05-06-2023, 20:30 | #1 (permalink) |
Junior Member Join Date: Oct 2012
Member: 1823749 Status: Offline Thanks Meter: 0 | problem with 5030a imei repair my imei is all 000000000000000 i do have signal but cannot make any call or data browsing Engine version 1.0.0.5337 Searching phone; For an successful connection do the following: 1. Power on the phone and power it off 2. Keep pressed firmly volume DOWN key 3. Insert the usb cable inside the phone while keeping pressed volume DOWN Phone detected (@oem17.inf,%usbcomm_dl%;SPRD U2S Diag) (Driver version: 4.20.42.134) Preparing to sync; Port opened [COM20]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: (c)2021, FuriouSTeaM Starting FDL2; FDL2 sent; Starting auth; memory_type: IF_TYPE_MMC dev_no: 0 part_type: PART_TYPE_UNKNOWN vendor: Man 000088 Snr 513b292f product: SLD64G revision: 5.5 memory_size: 57.6 GB HW IMEI : 000000-00-000000-0 PHONE INFO: NONE PHONE ID: MDYzZDgzMTYwMDkwNDBhMA== BT ADDR: NONE SW IMEI[0]: 350770-41-071241-2 SW IMEI[1]: 867400-02-031662-0 SW IMEI[2]: 867400-02-031663-8 SW IMEI[3]: 867400-02-031664-6 SIMLOCK FLAG: OFF Reading NV; NV saved to : NV_000000-00-000000-0_350770-41-071241-2_98550000_6_05_2023_14_27_02.spd Gathering security data; Security check result: 0 Connecting to server; Authorisation process started; Furious Multipurpose Credits: 1 Done; Requesting data from server ! Wait please ... Re-programming; Security programmed; Sync NV; Done; IMEI[0] repaired; Remove battery and cable; Log file saved to: LOG_6_05_2023_14_27_23.txt Time needed - 00:02:01 |
05-08-2023, 11:26 | #2 (permalink) |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,568 | https://www.furiousgold.com/en/produ...tipurpose-logs NOTE: FOR OT-5024A, OT-5001A, OT-5030A IMEI REPAIR WORKS WITH ORIGINAL VALUE ONLY !!! |
