Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > FuriousGold
FuriousGold FuriouS GOLD Support Area | Powered by FuriousTeam
Old 04-01-2019, 17:20   #1 (permalink)
Member: 78516
Thanks Meter: 62
Huawei p20 pro clt-al00 failed remove huawei id [SOLVED=SOLUTION INSIDE]
Device detected:
BOOTLOADER File to update: Kirin970_T2_A8.1_V5
OEM File to update: CLT-AL00
01/04/2019 17:40:00 Starting to write device...
Writing bootloader...
Writing Kirin970_T2_A8.1_V5_3.dtwork...
Writing Kirin970_T2_A8.1_V5_4.dtwork...
Writing Kirin970_T2_A8.1_V5_5.dtwork...
Waiting for fastboot device...
Device found: D5F7N1871600XXXX
Looking for a device in fastboot mode
Getting IMEI...
Getting build number...
Getting model ...
Getting battery state...
Getting backdoor info...
Getting lock state info...
Getting lock boot info...
SN:D5F7N1871600XXXX
IMEI:86981304XXXXXXX
IMEI1:86981304XXXXXXX
MEID:A000009376XXXX
Build number: :CLT-AL00 8.1.0.176(C00)
Model: CLT-AL00
Battery state: 5956mv
OEM lock state info:
 FB LockState: UNLOCKED
 USER LockState: LOCKED
OEM get bootinfo:
 unlocked
Writing OEMINFO partition
OEMINFO partition UPDATE ...OK
Software written
01/04/2019 17:40:48 Writing device finished OK
All went good but Huawei Id remains !
1 I put it in HUAWEI USB 1.0 mode by using testpoint
2 I checked use bootloader
3 I selected the bootloader
4 I checked "Update OEMINFO and Unlock Huawei ID"
5 I selected CLT-AL00
6 I clicked update
Do I need to flash it after this ?
What is wrong ?
Thanks
The Following User Says Thank You to tooko For This Useful Post:
Old 04-01-2019, 18:27   #2 (permalink)
Member: 78516
Thanks Meter: 62
I did a factory reset ! Huawei ID remains !
I changed OEMINFO selecting CLT-L29 instead of CLT-AL00 , the device hung on logo!
I changed back to the right OEMINFO , Huawei ID remains !
I want to flash it but there are only CLT-L29 and CLT-L09 on the support and for some reasons I cannot download them ! Can I convert it from CLT-AL00 to CLT-L29 ?
any idea ??
Thanks
Old 04-01-2019, 19:27   #3 (permalink)
.:hack3r2k:.'s Avatar
Member: 15022
Sonork: 100.53452
Thanks Meter: 61,568
Should be able to convert
The Following User Says Thank You to .:hack3r2k:. For This Useful Post:
Old 04-02-2019, 15:01   #4 (permalink)
Member: 877421
Sonork: halim
Thanks Meter: 62
to remove huawei id counvert to global version
The Following User Says Thank You to halim.gsm For This Useful Post:
Old 04-05-2019, 13:52   #5 (permalink)
Member: 78516
Thanks Meter: 62
Can you give some directions please ?
thanks
B.R.
Old 04-12-2019, 21:55   #6 (permalink)
Member: 349359
Thanks Meter: 7
yes do we need to flash it completely because am facing the same problem
The Following User Says Thank You to live gsm For This Useful Post:
Old 04-13-2019, 12:49   #7 (permalink)
Member: 78516
Thanks Meter: 62
did you manage to do it ? can you tell me how ? I do not want to brick it !!
thanks
Old 04-13-2019, 14:54   #8 (permalink)
jepetu's Avatar
Member: 181633
Thanks Meter: 730
Download full firmware from HERE.
1. Change OEMINFO to CLT-L29.
2. Flash firmware in UPGRADE MODE (not fastboot).
3. Then change OEMINFO only country again, phone must factory reset after completion.
4. Done HWID gone!
The Following 4 Users Say Thank You to jepetu For This Useful Post:
Old 04-13-2019, 14:57   #9 (permalink)
jepetu's Avatar
Member: 181633
Thanks Meter: 730
You can see my experience with an ALP-AL00 in this thread posts 13 and 14, it's the same process.
The Following 2 Users Say Thank You to jepetu For This Useful Post:
Old 04-13-2019, 16:49   #10 (permalink)
Member: 78516
Thanks Meter: 62
I am going to try and post results !!
thank you jepetu .
Old 04-16-2019, 12:14   #11 (permalink)
Member: 78516
Thanks Meter: 62
Hi,
tested with Huawei P20 pro CLT-AL00, it works like a charm, thank you jepetu.
1. Updated OEMINFO using tespoint to match needed vendor/country (in my case hw/spcseas)
2. Flashed CLT-L29 FULL ROM Charlotte-L29C_8.1.0.158(C636)_Firmware_8.1.0_r1_EMUI8.1_050 15AQX
3. Updated OEMINFO once more changing country to hw/eu to force phone to do a full factory reset because the diference after operation (this is NEEDED)
thanks to jepetu
The Following 6 Users Say Thank You to tooko For This Useful Post:
Old 05-29-2019, 06:23   #12 (permalink)
Member: 2542848
Thanks Meter: 80
Originally Posted by tooko View Post
Hi,
thanks to jepetu
Hi Sir, Please help to explain me.
There are many
-Kirin970 A8.1_V1
-Kirin970 A8.1_V2
-Kirin970 A8.1_V3
-Kirin970 A8.1_V4
So which one should I choose the right ?
Now my phone is CLT-AL00 DaulSim. Lock Huawei ID.
android : 9
build number: 9.0.0.184(C00E57R1P15) Turbo
Android Sec patch : April 1, 2019
Please help
Old 05-29-2019, 07:35   #13 (permalink)
Member: 15022
Sonork: 100.53452
There are many
-Kirin970 A8.1_V1
-Kirin970 A8.1_V2
-Kirin970 A8.1_V3
-Kirin970 A8.1_V4
android : 9
Please help
You try all one by one. Only one will work
Old 07-18-2019, 02:48   #14 (permalink)
Member: 164422
Thanks Meter: 24
oeminfo change
plz can i know how you changed oeminfo.
Old 07-18-2019, 06:38   #15 (permalink)
Member: 15022
Sonork: 100.53452
You use a scrip.txt . Inside you put oeminfo=oeminfo.img line. Use resurrector to load it and thats it
Page generated in 0.21289 seconds with 8 queries
