Alcatel 1054x unlock done furious gold pack 2 spd SERVICE TOOL Searching phone; For an successful connection do the following: 1. Remove battery and usb cable 2. Insert the usb cable in the phone 3. Keep pressed the boot key and insert the battery Phone detected (SCI USB2Serial) Preparing to sync; Port opened [COM44]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: (c)2014, FuriouSTeaM GSM DEVELOPEMENT Chip type: 6531 FdlStat: 0001 Starting auth; HW IMEI : 000000-00-000000-0 Memory [CS0]: 00C8:0060:0016 - SIZE : 00400000 Reading phone info; PHONE INFO: 1054X-3AVRGBD-1 BT ADDR: 6B:42:F9:03:BE:28 SW IMEI[0]: 358299-07-120807-4 SW IMEI[1]: 352751-01-952326-7 SW IMEI[2]: 358570-01-010389-3 SW IMEI[3]: 910575-60-140046-8 SIMLOCK FLAG: ON FIXED NV BASE: 303B8000 Reading NV; NV saved to : NV_000000-00-000000-0_358299-07-120807-4_65310001_18_06_2017_17_34_17.spd IMEI: 358299-07-120807-4 UNLOCK CODE: 16710750 or 3582990716710750 Re-programming; NV programmed; Done; Phone unlocked; Remove battery and cable; Log file saved to: LOG_18_06_2017_17_34_36.txt Time needed - 00:00:30 |
Alcatel ot 4022d unlock done Code: Searching phone; |
OT-4007D permanent lock unlock done OT-4007D permanent lock unlock done by FuriousGold http://i65.tinypic.com/2moxtva.png Searching phone; Phone detected (@oem5.inf,%vcom_preloader%;MediaTek PreLoader USB VCOM (Android)) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on Android Gadget VCOM Driver (COM5); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6575 Sw version: MAUI.11AMD.W11.50.SP.V31.P2 Hw Version: JRDHZ75_PIXO_GB2_HW Reading phone info; IMEI: 863580-02-015190-5 Reading simlock info; Locked to: 000-00 code_cat_n: 05940908 enabled: no tries: 10 code_cat_ns: 25505088 enabled: no tries: 10 code_cat_sp: 06907256 enabled: no tries: 10 code_cat_c: 10876501 enabled: no tries: 10 code_cat_sim: 21603581 enabled: no tries: 10 code_cat_ns_sp: 53297761 enabled: no tries: 5 code_cat_sim_c: 86817778 enabled: no tries: 5 Time needed - 00:00:38 |
Alcatel 5056w unlock done Connect the phone powered off with both volume down and up pressed or connect the phone powered off and leave it connected to the usb till it shows the battery/charging screen ; Phone detected (@oem84.inf,%qcomdevice90080%;Qualcomm HS-USB QDLoader 9008) Preparing to start flash mode; Preparing to open COM63 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22CD IMEI: 01474900012364-2 PTH: 08 PTS: B6N PROV_ID: 5056W-2AWFUS7-R SBTADDR: 24:0D:C2:2D:A8:D1 SWIFIADDR: 24:0D:C2:2D:F6:9F HS_PN: SAA1F5BWA10C SSN: N6KB10CGTMZ02DU Bruteforcing data; This operation can take up to 30 minutes !!! Done; Work id: 02E168CD Done; Stype: 00000001 SECURITY: XUB0UW03BR10 Size: 000002B7 Backup saved to: 01474900012364-2 Unlocking; SIM_LOCK REMOVED ! Log file saved to: LOG_21_06_2017_16_10_57.txt Time needed - 00:12:48 |
huawei y560 frp huawei y560 frp ok!!!! 2017.06.22. 10:15:14 FlyCaptain Huawei Module v2.0.0.0154 Furious Gold Pack 7 Dongle S/N: 73D51A44 Before detection connect cable to usb and enable Manufacture mode ! Qualcomm and HiSilicon: *#*#2846579#*#* MTK: *#*#14789632#*#* Windows: ##2846579# ProjectMenu 1.Background setting 2.USB ports setting Select Manufacture mode (for MTK other/debug mode) 2017-06-22 10:15:16.306 Start read phone info! 2017-06-22 10:15:16.454 Detect phone done! Model: msm8909 Firmware ver.: Y560-L01V100R001C577B047 SN: Q6VBBBB5C2962519 Root State: UNROOT Battery state: 4199mv 2017-06-22 10:15:21.568 Erase FRP start 2017-06-22 10:15:25.192 Reading phone info... 2017-06-22 10:15:25.266 Read phone info success! Model: msm8909 Firmware ver.: Y560-L01V100R001C577B047 SN: Q6VBBBB5C2962519 2017-06-22 10:15:25.303 Reading data from server... 2017-06-22 10:15:25.621 Reading data from server success! 2017-06-22 10:15:25.624 Erasing FRP... 2017-06-22 10:15:25.881 Erase FRP done! |
New security LUA-L01 succesfull unlock All other tool failed! Searching phone... (insert the USB cable in the powered off phone) Phone detected (MediaTek PreLoader USB VCOM (Android)) Preparing to start MTK debug mode; Searching for debug port... (be sure drivers from support were installed!) MTK debug mode entered Baseband Chip: MT6735M,S01 Sw version: Hw Version: ALPS.L1.MP3.V2.95_OT6735M.35GU.L1_P69 Baseband Chip: MT6735, E00 Sw version: MOLY.LR9.W1444.MD.LWTG.MP.V48.P16.T2 Hw Version: OT6735_65C_L1_HW Reading info... IMEI 1: 8616870327xxxxxx IMEI 2: N/A Open port success! 2017-06-22 17:58:58.563 Reading data from server... 2017-06-22 17:58:59.063 Reading data from server success! Reading simlock info; Gathering info; SIM UNLOCK CODE: 82886028 Simlock read end; Thx furi ;) |
ALCATEL 2004C UNLOCK DONE Using library Brom_DLL_v5.1316.1 Searching phone; (for some models keep SPACE or * (STAR) key pressed before inserting the cable) Phone detected (MediaTek USB Port (COM18)) Preparing to start meta mode; Requesting authorization; Done; Meta mode entered; Baseband Chip: MT6260 Sw version: MAUI.11B.W13.08.MP.V4.F54 Hw Version: JRDHZ60A_11B_HW Reading phone info; IMEI: 014659-00-184191-2 Reading security; Done; Checking; Preparing; Writing security; Phone unlocked; Remove battery and cable; Time needed - 00:00:20 Log file saved to: LOG_22_06_2017_17_43_31.txt |
Alcatel 4013x unlocked done Code: Using library Brom_DLL_v7.1522.2 |
vodafone 300 unlocked done Code: Using library Brom_DLL_v7.1522.2 |
Vodafone 975 successfully unlocked Code: Searching phone; |
VDF 500 unlocked Code: Using library Brom_DLL_v7.1522.2 |
Alcatel 2001x unlocked done Code: Using library Brom_DLL_v5.1316.1 |
P8 lite unlocked done Code:
Huawei y530 unlocked done Code: Connecting; |
Huawei CUN-L01 FRP Removal Huawei Y5 II CUN-L01 4G LTE FRP Removal Quote:
