01-21-2015, 16:30 | #1 (permalink) |
Freak Poster Join Date: Jul 2008 Location: BiH
Member: 825846 Status: Offline Sonork: kalaba Thanks Meter: 23 | ot 1013x unlock problem Using library Brom_DLL_v5.1316.1 Searching phone; (for some models keep SPACE or * (STAR) key pressed before inserting the cable) Phone detected (@oem186.inf,%mtk6218%;USB Modem Driver) Preparing to start meta mode; ERROR: Comport open failed ! Time needed - 00:00:34 I to work together various drivers but still the same, I tried it with and without battery and charger is not working ate driver problem I have properly installed the driver com port is ok, the idea or the wrong driver is installed please help |
01-22-2015, 09:12 | #2 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,568 | Quote:
Br | |
The Following User Says Thank You to .:hack3r2k:. For This Useful Post: |
02-05-2015, 14:51 | #5 (permalink) |
Member: 825846 Status: Offline Sonork: kalaba Thanks Meter: 23 | I do not work for me, not to connect to the furious I tried several cables simply not going connection ??? Does anyone have that verified tested this phone? |
02-05-2015, 16:06 | #7 (permalink) |
Member: 825846 Status: Offline Sonork: kalaba Thanks Meter: 23 | Try cable c701 not connect, and manualy connect rx, tx , gnd but not connect ?? Please rx, tx, in board maybe wrong pinout Last edited by kalser; 02-05-2015 at 16:23. |
02-06-2015, 08:40 | #10 (permalink) |
Freak Poster Join Date: Jan 2009
Member: 954179 Status: Offline Thanks Meter: 83 | Let think about a new model hard protected one.So need testpoint before.It's an idea not the solution.Can you give the version of your1013?And what is displayed when put a sim card? Network key or SIM LOCKED? |
02-06-2015, 09:23 | #11 (permalink) |
Member: 825846 Status: Offline Sonork: kalaba Thanks Meter: 23 | I do work on codes percent have no solutions via cable I see no one did this model on cable, so I wonder which solution is not going that cable is not even try? I have every day need 3-4 models 1013 to unlock but thus far they work the codes when the solution in TestPoint a set image |
03-27-2015, 16:54 | #12 (permalink) |
Freak Poster Join Date: Apr 2006 Location: Bosnia and Hercegovina Age: 50
Member: 257050 Status: Offline Thanks Meter: 5 | sing library Brom_DLL_v5.1316.1 Searching phone; (for some models keep SPACE or * (STAR) key pressed before inserting the cable) Phone detected (@oem186.inf,%mtk6218%;USB Modem Driver) Preparing to start meta mode; ERROR: Comport open failed ! need fix this problem for next update. Tnx. .:hack3r2k:. |
The Following User Says Thank You to azo_ja For This Useful Post: |
03-28-2015, 09:47 | #13 (permalink) | |
Nothing to fix. You must use serial cable. You tried over usb Br | |
04-04-2015, 10:01 | #14 (permalink) |
No Life Poster Join Date: Oct 2008 Location: BIH,Bratunac
Member: 888715 Status: Offline Thanks Meter: 109 | i use serial cable,i use usb cable phone not unlock,need fix this problem txn adevance |
The Following User Says Thank You to lipen For This Useful Post: |
04-08-2015, 13:28 | #15 (permalink) |
Insane Poster Join Date: Jan 2006 Location: Sarajevo
Member: 227343 Status: Offline Thanks Meter: 11 | OT-1013x is Baseband Processor: MT6261, HW Rev. B.01, SW Rev. 0.01 Please support this phone. Thanks |
The Following User Says Thank You to bobo07 For This Useful Post: |
