02-19-2021, 14:20 | #1 (permalink) |
No Life Poster Join Date: Apr 2004 Location: srilanka
Member: 61595 Status: Offline Sonork: 100.1610188 Thanks Meter: 97 | huawei dra-lx5 only 2g signal after huawei ID remove [SOLVED] Engine version 1.0.0.5188 Searching phone in normal mode; [connect the phone powered off to the usb cable with testpoint connected] Phone detected (MediaTek USB Port (COM146)) (Driver version: 3.0.1504.0) Preparing to start flash mode; Preparing to open COM146 Connecting; Downloading DA; Initializing; Rid: ba15fb8d0904d10c77755e400264237b Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6765 [CA00, 00, 6765, 00] BB ID: MThFMjAwMTVCODlDNkMyQkE4M0FCRDU4NDMwNThFMEQ= HW_STORAGE_EMMC: 0x51000115 0x41333658 0xC10F0342 0xC5573DD2 [SIZE=0x748800000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x136800000 SIZE: 0x611200000 Contents saved to : E:\FURIOSE\PACK6\OTSmart_v1.0.0.5188_SEC_Edition\P ART_OEMINFO_HUAWEI DRA-LX9_ba15fb8d0904d10c77755e400264237b_19_02_2021_18 _38_46.osp Formatting OEMINFO partition now... Done; Done; Searching phone in normal mode; [connect the phone powered off to the usb cable with testpoint connected] Phone detected (MediaTek USB Port (COM146)) (Driver version: 3.0.1504.0) Preparing to start flash mode; Preparing to open COM146 Connecting; Downloading DA; Initializing; Rid: ba15fb8d0904d10c77755e400264237b Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6765 [CA00, 00, 6765, 00] BB ID: MThFMjAwMTVCODlDNkMyQkE4M0FCRDU4NDMwNThFMEQ= HW_STORAGE_EMMC: 0x51000115 0x41333658 0xC10F0342 0xC5573DD2 [SIZE=0x748800000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x136800000 SIZE: 0x611200000 oeminfo nv field not found; Formatting FRP partition now... Done; Factory Reset Protection successfully removed ! Time needed - 00:03:03 Log file saved to: LOG_19_02_2021_18_41_48.txt imei null,kepad and 3g 4g signal not working and appear only 2g signal.need solution for it please |
02-19-2021, 14:41 | #2 (permalink) |
Member: 61595 Status: Offline Sonork: 100.1610188 Thanks Meter: 97 | my problem solved after write oem backup logs here Using library Brom_DLL_v7.1813.3 Engine version 1.0.0.5188 Searching phone in normal mode; [connect the phone powered off to the usb cable with testpoint connected] Phone detected (MediaTek USB Port (COM146)) (Driver version: 3.0.1504.0) Preparing to start flash mode; Preparing to open COM146 Connecting; Downloading DA; Initializing; Rid: ba15fb8d0904d10c77755e400264237b Requesting baudrate change; Done; USB SPEED: USB_HIGH_SPEED DEVICE INFO: BB CHIP: MT6765 [CA00, 00, 6765, 00] BB ID: MThFMjAwMTVCODlDNkMyQkE4M0FCRDU4NDMwNThFMEQ= HW_STORAGE_EMMC: 0x51000115 0x41333658 0xC10F0342 0xC5573DD2 [SIZE=0x748800000] IMEI1 [OTP 0000]: 000000-00-000000-0 IMEI2 [OTP 0000]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0x136800000 SIZE: 0x611200000 Preparing to write oeminfo Preparing to write OEMINFO; Writing OEMINFO; Partition write ended successfully; Time needed - 00:00:47 Log file saved to: LOG_19_02_2021_19_03_45.txt |
