06-30-2009, 14:15 | #796 (permalink) |
No Life Poster Join Date: Aug 2006 Location: SPAIN-----UK
Member: 333439 Status: Offline Sonork: 100.1589101 Thanks Meter: 623 | Kf310 ynlock succesfull COMPILED DATE : Dec 11 2008 11:43:00 RELEASE DATE : Nov 28 2008 08:00:00 FIRMWARE INFO : KF310-MSM6245-V10b-NOV-28-2008-XX IMEI : 35423902730645-1 BLUETOOTH ADDR : 81 3E 13 A9 22 00 MEMORY ID : 0098:00C1 MEMORY NAME : toshiba_ty9000a800jogg MEMORY INFO : 0800:0040:02FD INIT NAND ROUTINES; NAND INIT MADE; READING SECURITY AREA; READING SEC DATA; SECURITY TESTS PASSED ! UNLOCKING PASSED ! LOCK HASH WRITTEN; UNLOCKED ! Time needed - 00:00:23 |
06-30-2009, 14:30 | #797 (permalink) |
Freak Poster Join Date: Aug 2008 Location: Cote d'Ivoire
Member: 841640 Status: Offline Thanks Meter: 86 | ZTE F866 succesfully unlocked (Pack 5) Using cable FGOLD-055 Software engine version: 1.0.0.2454 Searching phone ... MODEL : QCOM SERIES 6 COMPILED DATE : Dec 3 2005 16:34:00 RELEASE DATE : Sep 26 2001 01:30:00 FIRMWARE INFO : P600B2V4.0.0B11_SEC IMEI : 35753900036841-1 BLUETOOTH ADDR : 00 00 00 00 00 00 MEMORY ID : 00EC:0076 MEMORY NAME : samsung_kag00j007m MEMORY INFO : 0200:0020:0800 INIT NAND ROUTINES; NAND INIT MADE; READING; ERASING; WRITING; READING; ERASING; WRITING; UNLOCKED ! RESET ! Time needed - 00:00:10 |
07-01-2009, 05:16 | #798 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Kotla arab ali khan Age: 56
Member: 623703 Status: Offline Sonork: 100.1614330 Thanks Meter: 439 | 8320 blackberry unlock ok fg Searching for usb device ... Reading info ... IMEI: 358264010694792 Calculating ... MEP2 CODE: 6179570332791522 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:41 |
07-01-2009, 08:03 | #799 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Sydney
Member: 153695 Status: Offline Sonork: srkhan Thanks Meter: 788 | KU990GO unlock done Software engine version: 1.0.0.2454 Searching phone ... MODEL : KU990 COMPILED DATE : Aug 27 2008 11:35:00 RELEASE DATE : Oct 5 2007 17:00:00 FIRMWARE INFO : KU990GO-MSM6280-V10a-AUG-12-2008-XX IMEI : 35493502441056-4 BLUETOOTH ADDR : 3E 42 EA E3 1F 00 MEMORY ID : 0098:00CA MEMORY NAME : toshiba_tya000bc00bogg MEMORY INFO : 0800:0040:06C3 INIT NAND ROUTINES; NAND INIT MADE; READING SECURITY AREA; READING SEC DATA; SECURITY TESTS PASSED ! UNLOCKING PASSED ! LOCK HASH WRITTEN; UNLOCKED ! Time needed - 00:00:05 |
07-01-2009, 23:58 | #800 (permalink) |
Junior Member Join Date: Jan 2009
Member: 952775 Status: Offline Sonork: elzorro Thanks Meter: 18 | Successfully Unlocked Blackberry 9530 Hi, guys Successfully unlocked BlackBerry 9530 Searching for usb device ... Reading info ... IMEI: 359483028793425 Calculating ... MEP2 CODE: 5739441571149403 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:21 |
07-02-2009, 09:01 | #801 (permalink) |
No Life Poster Join Date: Mar 2001 Location: ALBANIA(Tirana) Age: 51
Member: 3617 Status: Offline Thanks Meter: 579 | Blackberry 8900 T Mobile Searching for usb device ... Reading info ... IMEI: 358453023971772 Calculating ... MEP2 CODE: 6563237292141376 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:14 |
07-02-2009, 15:31 | #802 (permalink) |
No Life Poster Join Date: May 2007 Age: 37
Member: 500858 Status: Offline Sonork: 1589054 Thanks Meter: 392 | kp100 Press power on ! Starting communication ... Platform: E-Gold Lite ... Preloader sent .... Loader sent .... Flash ID(0): 0001:011A Bypassing security ... LOCK: ACTIVE IMEI: 355882022427647 UNLOCK CODE: 32919817 Saved: INFINEON_18.16.06_18.06.2009_EEP.bin REMOVE BATTERY AND PUT BACK ! Time needed - 00:00:32 |
07-02-2009, 15:31 | #803 (permalink) |
Member: 500858 Status: Offline Sonork: 1589054 Thanks Meter: 392 | kp170 Press power on button ... Phone detected ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Requesting baudrate change ... Baudrate changed ... Flash ID(0): 0001:227E:3C00 Searching flash image ... Reading flash image ... Unlock finished ! Done ! Time needed - 00:00:23 |
07-02-2009, 15:33 | #804 (permalink) |
Member: 500858 Status: Offline Sonork: 1589054 Thanks Meter: 392 | f866 tware engine version: 1.0.0.2454 Searching phone ... MODEL : QCOM SERIES 6 COMPILED DATE : Dec 3 2005 16:34:00 RELEASE DATE : Sep 26 2001 01:30:00 FIRMWARE INFO : P600B2V4.0.0B11_SEC IMEI : 35753900209138-3 BLUETOOTH ADDR : 00 00 00 00 00 00 MEMORY ID : 00EC:0076 MEMORY NAME : samsung_kag00j007m MEMORY INFO : 0200:0020:0800 INIT NAND ROUTINES; NAND INIT MADE; READING; ERASING; WRITING; READING; ERASING; WRITING; UNLOCKED ! RESET ! Time needed - 00:00:12' |
07-02-2009, 15:36 | #805 (permalink) |
Member: 500858 Status: Offline Sonork: 1589054 Thanks Meter: 392 | MODEL : U880 Software engine version: 1.0.0.2454 Searching phone ... MODEL : U880 COMPILED DATE : Feb 20 2006 09:02:00 RELEASE DATE : Jul 3 2005 16:00:00 FIRMWARE INFO : U880-MSM6250-V10b_wm-FEB-08-2006-H3G-UK IMEI : 35705000631662-8 BLUETOOTH ADDR : 91 9A 09 56 12 00 MEMORY ID : 0098:0079 MEMORY NAME : toshiba_ty9000ac10aobg MEMORY INFO : 0200:0020:1980 LOADING INIT DATA; RESETTING PHONE ! WAITING FOR PHONE TO POWER ON 30 SEC; PHONE ONLINE; SW VERSION: [OK] MODULE ERROR IMEI: [OK] 35705000631662800 BLUETOOTH ADDR: [OK] 919A09561200 PLAYING MUSIC ... WAIT; DOING CONFIG; INJECTING VODKA; INJECTING JUICE; DRINKING; DANCING; STAT: OFF NAND UNLOCK DONE; PROCESS STARTED; READING; ERASING; WRITING; READING; ERASING; WRITING; UNLOCKED ! Time needed - 00:01:20 |
07-02-2009, 15:39 | #806 (permalink) |
Member: 500858 Status: Offline Sonork: 1589054 Thanks Meter: 392 | S1 Software engine version: 1.0.0.2454 Searching phone ... MODEL : QCOM SERIES 2 COMPILED DATE : Nov 28 2007 09:22:00 RELEASE DATE : Aug 10 2007 08:00:00 FIRMWARE INFO : M6260A-KYRZ-2.1.3022 IMEI : 35776701777609-0 BLUETOOTH ADDR : 8C 1C 08 40 12 00 MEMORY ID : 00AD:0036 MEMORY NAME : hynix_hycosehomf3p MEMORY INFO : 0200:0020:06BD INIT NAND ROUTINES; NAND INIT MADE; PROCESS STARTED; READING; ERASING; WRITING; RESET ! Time needed - 00:00:06 |
07-02-2009, 15:42 | #807 (permalink) |
Member: 500858 Status: Offline Sonork: 1589054 Thanks Meter: 392 | kp170 Press power on button ... Phone detected ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Requesting baudrate change ... Baudrate changed ... Flash ID(0): 0001:227E:3C00 Searching flash image ... Reading flash image ... Unlock finished ! Done ! Time needed - 00:00:28 |
07-03-2009, 06:41 | #808 (permalink) |
Freak Poster Join Date: Apr 2009 Location: manila
Member: 1003463 Status: Offline Thanks Meter: 67 | LG u310 unlock successfuly Software engine version: 1.0.0.2440 Searching phone ... MODEL : U310 COMPILED DATE : Oct 12 2006 14:55:00 RELEASE DATE : May 9 2006 17:00:00 FIRMWARE INFO : U310-MSM6250A-V10a-OCT-12-2006-H3G-IT IMEI : 35281801320164-4 BLUETOOTH ADDR : AF 51 6F A1 19 00 MEMORY ID : 0098:0076 MEMORY NAME : toshiba_ty90009800cogg MEMORY INFO : 0200:0020:0900 LOADING INIT DATA; RESETTING PHONE ! WAITING FOR PHONE TO POWER ON 30 SEC; PHONE ONLINE; SW VERSION: [OK] MODULE ERROR IMEI: [OK] 35281801320164400 BLUETOOTH ADDR: [OK] AF516FA11900 PLAYING MUSIC ... WAIT; DOING CONFIG; INJECTING VODKA; INJECTING JUICE; DRINKING; DANCING; STAT: ON NAND UNLOCK DONE; PROCESS STARTED; READING; ERASING; WRITING; READING; ERASING; WRITING; UNLOCKED ! Time needed - 00:01:30 |
07-03-2009, 08:23 | #809 (permalink) |
Banned Join Date: Jun 2009
Member: 1058944 Status: Offline Sonork: 100.1582347 Thanks Meter: 218 | OT-E205 unlock Press power on shortly ... Starting communication ... BootRom v04.11 Sending certificate ... Sending preloader ... Sending EBOLA ViruS ! Phone infected. RSA Defeated ! Loader version: FuriouSTeaM GSM DEVELOPEMENT Trying baud rate change ... Baud rate changed ok ! FLASH 1 ID: 0001:227E 0A01 MODE: E100/E105/E157/E158/E159/E160/E161 E200/E205/E220/E230/E252/E256/E257 E259/E260/E265/C61/C62 MCU ID: 0F3803E5D09703F7 ALGO TYPE: 01 OTP IMEI: 359831004089996 PROVIDER: E205X-2ARGGB1 FW INFO: 67CBAA0105 Phone unlocked. Phone reseted ! Time needed - 00:00:06 thanks FG. |
07-03-2009, 11:48 | #810 (permalink) |
No Life Poster Join Date: Nov 2008 Location: tunisia
Member: 898887 Status: Offline Sonork: ramazoti Thanks Meter: 210 | MTV3.4 UNLOCK OK Searching phone ... MODEL : M6275A-OEMS Download mode entered ... Loading bootloader ... Requesting random data ... Completed ... Memory Info: 00EC:0078 Nand init done; Reading; Imei : 35749402011815-8 Reading; SP saved to: SP_35749402011815_5E4_12.43.24_03.07.2009_HUAWEI.b in Erasing; Writing; Unlocked ! Done ! Time needed - 00:00:23 |
