04-03-2018, 20:03 | #1 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Balkan Age: 50
Member: 1473716 Status: Offline Thanks Meter: 1,273 | Mobiwire Atohi unlock problem Constantly Error..... Searching phone; Phone detected (MTK USB Port) Preparing to start meta mode; COM opened ok; Phone must be powered off; Keep pressing the power button if serial used ! (for USB connection keep SPACE or * (STAR) key pressed and insert the usb cable) Connecting; COM opened ok; Phone must be powered off; Keep pressing the power button if serial used ! (for USB connection keep SPACE or * (STAR) key pressed and insert the usb cable) ERROR: ? Time needed - 00:00:43 Does anyone have an older version of the program?.... |
04-03-2018, 20:41 | #2 (permalink) | |
Member: 1473716 Status: Offline Thanks Meter: 1,273 | Quote:
Problem Solved on another PC with win10 Probably drivers are a problem..... Keep 0 and insert usb cable... Searching phone; Phone detected (@oem26.inf,%vcom_bootrom%;MediaTek USB Port) Preparing to start meta mode; COM opened ok; Phone must be powered off; Keep pressing the power button if serial used ! (for USB connection keep SPACE or * (STAR) key pressed and insert the usb cable) Connecting; Meta mode entered; Baseband Chip: MT6276 Sw version: V01_170324_Atohi_MobiWire_NL02_MP Hw Version: SELECTIONB1_1G512_11B_HW Reading phone info; IMEI: 353535-07-048233-4 Reading simlock info; Unlock codes: Locked to: 460-01 code_cat_n: 12345678 enabled: yes tries: 0 code_cat_ns: 56781234 enabled: no tries: 5 code_cat_sp: 11112222 enabled: no tries: 5 code_cat_c: 33334444 enabled: no tries: 5 code_cat_sim: 55556666 enabled: no tries: 5 code_cat_ns_sp: 77778888 enabled: no tries: 5 code_cat_sim_c: 99990000 enabled: no tries: 5 Time needed - 00:00:49 | |
The Following User Says Thank You to gile@gile For This Useful Post: |
