05-18-2014, 09:08 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: Feb 2012 Location: Sarajevo BiH Age: 30
Member: 1720435 Status: Offline Thanks Meter: 14 | Huawei G5520 Unlock Help Who cable use,any help Using library Brom_DLL_v5.1316.1 COM opened ok; Press power and keep it pressed now ! COM opened ok; Press power and keep it pressed now ! COM opened ok; Press power and keep it pressed now ! COM opened ok; Press power and keep it pressed now ! COM opened ok; Press power and keep it pressed now ! COM opened ok; Press power and keep it pressed now ! COM opened ok; Press power and keep it pressed now ! COM opened ok; Press power and keep it pressed now ! COM opened ok; Press power and keep it pressed now ! COM opened ok; Press power and keep it pressed now ! ERROR: Connection failed ! Time needed - 00:03:22 |
05-18-2014, 10:22 | #2 (permalink) |
Member: 1720435 Status: Offline Thanks Meter: 14 | [QUOTE=informaticar97;10316292]How unlock Huawei G5520, i try with Pack 6, OTZ Flasher and error Using library Brom_DLL_v5.1316.1 COM opened ok; Press power and keep it pressed now ! Connecting; Meta mode entered; Baseband Chip: MT6252 Sw version: G5520V100R001C445B202SP00S Hw Version: G5520_12864_11B_HW Reading phone info; IMEI: N/A Reading security; Done; Checking; Preparing; ERROR: Unlock Failed; Time needed - 00:00:10 |
05-29-2014, 20:54 | #4 (permalink) | |
No Life Poster Join Date: Mar 2001 Location: Croatia Age: 45
Member: 3508 Status: Offline Thanks Meter: 71 | [QUOTE=informaticar97;10316426] Quote:
Which cable did you use!?!? Did you solder testpoints or via micro USB connector!?!? I can't unlock it with USB cable, but I can read flash!! Even I tried RX/TX cable via micro USB for Samsung, LG, MTK platform, Vodafone and phone won't connect, it just power on!! - READ FLASH Using library Brom_DLL_v5.1316.1 EMI Settings Loaded; Searching phone; (for some models keep SPACE or * (STAR) key pressed before inserting the cable) Phone detected (USB Single Port) Preparing to start flash mode; Connecting; Downloading DA; Initializing; Requesting baudrate change; Done; DEVICE INFO: BB CHIP: MT6252_S0101 [D100, 101, 6250, FF] MEMORY: [Numonyx] N25W128 [2C:CB:18] [SIZE=0x01000000] FAT INFO: 0x00D90000 SIZE: 0x00270000 Reading data; - UNLOCK Using library Brom_DLL_v5.1316.1 Searching phone; (for some models keep SPACE or * (STAR) key pressed before inserting the cable) Phone detected (USB Single Port) Preparing to start meta mode; ERROR: Timeout waiting ! Time needed - 00:00:52 BR | |
