04-03-2008, 03:38 | #1 (permalink) |
Insane Poster Join Date: May 2007
Member: 518262 Status: Offline Thanks Meter: 1 | help,, in sefut module.. Press Power On shortly ! Error ... ! Operation Time - 00:00:06 |
04-04-2008, 00:32 | #2 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,570 | Quote:
Br | |
04-04-2008, 12:13 | #3 (permalink) |
Member: 518262 Status: Offline Thanks Meter: 1 | Yes sir hack, i already tried to put 9v battery and cable is good..because i test with my w850 unit and it will read using same cable w/ bat that i used in k320.. i tried to use cruiser fighter cable as somebody suggested me, then it will read, but in unlock operation, i get error.. heres the unlock log.. Press Power On shortly ! Phone detected ... Loading ... Loader version: 070129 1112 NGUCXC125872_DB2010_PRODUCTIONIDLOADER_P4D [PHONE DETAILS] Baseband IC ID: 8040 Protocol ver.: 0301 OTP Cert. ID: 50 OTP Lock Stat.: 1 OTP Imei : 35670601927885 PAF: 1 Color : RED Erom Cert. ID : 50 Flash Chip ID : 897E [UNLOCK START] Press Power On shortly ! [UNLOCK END] Error ... ! Operation Time - 00:00:1 At first "Press power on shortly" msg it will respond, 2nd "press power on shortly" msg it wont respond/continue... I already tried reattach battery/cable many times.. Hope i can solve this problem.. Thanks sir for your help.. BR |
04-05-2008, 07:49 | #4 (permalink) | |
Br | |
Help not see Coral 620 in the module | GuilleC_PMA | Infinity-Box | 2 | 04-27-2009 20:06 |
Problem with SEFut module need help | alayne | FuriousGold | 5 | 05-26-2008 15:47 |
pb on sefut module | starskyone | FuriousGold | 3 | 01-19-2008 17:39 |
I need help in the I Modulate Alcatel OH and C | ricardo ariza a | TSMbox+ | 1 | 08-13-2007 13:26 |
pls help "error in main module !!!!" scd-r-v13 | casacentregsm | ARM9 BASED M62 / M62+ | 1 | 01-12-2005 22:45 |
