03-08-2008, 10:48 | #1 (permalink) |
Freak Poster Join Date: Apr 2005 Location: BIRNAM MELROSE JOBURG S.A Age: 48
Member: 139349 Status: Offline Thanks Meter: 7 | K550i HELP UNLOCK IT CAN SOME GENIOUS TELL ME HOW TO UNLOCK SONY ERICSSON K550i WITH FURIOUS GOLD BOX, I JUST UPDATED IT TO MODELS PACK 3 BUT IT IS NOT RESPONDING EVEN IF I TRY TO READ INFO IT SHOWS THIS Press Power On shortly ! Error ... ! Operation Time - 00:00:07 I DONT KNOW IF THE CABLE GPG-008 FURIOUS SEK 750i THAT CAME WITH THE BOX IS THE ONE THAT WORKS ON THIS PHONE. |
03-08-2008, 11:35 | #2 (permalink) | |
No Life Poster Join Date: Jun 2006 Location: With You In Mind
Member: 300540 Status: Offline Thanks Meter: 103 | Quote:
BR. | |
03-08-2008, 14:37 | #5 (permalink) |
Member: 139349 Status: Offline Thanks Meter: 7 | k550i unlocking oh sure thats original usb cable, i was so stupid to ask that question i dont know what was in my thoughts. im done with the cable i made one DCU-60 Cable from the k750 that i had and installed usb drivers for SEFUT and the phone is detected but when i try to do job here is what it says Keep pressed "C" on phone and insert DCU-60 cable ! Phone detected ... Loading ... Loader version: 070129 0950 NGUCXC1250330_DB2020_PRODUCTIONIDLOADER_P3J [PHONE DETAILS] Baseband IC ID: 9900 Protocol ver.: 0301 OTP Cert. ID: 51 OTP Lock Stat.: 1 OTP Imei : 35665701947994 PAF: 1 Color : RED Erom Cert. ID : 52 Flash Chip ID : 897E [PHONE INFO] MODEL: K550i MAPP CXC article: R6CA001 prgCXC1250744_ORANGE_LI MAPP CXC version: R6CA001 Language Pack.: ORANGE_GEN CDA article.: CDA102743/55 CDA version.: R9A Default article.: cxc1250671 Default version.: R6CA001 Operator: 234-33 Locked: YES Operation Time - 00:00:10 but when i want to unlock it says NO FILES PRESENT IN LISTS! So which files should i install for the phone to unlocked? |
03-08-2008, 15:26 | #6 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,602 | Quote:
Damn fiels from www.gsm-hacking.eu/files . Must be same version with fw from phone. Br | |
03-13-2008, 11:01 | #7 (permalink) |
Member: 139349 Status: Offline Thanks Meter: 7 | Look At This Steve MY K550i is DEAD Keep pressed "C" on phone and insert DCU-60 cable ! Phone detected ... Loading ... Loader version: 070129 0950 NGUCXC1250330_DB2020_PRODUCTIONIDLOADER_P3J [PHONE DETAILS] Baseband IC ID: 9900 Protocol ver.: 0301 OTP Cert. ID: 51 OTP Lock Stat.: 1 OTP Imei : 35665701947994 PAF: 1 Color : RED Erom Cert. ID : 52 Flash Chip ID : 897E [UNLOCK START] Keep pressed "C" on phone and insert DCU-60 cable ! Phone detected ... Security defeated ! Loading ... Loader version: DB2020_INSIDE - FuriouSTeaM Invalid file loaded as main firmware; [UNLOCK END] Error ... ! Operation Time - 00:00:27 I HAVE DISCOVERED THAT MAIN FIRMWARE FOR MY PHONE IS MAPP CXC version: R6CA001. THAT IS WHY IT IS SAYING INVALID FILE LOADED AS MAIN FIRMWARE. so where do i get a correct firmware R6CA001 HELP ME STEVE IM STRANDED. |
UB team ,i cant unlock K550i,,help... | nath15 | Universalbox | 7 | 02-11-2009 05:42 |
Help unlocking Sony Erickson k550i | damienkearney20 | Sony Ericsson Hardware Repair | 0 | 06-17-2008 23:03 |
z1010 Need help unlocking it | Triple X | Sony Ericsson Hardware Repair | 0 | 09-20-2006 04:02 |
It Helps Unlock Motorola A835 Though It Is Not Free | WEBWOMAN€ | Phone Unlocking Codes & Maps | 11 | 04-23-2004 08:59 |
M35v20 locked....pls help unlock it !!!! | GsmNut | x1x to x45/x50 | 2 | 12-30-2002 09:29 |
