02-04-2011, 08:42 | #7681 (permalink) |
Cheater -Don't Deal with him- Join Date: May 2006 Age: 38
Member: 283204 Status: Offline Sonork: 100.1577140 Thanks Meter: 1,098 | <<<<succsessfully unlock done vodafone 246 with furious-gold>>>> Software engine version: 1.0.0.5472 Insert cable in box now [NO BATTERY INSIDE PHONE] ! Starting communication ... Platform: E-Gold Voice3-32 [00 00] ... Preloader sent .... Loader sent .... Flash ID(0): 00EF:4016 Checking firmware version ... Detected: ED-DE-P118A2V1.0.0B10 Saved: ZTE_NONE_ED-DE-P118A2V1.0.0B10_12.54.34_04.02.2012_PARTIAL.bin Erasing ... Writing ... Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:46 Br: Harkishan |
02-04-2011, 08:47 | #7682 (permalink) |
Member: 283204 Status: Offline Sonork: 100.1577140 Thanks Meter: 1,098 | <<<<Succsessfully unlock lg gs390go with furious-gold>>>> Here is log: Press power on ! Starting communication ... Platform: S-Gold3 ... Preloader sent .... Loader sent .... UNLOCK CODES: NETWORK: 6674400429116734 NETWORK SUBSET: 5807643698366516 SERVICE PROV.: 0056281348747233 CORPORATE: 8942840674220083 SIM/USIM: 0985717105100507 Power on phone with original sim. Type 2945#*390# and enter code. Done ! Time needed - 00:00:17 Br: Harkishan |
02-04-2011, 09:00 | #7683 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Pakistan
Member: 897524 Status: Offline Sonork: 100,1609543 Thanks Meter: 172 | Successfully unlock Z100 Software engine version: 1.0.0.4874 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 352865041768524 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 E4 31 04 97 1C 01 8D 06 Flash ID(0): 00C2:22A7 Saved: ZTE_352865041768524_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_12.43.22_04.02.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:39 |
02-04-2011, 09:58 | #7684 (permalink) |
No Life Poster Join Date: Aug 2005
Member: 175945 Status: Offline Sonork: ziiyyaad Thanks Meter: 704 | sfr 231 unlock > IMEI: 356690xxxxxxxxxxxxxxxxx > NCK: 242976480644 > SPCK: 555488400630 FOR SOME MODELS TYPE *983*8284# OR ###825*09# (WITHOUT SIM) TO ENTER THE N.P. CODE. |
02-05-2011, 06:42 | #7685 (permalink) |
No Life Poster Join Date: Dec 2005
Member: 213172 Status: Offline Sonork: 1582799 Thanks Meter: 265 | LG GS290 Unlock Done. Press power on ! Starting communication ... Platform: S-Gold3 ... Preloader sent .... Loader sent .... UNLOCK CODES: NETWORK: 9964166769956744 NETWORK SUBSET: 1547453130395609 SERVICE PROV.: 5715854499780782 CORPORATE: 0223712181349275 SIM/USIM: 6074439019055213 Power on phone with original sim. Type 2945#*290# and enter code. Done ! Time needed - 00:00:28 |
02-05-2011, 08:11 | #7686 (permalink) |
No Life Poster Join Date: Jan 2009 Location: ---- Age: 35
Member: 959010 Status: Offline Sonork: 100.1602440 Thanks Meter: 445 | Z100 unlock done Software engine version: 1.0.0.5455 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 352865041134248 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 24 31 04 98 99 07 92 00 Flash ID(0): 00C2:22A7 Saved: ZTE_352865041134248_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_12.07.10_05.02.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:56 |
02-05-2011, 08:31 | #7687 (permalink) |
No Life Poster Join Date: Apr 2010
Member: 1277468 Status: Offline Sonork: 100.1603661 Thanks Meter: 701 | successfull unlocked G1157 BY FG BOX............. successfull unlocked G1157 BY FG BOX............. Software engine version: 1.0.0.5472 Connect phone powered on ! Start auth ! SW Ver: REL_P1.2PU04V01.04 Imei: 358145032436??? Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_358145032436???_REL_P1.2PU04V01.04_12.11.53 _05.02.2011_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:33 BR:. SHABIR97 |
02-05-2011, 14:31 | #7688 (permalink) |
No Life Poster Join Date: Sep 2005 Location: -=HORIZON=-MobiSoft Rahwali GR Age: 38
Member: 181213 Status: Offline Sonork: 100.1586186 Thanks Meter: 201 | BB8900 unlocked: Searching for usb device ... Reading info ... IMEI: 353471033605524 Calculating ... MEP LOCK: MEP-04598-005 MEP1 [SIM]: 4091371409111413 MEP2 [NETWORK]: 3382799550880407 MEP3 [NETWORK SUBSET]: 6137771130110416 MEP4 [SERVICE PROVIDER]: 6724639546973747 MEP5 [CORPORATE]: 8945961398529991 How to enter codes in BlackBerry: 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2/MEPP2 (for NETWORK LOCK) or MEP4/MEPP4 (for SERVICE PROV LOCK) 9. Now it will ask to enter then mep code Done ! Time needed - 00:00:42 |
02-05-2011, 14:49 | #7689 (permalink) |
Temporary banned !! Join Date: Apr 2007
Member: 482214 Status: Offline Sonork: 100.1617896 Thanks Meter: 316 | ZTE F102 3G UNLOCK DONE Software engine version: 1.0.0.5949 Searching phone ... MODEL : QCOM SERIES 10 COMPILED DATE : Dec 2 2009 11:18:00 RELEASE DATE : Aug 26 2009 02:00:00 FIRMWARE INFO : H3G_GB_P607C3V2.0.0B04-S IMEI : 35674003202065-4 BLUETOOTH ADDR : F4 E4 70 1A 18 08 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 LOOKING SENSITIVE DATA; DATA FOUND; READING FW SIGN; READING NET DATA; READING NCK DATA; READING PUBLIC KEY; CHECKING SIGN; SIGN OK; LOCKED NET 0 (MCC: 234 MNC: 20) LOCKED NET 1 (MCC: 235 MNC: 94) READING; CALCULATING; ERASING; WRITING; UNLOCKED; RESET ! Time needed - 00:00:09 |
02-06-2011, 06:34 | #7690 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: SL3 LBF IN Kamoke(Gujranwala)
Member: 481915 Status: Offline Sonork: 100.1604233 Thanks Meter: 476 | Lg u310 unlocked log: Quote:
mianlinks | |
02-06-2011, 08:29 | #7691 (permalink) |
Member: 1277468 Status: Offline Sonork: 100.1603661 Thanks Meter: 701 | successfull unlocked UFONE T156................... successfull unlocked UFONE T156................... Software engine version: 1.0.0.5472 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.01 Imei: 35814603013???? Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_35814603013???_P1.2PU01V01.01_12.05.28_06.0 2.2011_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:26 BR:. SHABIR97 |
02-06-2011, 10:06 | #7692 (permalink) |
Member: 959010 Status: Offline Sonork: 100.1602440 Thanks Meter: 445 | Z100 unlock done Software engine version: 1.0.0.5455 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 352865041093832 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 A4 34 04 98 E7 08 9C 03 Flash ID(0): 00C2:22A7 Saved: ZTE_352865041093832_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_11.34.58_06.02.2011_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:44 |
02-06-2011, 12:12 | #7693 (permalink) |
No Life Poster Join Date: Apr 2009 Location: HM unlock fone mandi bahauddin
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | t156 unlock done Software engine version: 1.0.0.5444 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.01 Imei: 353081039280931 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_353081039280931_P1.2PU01V01.01_16.09.33_06. 02.2011_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:47 |
02-06-2011, 14:57 | #7694 (permalink) |
Member: 1277468 Status: Offline Sonork: 100.1603661 Thanks Meter: 701 | huawi G1157 unlock done............... huawei G1157 Software engine version: 1.0.0.5472 Connect phone powered on ! Start auth ! SW Ver: REL_P1.2PU04V01.04 Imei: 35633403821????? Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 00BF:234B Reading ... Saved: HUAWEI_35633403821>>>>>_REL_P1.2PU04V01.04_18.53.0 8_06.02.2011_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:01:27 br:. shabir97 |
02-06-2011, 15:34 | #7695 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Pakistan Age: 36
Member: 748029 Status: Offline Sonork: 100.1603742 Thanks Meter: 1,822 | I Have Unlocked G2158 & T156 Successfully Unlocked.I Have Lost G2158,s Logs. Software engine version: 1.0.0.5419 Connect phone powered on ! Start auth ! SW Ver: P1.2PU01V01.02 Imei: 358146031254120 Getting config data; Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:22C4 Reading ... Saved: HUAWEI_358146031254120_P1.2PU01V01.02_19.26.46_06. 02.2011_PARTIAL.bin Erasing ... Writing ... Unlocked ! Remove battery and put back ! Time needed - 00:00:48 B,R. |
