02-28-2013, 03:07 | #1 (permalink) |
No Life Poster Join Date: Feb 2007
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | help to unlock Black Berry 9630 thanks |
The Following User Says Thank You to chris2007 For This Useful Post: |
02-28-2013, 11:59 | #3 (permalink) |
No Life Poster Join Date: Oct 2009 Location: FuriouSGold Age: 18
Member: 1144248 Status: Offline Sonork: 100.1574721 Thanks Meter: 3,936 | Open as admin. You must have PACK54 loaded in your dongle. And you can read code to unlock, no direct unlock |
The Following User Says Thank You to FTEAM_MODERATOR For This Useful Post: |
02-28-2013, 21:16 | #6 (permalink) |
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | Connecting to device ... Connected. UNSUPPORTED MODEL ! Disconnecting. Time needed - 00:00:00 |
03-02-2013, 00:13 | #12 (permalink) |
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | sorry i was not dowload Blackberry_ServiceTOOL_v1.0.0.1395, after download and install then download Blackberry_ServiceTOOL_v1.0.0.1400_EXE_ONLY then i run and here the result Searching for usb device ... Reading info ... IMEI: 980070000646163 Calculating ... MEP LOCK: MEP-15326-002 MEP1 [SIM]: 0945836452618434 MEP2 [NETWORK]: 63205520 MEP3 [NETWORK SUBSET]: 3906769681104619 MEP4 [SERVICE PROVIDER]: 4210528035125515 MEP5 [CORPORATE]: 3297469460304789 How to enter codes in BlackBerry: 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2/MEPP2 (for NETWORK LOCK) or MEP4/MEPP4 (for SERVICE PROV LOCK) 9. Now it will ask to enter then mep code Done ! Time needed - 00:01:05 |
