11-13-2020, 15:16 | #1 (permalink) |
No Life Poster Join Date: Aug 2012 Location: Chile
Member: 1797183 Status: Offline Thanks Meter: 148 | I need some help FuriousTeam my question is? for each process to the same phone do you consume credits? Where can you see a remaining credit counter, if in my case I lost both credits, can you help me make a refund? It is worth mentioning that both teams to finish with error remained stuck in the logo here the registry plus the backup of both processes carried out: Code: Using library Brom_DLL_v7.1813.3 Searching phone in emergency mode; [connect the phone in "Firmware Update" Mode. Hold the Volume Up on the powered off phone and enter the USB cable in order to enter it] Phone detected (USB\VID_1004&PID_6000&REV_0409) Preparing to start flash mode; Preparing to open COM70 Opened; Authorising; Authorized; LAF_ERROR_ACCESS_DENIED download_cable = 910K battery_level = 40 download_type = download_speed = 0 usb_version = UHS hardware_revision = rev_10 download_sw_version = device_sw_version = X52010m secure_device = S laf_sw_version = 1.1 device_factory_version = LMX520HMAT-00-V10c-SCA-XXX-SEP-18-2019+0 device_factory_out_version = LMX520HMAT-00-V10c-SCA-XXX-SEP-18-2019+0 pid = 965GAN68B6JF04GK6 imei = 355472100292103 model_name = LM-X520HM device_build_type = U chipset_platform = mt6765 target_operator = LAO target_country = COM ap_factory_reset_status = 6 cp_factory_reset_status = 0 isDownloadNotFinish = 0 qem = 0 cupss_swfv = A1568817212-M1568817212-FFFFFFFFFFF-U1568824988-0 is_one_binary_dual_plan = 0 memory_size = 61071360 memory_id = GX6BMB bootloader_ver = MiniOS 3.0 islan_download = 0 skip_readwrite = 0 Starting; Setting secure mode; Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Getting security info; Setting secure mode; Done; Reading security; Done; Checking security; Phone it's going restart several times during this step; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Done; Contents saved to : C:\Users\old_i\Desktop\Archivos\FURIOS GOLD\OTSmart_v1.0.0.5008_SEC_Edition\SEC_BKP_LG K50_355472100292103.osp Working; Connecting to server; Authorisation process started; Done; Requesting data from server ! Wait please ... Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; IMEI A: 355472-10-029210-3 IMEI B: 350305-26-000000-1 IMEI C: 350305-26-000000-1 WiFi ADDR: AC:F6:F7:BD:1C:DC BT ADDR: AC:F6:F7:4E:03:DE LOCK STATUS: 0 0 0 0 Done; Working; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; IMEI1 repaired; Starting Re-init operation; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. ERROR: Scan port failed ! Erase failed; Re-init operation completed; GPT Restore failed; Setting secure mode; ERROR: laf_cmd_protection - LAF_ERROR_ACCESS_DENIED ! Time needed - 00:04:15 Code: Using library Brom_DLL_v7.1813.3 Searching phone in emergency mode; [connect the phone in "Firmware Update" Mode. Hold the Volume Up on the powered off phone and enter the USB cable in order to enter it] Phone detected (USB\VID_1004&PID_6000&REV_0409) Preparing to start flash mode; Preparing to open COM70 Opened; Authorising; Authorized; LAF_ERROR_ACCESS_DENIED download_cable = 910K battery_level = 62 download_type = download_speed = 0 usb_version = UHS hardware_revision = rev_11 download_sw_version = device_sw_version = X42010v secure_device = S laf_sw_version = 1.1 device_factory_version = LMX420HMAT-00-V10f-SCA-XXX-AUG-05-2019+0 device_factory_out_version = LMX420HMAT-00-V10f-SCA-XXX-AUG-05-2019+0 pid = 962MAD32B57S03BTE imei = 353389101610699 model_name = LM-X420HM device_build_type = U chipset_platform = mt6765 target_operator = LAO target_country = COM ap_factory_reset_status = 6 cp_factory_reset_status = 0 isDownloadNotFinish = 0 qem = 0 cupss_swfv = A1565096446-M1565096446-FFFFFFFFFFF-U1565108320-0 is_one_binary_dual_plan = 0 memory_size = 61071360 memory_id = QX63MB bootloader_ver = MiniOS 3.0 islan_download = 0 skip_readwrite = 0 Starting; Setting secure mode; Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Getting security info; Setting secure mode; Done; Reading security; Done; Checking security; Phone it's going restart several times during this step; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; Done; Contents saved to : C:\Users\old_i\Desktop\Archivos\FURIOS GOLD\OTSmart_v1.0.0.5008_SEC_Edition\SEC_BKP_LG LM-X420HM_353389101610699.osp Working; Connecting to server; Authorisation process started; Done; Requesting data from server ! Wait please ... Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; IMEI A: 353389-10-161069-9 IMEI B: 350305-26-000000-1 IMEI C: 350305-26-000000-1 WiFi ADDR: AC:F6:F7:BB:FF:E8 BT ADDR: AC:F6:F7:4C:E6:EA LOCK STATUS: 0 0 0 0 Done; Working; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. Done; IMEI1 repaired; Starting Re-init operation; Waiting for device; Be sure it restarted in "Firmware Update" Mode. If not, put it manually. ERROR: Scan port failed ! Erase failed; Re-init operation completed; GPT Restore failed; Setting secure mode; ERROR: laf_cmd_protection - LAF_ERROR_ACCESS_DENIED ! Time needed - 00:05:19 |
