735M_S00 [CA00, 00, 335, FF] HW_STORAGE_EMMC: 0x51000115 0x4D333238 0x7C210042 0x9983EA6A [SIZE=0x3A4A00000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x99000000 SIZE: 0x0BA00000 BR ERSA Seb |
Huawei lua l03 unlock ,read nvram, Searching phone... (insert the USB cable in the powered off phone) Phone detected (MediaTek PreLoader USB VCOM (Android)) Preparing to start MTK debug mode; Searching for debug port... (be sure drivers from support were installed!) MTK debug mode entered Baseband Chip: MT6735M,S01 Sw version: Hw Version: ALPS.L1.MP3.V2.95_OT6735M.35GU.LU.L1_P12 Baseband Chip: MT6735, E00 Sw version: MOLY.LR9.W1444.MD.LWTG.MP.V48.P10 Hw Version: OT6735_65C_LU_L1_HW Reading info... IMEI 1: 869531029333550 IMEI 2: N/A Open port success! Start backup NVRAM Backup saved to: NVRAM_869531029333550.bin Open port success! 2017-05-30 17:24:48.161 Reading data from server... 2017-05-30 17:24:48.961 Reading data from server success! Reading simlock info; Gathering info; Simlock ok; SIM1 Locks cleared; Simlock ok; SIM2 Locks cleared; Simlock read end; |
HUAWEI CAM L03 UNLOCK DONE 31/05/2017 02:54:15 p.m. FlyCaptain Huawei Module v2.0.0.0151 Furious Gold Pack 7 Dongle S/N: 57A96656 Before detection connect cable to usb and enable Manufacture mode ! Qualcomm and HiSilicon: *#*#2846579#*#* MTK: *#*#14789632#*#* Windows: ##2846579# ProjectMenu 1.Background setting 2.USB ports setting Select Manufacture mode (for MTK other/debug mode) 2017-05-31 14:54:17.385 Autodetect started! 2017-05-31 14:54:18.027 Found COM port: COM792 2017-05-31 14:54:19.030 Start read phone info! 2017-05-31 14:54:19.032 Open port COM792 (Android Adapter PCUI (COM792))... 2017-05-31 14:54:19.160 Phone authorize success! 2017-05-31 14:54:19.164 Read basic info... 2017-05-31 14:54:20.361 Read secure info... 2017-05-31 14:54:29.301 Detect phone done! Model: CAM-L03 IMEI: 861092037142739 SUB_IMEI: 861092037142739 IMEISV: 24 Firmware ver.: CAM-B124 SN: NSXDU17110001913 Custom SN: DU3UGD171B018867 WiFi MAC: 50:01:D9:3A:8B:BE BlueTooth MAC: 50:01:D9:3A:93:DF Vendor: orange Country: do FASTBOOT:DailyBuild_201610210615_FASTBOOT BOOT:DailyBuild_201610210615_BOOT RECOVERY:(unknow) SYSTEM:CAM-L03C900B124_SYSTEM MAINVER:CAM-B124 DATAVER:CAM-B124_DATA_orange_do APTIME:Fri Oct 21 06:23:01 CST 2016 CUSTTIME:Fri Oct 21 06:40:07 CST 2016 RAM: 2G eMMC: 16G IMEI 1 Sim Lock status: NET: locked, unlock retry counts: 10 NETSUB: unlocked SP: unlocked 2017-05-31 14:54:37.944 Autodetect started! 2017-05-31 14:54:40.578 Found COM port: COM792 2017-05-31 14:54:40.584 Open port COM792 (Android Adapter PCUI (COM792))... 2017-05-31 14:54:40.709 Connecting to server... 2017-05-31 14:54:41.712 Connected! 2017-05-31 14:54:41.715 Read data from server... 2017-05-31 14:54:44.038 Read data from server success! 2017-05-31 14:54:44.261 Phone authorize start 2017-05-31 14:54:49.425 Phone authorize success! 2017-05-31 14:54:49.430 Read secure info... 2017-05-31 14:54:58.293 Read secure info success! 2017-05-31 14:54:58.299 Read basic info... 2017-05-31 14:55:01.967 Read basic info success! 2017-05-31 14:55:01.973 Unlocking start 2017-05-31 14:55:01.979 Phone secure identify start 2017-05-31 14:55:05.040 Phone secure identify success! 2017-05-31 14:55:05.046 Reading data from server... 2017-05-31 14:55:05.899 Reading data from server success! 2017-05-31 14:55:07.883 Unlock done! 2017-05-31 14:55:07.890 Job finished! |
Successful Unlock Huawei LUA-U03 Code: Searching phone... |
Huawei P10 (VTR-L29) FRP success Model: VTR-L29 MEID: 8627********** pESN: 00000000 IMEI: 8627********** Firmware ver.: VTR-L29C432B123 SN: 7EX7************ IMEI1:8627********** FB LockState: LOCKED USER LockState: LOCKED locked Battery state: 4979mv 2017-06-01 09:28:59.182 Erase FRP start 2017-06-01 09:29:03.059 Reading phone info... 2017-06-01 09:29:03.153 Read phone info success! Model: VTR-L29 MEID: 8627********* pESN: 00000000 IMEI: 8627********** Firmware ver.: VTR-L29C432B123 SN: 7EX7N1********* 2017-06-01 09:29:03.168 Reading Certify data... 2017-06-01 09:29:03.200 Reading Certify data success! 2017-06-01 09:29:03.215 Signing Certify data... 2017-06-01 09:29:07.734 Erase FRP done! |
earching phone... (insert the USB cable in the powered off phone) Phone detected (MediaTek PreLoader USB VCOM (Android)) Preparing to start MTK debug mode; Searching for debug port... (be sure drivers from support were installed!) MTK debug mode entered Baseband Chip: MT6735,S01 Sw version: Hw Version: LYO-L02C718B123 Baseband Chip: MT6735, E00 Sw version: MOLY.LR9.W1444.MD.LWTG.MP.V42.P40 Hw Version: HQ6753_65C_B1N_L1_HW Reading info... IMEI 1: 861947031220510 IMEI 2: N/A Open port success! 2017-06-01 00:34:57.417 Reading data from server... 2017-06-01 00:34:58.106 Reading data from server success! Reading simlock info; Gathering info; Simlock ok; SIM1 Locks cleared; Simlock ok; SIM1 Locks cleared; Simlock ok; SIM2 Locks cleared; Simlock ok; SIM2 Locks cleared; Simlock read end; |
