04-24-2014, 17:55 | #1 (permalink) |
No Life Poster Join Date: Mar 2001 Location: ALBANIA(Tirana) Age: 51
Member: 3617 Status: Offline Thanks Meter: 579 | OT-655X dead after flashing ok.?????? i decide to flash the phone after phone flashed ok ....phone does not power on any help |
04-25-2014, 08:52 | #3 (permalink) |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,569 | I checked again using latest version 1.0.0.1386 and everything is ok. I suppose batt went empty while flashing over serial since it takes some time. Charge it externally and will work Br |
04-25-2014, 16:42 | #4 (permalink) |
Member: 3617 Status: Offline Thanks Meter: 579 | Thx for reply batery is full i have trying with 2 bateries In support i download 2 files OT-655x i flashed with 655X-2X=B VDAL1 also 655X-2X=B VDZA1 phone flashed but does not power on when i put the charger i see only a smoll light blu in the front of phone but does not charge or power on |
04-28-2014, 12:42 | #7 (permalink) |
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,569 | I suggest to make a total format, download other flash from support and try writing again. Must also be sure what flash you write since are 2 hw versions 655WX and 655X. Now i see you flashed wrong flash and thats why phone didt start. Must use 655WX-2[X=B]VDAL1.otz not 655X !!!! Br |
04-28-2014, 17:21 | #8 (permalink) |
Member: 3617 Status: Offline Thanks Meter: 579 | i do everything as you said still the same situation after 2 second phone shut down i show you imei under flashing also picture of the back of phone are the same and is wrote Ot-655X |
