12-30-2006, 16:40 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Location: Gsmhosting Age: 42
Member: 138809 Status: Offline Sonork: 100.99886 Thanks Meter: 79 | Lg 8330 dead after convert to red by flash i have one lg8330 , for unlock.. when i pessed direct unlock soft said brown phone not supported , so i flashed via tp with v11 uk file... flashed all ok, after flash did direct unlock , unlock ok but set only blinks when power on, means phone is dead , i assembled phone perfectley checked twice, so what to do now???? plz help quick |
12-30-2006, 20:14 | #2 (permalink) |
Member: 138809 Status: Offline Sonork: 100.99886 Thanks Meter: 79 | finaly i solved prob by flashing with romanian inside flash files and set is on and working okay now, but before i tried to unlock via tp, flashed with ver 10 also with ver 20, but same dead also did direct unlock but solved by romanian flash files thanks furious team, here is log, Press Power On shortly ! LatencyTimer: 10ms Phone Detected ! Chip ID: 71000301 Loading ... Loader version: 40318 1450 LLECXC1325413_CERTLOADER R3J Flash ID: 890D Settings Done ! (c)2oo6, HACK3R2K.COM GSM DEVELOPEMENT Settings made ... CID: 42 IMEI: 35xxxxxxxxxxxx Formatting GDFS ... Writting GDFS ... Data OK ! Lock restored ! Counter setup done ! Type 2945#*88110# with SIM inside. Unlock codes: NCK : 55140306 NSCK : 55236151 SPCK : 55433025 CCK : 00100755 PCK : 55465534 ESCK : 39047767 Codes succesfully read ... Time needed - 00:01:02 Press Power On shortly ! LatencyTimer: 10ms Phone Detected ! Chip ID: 71000301 Loading ... Loader version: 50223 1439 LLECXC1325414_FLASHLOADER R3V Settings made ... Bypassing restriction ... Loader version: 40318 1450 LLECXC1325413_CERTLOADER R3J Flash ID: 890D Settings Done ! HACK3R2K.COM GSM DEVELOPEMENT Settings made ... CID: 42 IMEI: 356xxxxxxxxxxxxx drive_c_cid42_r.csw CSW BLOCKS: 00B0 drive_c_cid42_r.csw ... OK drive_media_cid42_r.csw CSW BLOCKS: 0040 drive_media_cid42_r.csw ... OK Drive_Rec_IT_cid42_r.csw CSW BLOCKS: 0028 Drive_Rec_IT_cid42_r.csw ... OK FS_Rec_IT_cid42_r.csw CSW BLOCKS: 0200 FS_Rec_IT_cid42_r.csw ... OK U8330_phone_wcdma_4mbram_cid42_R.csw CSW BLOCKS: 00D7 U8330_phone_wcdma_4mbram_cid42_R.csw ... OK READY. Time needed - 00:25:37 Press Power On shortly ! LatencyTimer: 10ms Phone Detected ! Chip ID: 71000301 FLASH CID: 42 PHONE COLOR: RED Loading ... Loader version: 50223 1439 LLECXC1325414_FLASHLOADER R3V OTP CID: 42 IMEI: 35xxxxxxxxxxxxx Settings made ... Bypassing restriction ... Loader version: 40318 1450 LLECXC1325413_CERTLOADER R3J Settings Done ! Certificate sent ... Boot info: HACK3R2K.COM GSM DEVELOPEMENT Flash 1: 0089:880D Flash 2: 0089:8810 Firmware version: U8330_V20a Working. Please wait ... Operation finished ! Time needed - 00:00:40 |
8330 dead after FLASHED with LG-U8330_full_V10_unlocked.bif | jawad8305 | LG | 6 | 06-25-2006 15:55 |
lg 8330 DEAD AFTER ALL 4 TESTPOINTS REMOVE IT FROM PCB | crossings | LG | 1 | 11-07-2005 16:36 |
lg 8120 dead after tying to unlock. please help | oxc61 | FuriouS II | 14 | 10-14-2005 13:16 |
lg 8330 dead after unlock | STOMATELA | VygisToolbox | 10 | 07-06-2005 07:38 |
LG U 8330 dead after flashing to U8130 v101. | arsidi | FuriouS II | 4 | 06-17-2005 14:32 |
