05-22-2014, 11:56 | #11836 (permalink) |
Freak Poster Join Date: Oct 2011 Location: Almoradi (ALICANTE) . SPAIN
Member: 1677266 Status: Offline Thanks Meter: 90 | Searching phone; Phone detected (@oem282.inf,%mtk_preloader%;PreLoader USB VCOM Port) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on Android Gadget VCOM Driver (COM185); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6582, E01 Sw version: MOLY.WR8.W1315.MD.WG.MP.V7.F2.P1 Hw Version: WIND82_WET_JB5_HSPA_HW Reading phone info; IMEI: 86xxxxxxxxxxxxx4-9 Reading simlock info; Locked to: C1C-1C code_cat_n: 12345678 enabled: no tries: 5 code_cat_ns: 35574126 enabled: yes tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Time needed - 00:00:49 |
05-24-2014, 12:33 | #11837 (permalink) |
No Life Poster Join Date: Apr 2004 Location: Skopje , Macedonia Age: 40
Member: 61851 Status: Offline Sonork: 100.1604862 Thanks Meter: 117 | alcatell idol 2 direct unlock sucess , for better detection hold both volume up and down while pluging usb cable it should detect it smoothly and when switch to high speed DA com port release them Using library Brom_DLL_v7.1347.5 Searching phone; Phone detected (MTK USB Port) Preparing to start flash mode; Connecting; Downloading DA; Initializing; Rid: 72e0b4560d4210c47bae4502682a22f1 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (MediaTek DA USB VCOM Port) TRYING TO OPEN COM94; DEVICE INFO: BB CHIP: MT6582_S00 [CA00, 00, 6582, 05] HW_STORAGE_EMMC: 0x4B000115 0x4D565837 0x9F2F0142 0xC5B00053 [SIZE=0x1D2880000] IMEI1 [OTP 0001]: 8XXXXX-02-XXXXXX-9 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 6037Y-2AALEU1 USRDATA INFO: 0x61B80000 SIZE: 0x70D00000 Searching data; Locked to: 294-03 code_cat_n: 35505991 enabled: yes tries: 7 code_cat_ns: 91558255 enabled: no tries: 10 code_cat_sp: 07376845 enabled: no tries: 10 code_cat_c: 03512112 enabled: no tries: 10 code_cat_sim: 49639890 enabled: no tries: 10 code_cat_ns_sp: 53297761 enabled: no tries: 5 code_cat_sim_c: 86817778 enabled: no tries: 5 Phone unlocked; Remove battery and cable; Time needed - 00:00:35 |
05-26-2014, 16:57 | #11838 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Paris Age: 48
Member: 1202782 Status: Offline Sonork: 100.1608261 Thanks Meter: 634 | Using library Brom_DLL_v7.1347.5 Searching phone; Phone detected (@oem141.inf,%mtk_preloader%;PreLoader USB VCOM Port) Preparing to start flash mode; Connecting; Downloading DA; Initializing; Rid: 902fa317f837cc9c1c05a3baa7ea2c2a Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem141.inf,%mtk_sp_da%;DA USB VCOM Port) TRYING TO OPEN COM76; DEVICE INFO: BB CHIP: MT6572_S00 [CA01, 00, 6572, FF] HW_STORAGE_EMMC: 0x4E000115 0x4D5A5735 0x27700142 0xB7B0C8CE [SIZE=0xE9480000] IMEI1 [OTP 0001]: 863283-02-207672-1 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 4015X-2ARGRO3 USRDATA INFO: 0x5D680000 SIZE: 0x8BE00000 Searching data; Locked to: 226-10 code_cat_n: 1634861537 enabled: yes tries: 8 code_cat_ns: 0503895204 enabled: no tries: 10 code_cat_sp: 1530139918 enabled: no tries: 10 code_cat_c: 5104563251 enabled: no tries: 10 code_cat_sim: 6725574679 enabled: no tries: 10 code_cat_ns_sp: 53297761 enabled: no tries: 5 code_cat_sim_c: 86817778 enabled: no tries: 5 Phone unlocked; Remove battery and cable; Time needed - 00:00:15 |
05-26-2014, 16:58 | #11839 (permalink) |
05-26-2014, 21:17 | #11840 (permalink) |
Member: 1677266 Status: Offline Thanks Meter: 90 | vodafone smart 4 785 unlock done Using library Brom_DLL_v7.1347.5 Searching phone; Phone detected (@oem282.inf,%mtk_preloader%;PreLoader USB VCOM Port) Preparing to start flash mode; Connecting; Downloading DA; Initializing; Rid: 5a009770227e2a470f0cdb938ee89b8a Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem284.inf,%mtk_sp_da%;MediaTek DA USB VCOM Port) TRYING TO OPEN COM216; DEVICE INFO: BB CHIP: MT6572_S00 [CA01, 00, 6572, FF] HW_STORAGE_EMMC: 0x30000111 0x39473430 0xD89C1030 0x1FA08630 [SIZE=0xEC480000] IMEI1 [OTP 0001]: 359729-05-113994-8 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: V785-2AVDES1 USRDATA INFO: 0x61B80000 SIZE: 0x8A900000 Searching data; Locked to: 214-01 code_cat_n: 17705712 enabled: yes tries: 10 code_cat_ns: 03851936 enabled: no tries: 10 code_cat_sp: 02689844 enabled: no tries: 10 code_cat_c: 03282629 enabled: no tries: 10 code_cat_sim: 16625009 enabled: no tries: 10 code_cat_ns_sp: 53297761 enabled: no tries: 5 code_cat_sim_c: 86817778 enabled: no tries: 5 Phone unlocked; Remove battery and cable; Time needed - 00:00:15 |
The Following User Says Thank You to Movileuropa For This Useful Post: |
05-29-2014, 14:59 | #11841 (permalink) |
Member: 1202782 Status: Offline Sonork: 100.1608261 Thanks Meter: 634 | Unlock sfr 1180 with succes Using library Brom_DLL_v5.1316.1 Searching phone; (for some models keep SPACE or * (STAR) key pressed before inserting the cable) Phone detected (@oem142.inf,%mtk6218%;MTK USB Port) Preparing to start meta mode; Meta mode entered; Baseband Chip: MT6260 Sw version: V05_M131030_UL18_SFR1180_MP Hw Version: SAGETEL60A_12864_11B_HW Reading phone info; IMEI: 359562-05-025858-7 Reading security; Done; Checking; Preparing; Writing security; Phone unlocked; Remove battery and cable; Time needed - 00:00:18 |
The Following User Says Thank You to Nadoui For This Useful Post: |
05-31-2014, 16:13 | #11843 (permalink) |
Cheater -Don't Deal with him- Join Date: Dec 2013 Location: XK Age: 26
Member: 2089356 Status: Offline Sonork: Threema: 3N5W6VV9 Thanks Meter: 520 | Sagem MY 300C Press power on shortly ... Starting communication ... MCU ID: 2030001241665DC10000000000008845 ROM HASH: 62FB6505AC902905678D99DD748702EE ROM VER: 05.02 Authorising ... Sending preloader ... Exploiting ... Preloader started ... Sending applet ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Changing baudrate ... Flash ID(0): 0001:327E:4300 Reading unbinded data; Unbinded flash data done; Unbinded eeprom data done; Plain datadone; Model: my300C Hash: 000034AC Algo: 05 Firmware: LI5,PJ: 280907 1049 Imei: 355437012486580 Phone code: 0000 Prod. code: 253018030 Id calculation done; CODES: NET LO CODE: 1916833981 NET HI CODE: 0847287165 DIRECT UNLOCK: OK Done ! Time needed - 00:02:51 |
06-02-2014, 08:29 | #11844 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Pakistan
Member: 570093 Status: Offline Thanks Meter: 1,067 | Motorola mb200 succesful unlock. Software engine version: 1.0.0.8781 Searching phone ... MODEL : QCOM SERIES 18 COMPILED DATE : Jul 1 2010 14:27:00 RELEASE DATE : May 5 2010 02:00:00 FIRMWARE INFO : M76XX-SDCBALUM-63805036 IMEI : 3567000309xxxx-0 BLUETOOTH ADDR : 00 26 BA 76 A2 3C LOADING DATA; DONE; INIT NAND ROUTINES; NAND INIT MADE; READING SEC; NETWORK: 27518784 INSERT A RESTRICTED SIM INSIDE AND ENTER UNLOCK CODE. SIM_LOCK REMOVED ! RESET ! Time needed - 00:00:52 |
06-02-2014, 16:48 | #11845 (permalink) |
No Life Poster Join Date: May 2010 Location: Haiti
Member: 1299439 Status: Offline Thanks Meter: 77 | Metro PCS ZTE F555 unlocked using FuriousGold Software engine version: 1.0.0.8942 Searching phone ... MODEL : QCOM SERIES 26 COMPILED DATE : Sep 30 2013 02:16:00 RELEASE DATE : Apr 24 2012 22:00:00 FIRMWARE INFO : MPCS_US_P671A91V1.0.0B05-S IMEI : 351819*******-9 BLUETOOTH ADDR : 49 38 57 B6 E8 78 INIT NAND ROUTINES; NAND INIT MADE; PHONE CODE: 0000 READING; CALCULATING; BEFORE BACKUP: FD301E27A44C3781CD79E6AD23FA0BC7.bin ERASING; WRITING; READING; AFTER BACKUP: D6D970C4423B8CA67F77EFE4BDB68E3E.bin UNLOCKED; RESET ! Log file saved to: LOG_2_06_2014_11_37_07.txt Time needed - 00:00:11 |
06-02-2014, 20:07 | #11846 (permalink) |
No Life Poster Join Date: Jan 2009 Location: cameroon
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | zte p752 unlock with furious gold ok Software engine version: 1.0.0.8938 Searching phone ... MODEL : QCOM SERIES 25 COMPILED DATE : Jun 19 2013 10:42:00 RELEASE DATE : May 7 2013 02:00:00 FIRMWARE INFO : 76XXU-USNSKOLYM-2540 IMEI : 35333903012809-9 BLUETOOTH ADDR : 1C 72 68 2F 8B 6C FIRMWARE: BYT_FR_P752D20V1.0.0B13 DONE; LOADING DATA; INIT NAND ROUTINES; NAND INIT MADE; UNLOCKING; PERFORMING EXTENDED UNLOCK; SIM_LOCK REMOVED ! RESET ! Log file saved to: LOG_2_06_2014_18_33_28.txt Time needed - 00:00:29 |
06-02-2014, 20:07 | #11847 (permalink) |
06-03-2014, 07:55 | #11848 (permalink) |
No Life Poster Join Date: Oct 2005 Location: TITI 2002 SERVIS CELULAR PG/AL
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,701 | zte kis lite unlocked QCOM1.0.0.8940 Software engine version: 1.0.0.8940 Searching phone ... MODEL : QCOM SERIES 21 COMPILED DATE : Aug 27 2013 01:07:00 RELEASE DATE : Jul 21 2012 06:00:00 FIRMWARE INFO : 76XXU-USMEKRLYM-109805 IMEI : 8685740105xx54-5 BLUETOOTH ADDR : 91 C4 4E B6 E8 78 FIRMWARE: SRB_P752D01V1.0.0B03 DONE; LOADING DATA; INIT NAND ROUTINES; NAND INIT MADE; UNLOCKING; SIM_LOCK REMOVED ! RESET ! Log file saved to: LOG_2_06_2014_14_15_18.txt Time needed - 00:00:28 |
The Following User Says Thank You to genci titi 2002 For This Useful Post: |
06-03-2014, 09:41 | #11849 (permalink) |
Member: 2089356 Status: Offline Sonork: Threema: 3N5W6VV9 Thanks Meter: 520 | vodafone 231 Software engine version: 1.0.0.6552 Connect phone powered on ! Start auth ! SW Ver: ELI_IF_291008_1026 Imei: 354561020731215 Done; Press power on ! Starting communication ... Platform: E-Gold Voice ... Preloader sent .... Starting ... Authorising ... Loader sent .... Flash ID(0): 0001:011A Reading ... Saved: SAGEM_354561020731215_ELI_IF_291008_1026_10.33.36_ 03.06.2014_PARTIAL.bin Done ! Time needed - 00:01:06 |
06-04-2014, 02:01 | #11850 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Havana, CUBA
Member: 181633 Status: Offline Thanks Meter: 731 | Alcatel 7024N from MetroPCS with 0 attemps direct unlocked!!! Using OTSMart. Code: Using library Brom_DLL_v7.1347.5 Searching phone; Phone detected (@oem160.inf,%mtk6218%;MTK USB Port) Preparing to start flash mode; Requesting authorization; Connecting; Downloading DA; Initializing; Rid: e7419961b048eec690058795758338a0 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver\x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem173.inf,%mtk_sp_da%;DA USB VCOM Port) TRYING TO OPEN COM30; DEVICE INFO: BB CHIP: MT6589_S00 [CA00, 00, 6583, 05] HW_STORAGE_EMMC: 0x4B000115 0x30305535 0xD8E5024D 0xFD702568 [SIZE=0xE9420000] IMEI1 [OTP 0001]: 013911-00-071636-8 IMEI2 [OTP 0001]: 000000-00-000000-0 PROVIDER: 7024N-2BE4US1 USRDATA INFO: 0x5C680000 SIZE: 0x8CDA0000 Searching data; Locked to: 219-01 code_cat_n: 1849660457 enabled: no tries: 5 code_cat_ns: 3491654389 enabled: no tries: 10 code_cat_sp: 1372144050 enabled: yes tries: 0 code_cat_c: 4041252390 enabled: no tries: 10 code_cat_sim: 3908132598 enabled: no tries: 10 code_cat_ns_sp: 0775592079 enabled: no tries: 5 code_cat_sim_c: 0705923867 enabled: no tries: 5 Phone unlocked; Remove battery and cable; Time needed - 00:00:36 |
