07-15-2020, 09:43 | #1 (permalink) |
No Life Poster Join Date: Feb 2007
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | Honor 9i 2018 LLD-AL30 FRP not success please help Code: Fly Captain Huawei Resurrector 0.0.0.53 user:xxxxxxxx OEM File to update: LLD-AL30 7/15/2020 9:35:27 PM Starting to write device... Process identifier:5217381 Waiting for fastboot device... Device found: 6SJNW18626035529 Looking for a device in fastboot mode Device found: 6SJNW18626035529 Getting IMEI... Getting build number... Getting model ... Getting model by product ... Getting battery state... Getting backdoor info... Getting lock state info... Getting lock boot info... Model: :LLD-AL30 9.1.0.120(C00E113R1P6) OEM lock state info: 7783mv Unlocking FRP... Writing FRP partition FRP partition update :FAIL Command not allowed Writing FRP partition Waiting for answer... FRP partition update FAIL Getting lock state info... Waiting for answer... Getting backdoor info... Waiting for answer... Waiting for answer... Cannot get FBlock info from device Waiting for answer... Cannot get HW FBlock info from device Waiting for answer... Waiting for answer... Writing FRP partition Waiting for answer... FRP partition update FAIL Update fastboot mode failed 7/15/2020 9:39:04 PM Writing device finished - INCOMPLETE |
07-15-2020, 10:03 | #2 (permalink) |
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | retry again Code: Fly Captain Huawei Resurrector 0.0.0.53 user:xxxxxxxx OEM File to update: LLD-AL30 7/15/2020 10:01:06 PM Starting to write device... Process identifier:5217420 Waiting for fastboot device... Device found: 6SJNW18626035529 Looking for a device in fastboot mode Device found: 6SJNW18626035529 Getting IMEI... Getting build number... Getting model ... Getting battery state... Getting backdoor info... Getting lock state info... Getting lock boot info... Build number: :LLD-AL30 9.1.0.120(C00E113R1P6) Model: LLD-AL30 Vendor/Country: all/cn Battery state: 7832mv OEM lock state info: FB LockState: LOCKED USER LockState: LOCKED OEM get bootinfo: locked Unlocking FRP... Writing FRP partition FRP partition update :FAIL Command not allowed Writing FRP partition FRP partition update :FAIL Command not allowed Update fastboot mode failed 7/15/2020 10:01:44 PM Writing device finished - INCOMPLETE |
07-15-2020, 10:15 | #3 (permalink) |
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | I try with FlyCaptain Huawei Module v2.0.0.0184 Code: 2020-07-15 22:12:18.946 FlyCaptain Huawei Module v2.0.0.0184 2020-07-15 22:12:18.949 Dongle S/N: xxxxxxxx Before detection connect cable to usb and enable Manufacture mode ! Qualcomm and HiSilicon: *#*#2846579#*#* MTK: *#*#14789632#*#* Windows: ##2846579# ProjectMenu 1.Background setting 2.USB ports setting Select Manufacture mode (for MTK other/debug mode) 2020-07-15 22:12:30.360 Checking credits... 2020-07-15 22:12:38.359 Check credits success! You have 9999 credit[s] 2020-07-15 22:12:45.507 Erase FRP start 2020-07-15 22:12:55.175 Reading phone info... 2020-07-15 22:12:55.760 Read phone info success! Model: LLD-AL30 Firmware ver.: LLD-AL30 9.1.0.120(C00E113R1P6 SN: 6SJNW18626035529 2020-07-15 22:12:55.778 Reading Certify data... 2020-07-15 22:12:56.041 Reading Certify data success! 2020-07-15 22:12:56.043 Signing Certify data... 2020-07-15 22:12:57.291 Erase FRP fail! Not supported/unknown chipset! |
07-15-2020, 16:09 | #4 (permalink) |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,568 | You must use TP and write LLD-Downgrade-Board-1.0.0.41-8.0.0.fcff !!! After can reset frp using flycatain. Or can use TP and resurrector Br |
07-15-2020, 17:00 | #6 (permalink) | |
No Life Poster Join Date: Aug 2011 Location: UK
Member: 1629133 Status: Offline Thanks Meter: 498 | Quote:
07-15-2020, 17:06 | #7 (permalink) | |
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | Quote:
07-18-2020, 17:07 | #10 (permalink) | |
what should I do check "Force OTA"? then browse file via "File to Update"? while in "Update Firmware" check "Basic" at "Mode" then "Option" check "Rescue Recovery" and "Old slow algo"? make testpoint connect phone to PC the press "Update" get below Code: Standard update Not Reboot NOT cheked Update Verlist to server on file load NOT checked Try Rescue Recovery checked Bypass version check NOT checked Old slow algo checked Force OTA checked Looking for a device in force upgrade mode No devices detected in force upgrade mode Looking for a device in fastboot mode No device found in fastboot mode No device detected to update | |
07-18-2020, 18:38 | #12 (permalink) |
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | i fix the drivers make the TP then connect to PC and now doing downgrade Code: Advanced update Not Reboot NOT cheked Update Verlist to server on file load NOT checked Try Rescue Recovery checked Bypass version check NOT checked Old slow algo checked Force OTA checked Looking for a device in force upgrade mode Device detected: COM613: HUAWEI USB COM 1.0 (COM613) |
07-18-2020, 19:01 | #13 (permalink) |
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | flashing done Code: Fly Captain Huawei Resurrector 0.0.0.53 user:xxxxxxxx Advanced update Not Reboot NOT cheked Update Verlist to server on file load NOT checked Try Rescue Recovery checked Bypass version check NOT checked Old slow algo checked Force OTA checked Looking for a device in force upgrade mode Device detected: COM613: HUAWEI USB COM 1.0 (COM613) USB Device REMOVAL Type: @oem32.inf,%huawei06%;HUAWEI USB COM 1.0 VidPid: VID_12D1&PID_3609 Instance id: 6&af16705&0&4 USB Device INSERTION Type: @oem32.inf,%huawei06%;HUAWEI USB COM 1.0 VidPid: VID_12D1&PID_3609 Instance id: 6&af16705&0&4 7/19/2020 6:09:39 AM Starting to write device in FASTBOOT mode... File to update: E:\Huawei\Huawei Honor 9i 2018\LLD-Downgrade-Board-1.0.0.41-8.0.0.fcff Device detected: COM613: HUAWEI USB COM 1.0 (COM613) USB Device REMOVAL Type: @oem32.inf,%huawei06%;HUAWEI USB COM 1.0 VidPid: VID_12D1&PID_3609 Instance id: 6&af16705&0&4 USB Device INSERTION Type: @oem32.inf,%huawei06%;HUAWEI USB COM 1.0 VidPid: VID_12D1&PID_3609 Instance id: 6&af16705&0&4 Process identifier:5224436 Writing bootloader... Step 1... Step 2... Waiting for device REMOVAL/INSERTION... USB Device REMOVAL Type: @oem32.inf,%huawei06%;HUAWEI USB COM 1.0 VidPid: VID_12D1&PID_3609 Instance id: 6&af16705&0&4 USB Device INSERTION Type: @oem3.inf,%singlebootloaderinterface%;Android Bootloader Interface VidPid: VID_18D1&PID_D00D Instance id: 6SJNW18626035529 Waiting for fastboot device... Device found: 6SJNW18626035529 Looking for a device in fastboot mode Device found: 6SJNW18626035529 Getting IMEI... Getting build number... Getting model ... Getting battery state... Getting backdoor info... Getting lock state info... Getting lock boot info... SN:6SJNW18626035529 IMEI:869967038263190 IMEI1:869967038493003 MEID:A0000091D5D1EE Build number: :LLD-AL30 9.1.0.120(C00E113R1P6) Model: LLD-AL30 Vendor/Country: all/cn Battery state: 0 OEM lock state info: FB LockState: UNLOCKED USER LockState: LOCKED OEM get bootinfo: unlocked Erasing ver .. . Writing ptable partition PTABLE partition update ...OK Writing xloader partition XLOADER partition update ...OK Writing fastboot partition FASTBOOT partition update ...OK Writing kernel partition KERNEL partition update ...OK Writing ramdisk partition RAMDISK partition update ...OK Writing vbmeta partition VBMETA partition update ...OK Writing odm partition ODM partition update ...OK Writing recovery_ramdisk partition RECOVERY_RAMDISK partition update ...OK Writing recovery_vendor partition RECOVERY_VENDOR partition update ...OK Writing recovery_vbmeta partition RECOVERY_VBMETA partition update ...OK Erasing cust partition Partition cust erased Erasing misc partition Partition misc erased Erasing cache partition Partition cache erased Writing cache partition CACHE partition update ...OK Writing fw_lpm3 partition FW_LPM3 partition update ...OK Writing fw_hifi partition FW_HIFI partition update ...OK Writing teeos partition TEEOS partition update ...OK Writing trustfirmware partition TRUSTFIRMWARE partition update ...OK Writing sensorhub partition SENSORHUB partition update ...OK Writing dts partition DTS partition update ...OK Writing modemnvm_update partition MODEMNVM_UPDATE partition update ...OK Writing modem_fw partition MODEM_FW partition update ...OK Writing system partition sending sparse file 464607556 bytes Waiting for answer... send sparse file OK sending sparse file 471773420 bytes Waiting for answer... send sparse file OK sending sparse file 389966172 bytes Waiting for answer... send sparse file OK SYSTEM partition update ...OK Writing vendor partition sending sparse file 423641020 bytes Waiting for answer... send sparse file OK sending sparse file 146912472 bytes Waiting for answer... send sparse file OK VENDOR partition update ...OK Erasing product partition Partition product erased Writing product partition PRODUCT partition update ...OK Erasing version partition Partition version erased Writing version partition VERSION partition update ...OK Erasing userdata partition Partition userdata erased Erasing userdata partition Partition userdata erased Writing userdata partition USERDATA partition update ...OK Writing splash2 partition SPLASH2 partition update ...OK Erasing bootfail_info partition Partition bootfail_info erased Erasing dfx partition Partition dfx erased Erasing rrecord partition Partition rrecord erased Waiting for fastboot device... USB Device REMOVAL Type: @oem3.inf,%singlebootloaderinterface%;Android Bootloader Interface VidPid: VID_18D1&PID_D00D Instance id: 6SJNW18626035529 USB Device INSERTION Type: @oem3.inf,%singlebootloaderinterface%;Android Bootloader Interface VidPid: VID_18D1&PID_D00D Instance id: 6SJNW18626035529 Device found: 6SJNW18626035529 Waiting for OEM hwdog certify set 0 command ...OK Waiting for OEM oeminfoerase-vendorcountry command ...OK Waiting for OEM oeminfoerase-devicemodel command ...OK Waiting for OEM oeminfoerase-ver command ...OK Waiting for OEM oeminfoerase-single_sim command ...OK USB Device REMOVAL Type: @oem3.inf,%singlebootloaderinterface%;Android Bootloader Interface VidPid: VID_18D1&PID_D00D Instance id: 6SJNW18626035529 Software written 7/19/2020 7:00:36 AM Writing device finished OK |
07-18-2020, 19:09 | #14 (permalink) |
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | Reboot phone back phone not power on normal Code: Fly Captain Huawei Resurrector 0.0.0.53 user:xxxxxxxx OEM File to update: LLD-AL30 7/19/2020 7:03:42 AM Starting to write device... Process identifier:5224479 Waiting for fastboot device... Device found: 6SJNW18626035529 Looking for a device in fastboot mode Device found: 6SJNW18626035529 Getting IMEI... Getting build number... Getting model ... Getting battery state... Getting backdoor info... Getting lock state info... Getting lock boot info... SN:6SJNW18626035529 IMEI:869967038263190 IMEI1:869967038493003 MEID:A0000091D5D1EE Build number: :LLD-AL30 9.1.0.120(C00E113R1P6) Model: LLD-AL30 Battery state: 0 OEM lock state info: FB LockState: UNLOCKED USER LockState: LOCKED OEM get bootinfo: unlocked Unlocking FRP... Writing FRP partition FRP partition update :FAIL partition error Writing FRP partition FRP partition update ...OK Writing OEMINFO partition OEMINFO partition update ...OK Software written 7/19/2020 7:05:19 AM Writing device finished OK 7/19/2020 7:05:47 AM Starting fastboot reboot device ... Looking for a device in fastboot mode Device found: 6SJNW18626035529 Getting IMEI... Getting build number... Getting model ... Getting battery state... Getting backdoor info... Getting lock state info... Getting lock boot info... SN:6SJNW18626035529 IMEI:862058047541326 IMEI1:862058047621904 MEID:A000009B6E7EE6 Build number: :LLD-AL30 8.0.0.130(C00) Model: LLD-AL30 Vendor/Country: all/cn Battery state: 0 OEM lock state info: FB LockState: UNLOCKED USER LockState: LOCKED OEM get bootinfo: unlocked 7/19/2020 7:05:49 AM Fastboot reboot device finished |
07-18-2020, 19:31 | #15 (permalink) | |
please help me disconnect battery and connect again and tr to connect via fastboot its not display on screen | |
