02-24-2012, 20:00 | #10426 (permalink) |
Freak Poster Join Date: Dec 2007
Member: 642071 Status: Offline Thanks Meter: 54 | Lg gs170 unlock done Starting communication ... Platform: A-GOLDRadio XMM2130 ... Preloader sent .... Loader sent .... Flash ID(0): 0089:8881 Bypassing security ... UNLOCK CODES: NETWORK: 7223850231220718 NETWORK SUBSET: 8112635906915553 SERVICE PROV.: 7591212781245236 CORPORATE: 3967021146782173 SIM/USIM: 7100806305215495 Saved: INFINEON_XMM2130_13.38.53_24.02.2012_EEP.bin REMOVE BATTERY AND PUT BACK ! Done ! Time needed - 00:00:58 |
02-24-2012, 21:53 | #10427 (permalink) |
Member: 642071 Status: Offline Thanks Meter: 54 | Zte gr225 at&t unlock done > imei: 01229********** > nck: 697790017195 > spck: 300828817687 for some models type *983*8284# or ###825*09# (without sim) to enter the n.p. Code. |
02-25-2012, 07:39 | #10428 (permalink) |
No Life Poster Join Date: Feb 2012 Location: lalamusa pakistan Age: 39
Member: 1724303 Status: Offline Sonork: 1611265 Thanks Meter: 70 | alcatel ot 708 flash done Make your handset power off, plug in the UART cable! Product: OT-708 Load DA file... Load AUTH file... Load flash image file... Start to connect the handset, keep pressing the power on key! Start to flash handset image... IMEI: 359081033117067 Provider ID: 708X-2EVDDE1 Security information version: XN17FB91 Downloading flash image now... Formatting file system now... Proceeding post process now... Proceeding post process now... Flash full handset image successfully! |
02-25-2012, 08:39 | #10429 (permalink) |
No Life Poster Join Date: Apr 2009 Location: HM unlock fone mandi bahauddin
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | siemens CF75 unlock done Shutdown phone... Starting service mode Press POWER button shortly Model: CF75 v10 IMEI: 356909002604215 Exploiting.... Shutdown phone... Press POWER button shortly FlashID: 0089:880D Set port speed. ! Can't set port speed Shutdown phone... Starting service mode Press POWER button shortly Can't init service mode. Try to restore Bootcore.. Shutdown phone... Press POWER button shortly FlashID: 0089:880D Set port speed. ESN: 8DCFA496 OTPIMEI: 356909002604215 Memory size: 32Mb Read memory map. Reading EEFULL. IMEI[5009]: 356909002604215 Unlocking Writing back EEFULL Restoring Bootcore All done! |
02-25-2012, 08:40 | #10430 (permalink) |
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | siemens M65 unlock done Shutdown phone... Starting service mode Press POWER button shortly Model: M65 v16 IMEI: 000000000000000 Exploiting.... Shutdown phone... Press POWER button shortly FlashID: 0089:880D Set port speed. ESN: E42E3513 OTPIMEI: 353667008809641 Memory size: 32Mb Read memory map. Reading EEFULL. IMEI[5009]: 353667008809641 Unlocking Writing back EEFULL Restoring Bootcore All done! |
02-26-2012, 11:52 | #10431 (permalink) |
Freak Poster Join Date: Feb 2011 Location: moon Age: 37
Member: 1523083 Status: Offline Sonork: 100.1609029 Thanks Meter: 141 | Make your handset power off, plug in the UART cable! Product: OT-808 Load DA file... Load AUTH file... Start to connect the handset, keep pressing the power on key! Start to read security information from handset... IMEI: 356389035671855 Security file: C:\Program Files (x86)\FURIOUS-GOLD\PACK8\Alcatel\Security\BackupSecurityFile\808 X-2AALFR1 Read security information successfully! Start code calculate... Product: OT-808 IMEI: 356389035671855 Security file: C:\Program Files (x86)\FURIOUS-GOLD\PACK8\Alcatel\Security\BackupSecurityFile\808 X-2AALFR1 NCK: NSCK: SPCK: PCK: Code calculate finished successfully! |
02-26-2012, 12:28 | #10432 (permalink) |
No Life Poster Join Date: Apr 2010 Location: pakistan Age: 48
Member: 1275418 Status: Offline Thanks Meter: 432 | pak 8 working Product: Vodafone555 Provider ID: V555X-2[X=A,B]VDES1 IMEI: 356694045187838 Start code calculate... NCK:2477952292 NSCK: SPCK: PCK: Code calculate finished successfully! |
02-26-2012, 12:28 | #10433 (permalink) |
Member: 1275418 Status: Offline Thanks Meter: 432 | Product: OT-363 Provider ID: 363X-2[X=A,B,C,D]VDES1 IMEI: 359675027366562 Start code calculate... NCK:0148936621 NSCK: SPCK: PCK: Code calculate finished successfully! |
02-26-2012, 12:29 | #10434 (permalink) |
Member: 1275418 Status: Offline Thanks Meter: 432 | Product: OT-585 Provider ID: 585X-2[X=A,B,C,D]RGFR3 IMEI: 356888042244622 Start code calculate... NCK:0300332381 NSCK: SPCK: PCK: Code calculate finished successfully! COMM OPENED 62 ! |
02-26-2012, 12:29 | #10435 (permalink) |
Member: 1275418 Status: Offline Thanks Meter: 432 | Product: OT-355 Load DA file... Load AUTH file... Load golden security file... Start to connect the handset, keep pressing the power on key! Start to rebuild security region... IMEI: 353923048023937 Security file: C:\Program Files\FURIOUS-GOLD\PACK8\Alcatel\Security\BackupSecurityFile\355 X-2BNRFR1 Rebuild security region successfully! |
02-26-2012, 12:30 | #10436 (permalink) |
Member: 1275418 Status: Offline Thanks Meter: 432 | Product: OT-355 IMEI: 353902304802393 Security file: C:\Program Files\FURIOUS-GOLD\PACK8\Alcatel\Security\BackupSecurityFile\355 X-2BNRFR1 NCK:3001994591 NSCK: SPCK:0483116905 PCK: Code calculate finished successfully! |
02-26-2012, 12:30 | #10437 (permalink) |
Member: 1275418 Status: Offline Thanks Meter: 432 | Product: OT-585 Provider ID: 585X-2[X=A,B,C,D]NRFR1 IMEI: 356888041675248 Start code calculate... NCK:2052098453 NSCK: SPCK:3232359640 PCK: Code calculate finished successfully! |
02-26-2012, 12:30 | #10438 (permalink) |
Member: 1275418 Status: Offline Thanks Meter: 432 | Time needed - 00:02:30 COMM OPENED 62 ! BAUD SET ! AUTH MADE ! SW VERSION: REL_C1.2PU01V01.05 TEST MODE STATUS: OFF SIM STATUS: OFF IMEI: 356820042153503 SN: 0 CONFIG DONE; DEFEATING PROTECTION; DEFEATED; WORKING; SIM_LOCK REMOVED ! |
02-26-2012, 12:31 | #10439 (permalink) |
Member: 1275418 Status: Offline Thanks Meter: 432 | Software engine version: 1.0.0.6047 Connect phone powered on ! Start auth ! SW Ver: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Imei: 352865041014002 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader started .. MCU ID: 45 E5 24 35 04 98 67 08 9C 0B Flash ID(0): 00C2:22A7 Saved: ZTE_352865041014002_E-PK-CMPAK-P108A34FM(S)V1.0.0B03_04.30.10_09.02.2012_PARTIAL. bin Unlocked ! Remove battery and put back ! Time needed - 00:01:48 Searching phone ... MODEL : M6275A-OEMSBL Download mode entered ... Loading bootloader ... Memory Info: 00AD:0078 Requesting random data ... Sending data ... Authorisation started ... Authorisation passed ... Unlock Code: 7777777777777777 Done ! Time needed - 00:00:15 |
02-27-2012, 05:47 | #10440 (permalink) |
Member: 1724303 Status: Offline Sonork: 1611265 Thanks Meter: 70 | Zong G 2100 unlock done COMM OPENED 5 ! BAUD SET ! AUTH MADE ! SW VERSION: HUAWEI G2100V100R001PAKC19B102SEC TEST MODE STATUS: OFF SIM STATUS: OFF IMEI: 351633040523642 SN: 0 CONFIG DONE; DEFEATING PROTECTION; DEFEATED; WORKING; SIM_LOCK REMOVED ! TIME NEEDED - 00:00:23 |
