01-15-2012, 18:10 | #10246 (permalink) |
Cheater -Don't Deal with him- Join Date: Sep 2010
Member: 1390802 Status: Offline Thanks Meter: 1,101 | Phone detected ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Requesting baudrate change ... Baudrate changed ... Flash ID(0): 0001:227E:3C00 Searching flash image ... Reading flash image ... Unlock finished ! Done ! Time needed - 00:00:25 |
01-15-2012, 18:11 | #10247 (permalink) |
Member: 1390802 Status: Offline Thanks Meter: 1,101 | Kp170 unlock done fg undefined Press power on button ... Phone detected ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Requesting baudrate change ... Baudrate changed ... Flash ID(0): 0001:227E:3C00 Searching flash image ... Reading flash image ... Unlock finished ! Done ! Time needed - 00:00:19 |
01-15-2012, 18:11 | #10248 (permalink) |
Member: 1390802 Status: Offline Thanks Meter: 1,101 | >>again sussessfully unlock done 2 lg u900 with furious gold>> Here is log: Software engine version: 1.0.0.2003 Searching phone ... MODEL : U900 COMPILED DATE : Jan 23 2007 10:39:00 RELEASE DATE : Jan 23 2007 12:00:00 FIRMWARE INFO : U900-MSM6250A-V11g-JAN-23-2007-H3G-IT IMEI : 35930400303364-7 BLUETOOTH ADDR : 9E 6E 3D 56 12 00 MEMORY ID : 0098:0079 MEMORY NAME : toshiba_ty9000ac10aobg MEMORY INFO : 0200:0020:1980 LOADING INIT DATA; RESETTING PHONE ! WAITING FOR PHONE TO POWER ON 30 SEC; PHONE ONLINE; SW VERSION: [OK] MODULE ERROR IMEI: [OK] 35930400303364700 BLUETOOTH ADDR: [OK] 9E6E3D561200 PLAYING MUSIC ... WAIT; DOING CONFIG; INJECTING VODKA; INJECTING JUICE; DRINKING; DANCING; STAT: ON NAND UNLOCK DONE; PROCESS STARTED; READING; ERASING; WRITING; READING; ERASING; WRITING; UNLOCKED ! Time needed - 00:01:18 |
01-15-2012, 18:11 | #10249 (permalink) |
Member: 1390802 Status: Offline Thanks Meter: 1,101 | Software engine version: 1.0.0.2003 Searching phone ... MODEL : U900 COMPILED DATE : Jan 23 2007 10:39:00 RELEASE DATE : Jan 23 2007 12:00:00 FIRMWARE INFO : U900-MSM6250A-V11g-JAN-23-2007-H3G-IT IMEI : 35930400141840-2 BLUETOOTH ADDR : 38 F7 36 56 12 00 MEMORY ID : 0098:0079 MEMORY NAME : toshiba_ty9000ac10aobg MEMORY INFO : 0200:0020:1980 LOADING INIT DATA; RESETTING PHONE ! WAITING FOR PHONE TO POWER ON 30 SEC; PHONE ONLINE; SW VERSION: [OK] MODULE ERROR IMEI: [OK] 35930400141840200 BLUETOOTH ADDR: [OK] 38F736561200 PLAYING MUSIC ... WAIT; DOING CONFIG; INJECTING VODKA; INJECTING JUICE; DRINKING; DANCING; STAT: ON NAND UNLOCK DONE; PROCESS STARTED; READING; ERASING; WRITING; READING; ERASING; WRITING; UNLOCKED ! Time needed - 00:01:13 |
01-15-2012, 18:12 | #10250 (permalink) |
Member: 1390802 Status: Offline Thanks Meter: 1,101 | again succsesfully unlock lg u890 with furious gold Here is log: Software engine version: 1.0.0.2003 Searching phone ... MODEL : U890 COMPILED DATE : Jun 7 2006 15:56:00 RELEASE DATE : Jun 7 2006 17:00:00 FIRMWARE INFO : U890-MSM6250A-V10a_wm-JUN-07-2006-H3G-UK IMEI : 35921300328608-1 BLUETOOTH ADDR : 5C 34 45 56 12 00 MEMORY ID : 0098:0079 MEMORY NAME : toshiba_ty9000ac10aobg MEMORY INFO : 0200:0020:1980 LOADING INIT DATA; RESETTING PHONE ! WAITING FOR PHONE TO POWER ON 30 SEC; PHONE ONLINE; SW VERSION: [OK] MODULE ERROR IMEI: [OK] 35921300328608100 BLUETOOTH ADDR: [OK] 5C3445561200 PLAYING MUSIC ... WAIT; DOING CONFIG; INJECTING VODKA; INJECTING JUICE; DRINKING; DANCING; STAT: ON NAND UNLOCK DONE; PROCESS STARTED; READING; ERASING; WRITING; READING; ERASING; WRITING; UNLOCKED ! Time needed - 00:01:13 |
01-15-2012, 18:12 | #10251 (permalink) |
Member: 1390802 Status: Offline Thanks Meter: 1,101 | Press power on ! Starting communication ... Platform: S-Gold3 ... Preloader sent .... Loader sent .... CODE: 7625700862919340 Power on phone with original sim. Type 2945#*71001# and enter code. Done ! Time needed - 00:00:17 |
01-15-2012, 18:12 | #10252 (permalink) |
Member: 1390802 Status: Offline Thanks Meter: 1,101 | Software engine version: 1.0.0.2003 Searching phone ... MODEL : U370 COMPILED DATE : Dec 20 2007 15:20:00 RELEASE DATE : May 17 2007 14:00:00 FIRMWARE INFO : U370W-MSM6245-V10c-DEC-20-2007-XX IMEI : 35839101135345-6 BLUETOOTH ADDR : 53 E3 BA 75 1E 00 MEMORY ID : 0098:00C1 MEMORY NAME : toshiba_ty9000a800jogg MEMORY INFO : 0800:0040:0308 INIT NAND ROUTINES; NAND INIT MADE; READING SECURITY AREA; READING SEC DATA; SECURITY TESTS PASSED ! UNLOCKING PASSED ! LOCK HASH WRITTEN; UNLOCKED ! Time needed - 00:00:09 |
01-15-2012, 18:12 | #10253 (permalink) |
Member: 1390802 Status: Offline Thanks Meter: 1,101 | Searching for usb device ... Reading info ... IMEI: 358264019739648 Calculating ... MEP2 CODE: 7591340541727059 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:13 |
01-15-2012, 18:13 | #10254 (permalink) |
Member: 1390802 Status: Offline Thanks Meter: 1,101 | Searching for usb device ... Reading info ... IMEI: 359158021185593 Calculating ... MEP2 CODE: 2438139050358695 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:12 |
01-15-2012, 18:13 | #10255 (permalink) |
Member: 1390802 Status: Offline Thanks Meter: 1,101 | Software engine version: 1.0.0.2003 Searching phone ... MODEL : KU990 COMPILED DATE : Sep 9 2008 18:27:00 RELEASE DATE : Sep 9 2008 17:00:00 FIRMWARE INFO : KU990GO-MSM6280-V10i-SEP-09-2008-XX IMEI : 35994402455XXX-X BLUETOOTH ADDR : E3 0D AE A9 22 00 MEMORY ID : 0098:00CA MEMORY NAME : toshiba_tya000bc00bogg MEMORY INFO : 0800:0040:06C3 INIT NAND ROUTINES; NAND INIT MADE; READING SECURITY AREA; READING SEC DATA; SECURITY TESTS PASSED ! UNLOCKING PASSED ! LOCK HASH WRITTEN; UNLOCKED ! Time needed - 00:00:15 |
01-15-2012, 18:14 | #10256 (permalink) |
Member: 1390802 Status: Offline Thanks Meter: 1,101 | Successfully Unlock km900 first in tunisia unlock km900: Press power on ! Starting communication ... Platform: S-Gold3 ... Preloader sent .... Loader sent .... CODE: 1967300664858915 Power on phone with original sim. Type 2945#*71001# and enter code. Done ! Time needed - 00:00:27 |
01-15-2012, 18:14 | #10257 (permalink) |
Member: 1390802 Status: Offline Thanks Meter: 1,101 | lg u990 unlocked success unlocked u990. Software engine version: 1.0.0.2003 Searching phone ... MODEL : U990 COMPILED DATE : Jul 7 2008 13:03:00 RELEASE DATE : Jan 28 2008 17:00:00 FIRMWARE INFO : U990-MSM6280-V10b-JAN-28-2008-XX IMEI : 35493502XXXXX-X BLUETOOTH ADDR : 1B 4C C7 E3 1F 00 MEMORY ID : 0098:00CA MEMORY NAME : toshiba_tya000bc00bogg MEMORY INFO : 0800:0040:06C3 INIT NAND ROUTINES; NAND INIT MADE; READING SECURITY AREA; READING SEC DATA; SECURITY TESTS PASSED ! UNLOCKING PASSED ! LOCK HASH WRITTEN; UNLOCKED ! Time needed - 00:00:08 |
01-15-2012, 18:15 | #10258 (permalink) |
Member: 1390802 Status: Offline Thanks Meter: 1,101 | Momo Disegn MD2 unlock ok Software engine version: 1.0.0.2003 Searching phone ... MODEL : QCOM SERIES 2 COMPILED DATE : Sep 5 2007 22:23:00 RELEASE DATE : Apr 13 2007 15:00:00 FIRMWARE INFO : P621C1V1.1.0B01 IMEI : 35714401023005-5 BLUETOOTH ADDR : F5 D3 17 EB 15 00 MEMORY ID : 00AD:0078 MEMORY NAME : hynix_hyg0sgh0mf3 MEMORY INFO : 0200:0020:133B INIT NAND ROUTINES; NAND INIT MADE; PROCESS STARTED; READING; ERASING; WRITING; UNLOCK CODE: 9449999913411132 ENTER USING: *983*865625# RESET ! Time needed - 00:00:23 |
01-15-2012, 18:15 | #10259 (permalink) |
Member: 1390802 Status: Offline Thanks Meter: 1,101 | Kf300 Press power on button ... Phone detected ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Requesting baudrate change ... Baudrate changed ... Flash ID(0): 0089:887E:0489 Searching flash image ... Reading flash image ... Unlock finished ! Done ! Time needed - 00:00:42 |
01-15-2012, 18:15 | #10260 (permalink) |
Member: 1390802 Status: Offline Thanks Meter: 1,101 | bb8100 unlocking done Searching for usb device ... Reading info ... IMEI: 352127014694611 Calculating ... MEP2 CODE: 55129059 How to enter codes in BlackBerry 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Done ! Time needed - 00:00:34 thanx furious team |
