02-23-2008, 02:46 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Philippines
Member: 329609 Status: Offline Thanks Meter: 245 | Problem in unlocking k510 cid 50 need help Press Power On shortly ! Phone detected ... Loading ... Loader version: 070129 1112 NGUCXC125872_DB2010_PRODUCTIONIDLOADER_P4D [PHONE DETAILS] Baseband IC ID: 8040 Protocol ver.: 0301 OTP Cert. ID: 50 OTP Lock Stat.: 1 OTP Imei : 35839701451356 PAF: 1 Color : RED Erom Cert. ID : 50 Flash Chip ID : 897E [UNLOCK START] Press Power On shortly ! [UNLOCK END] Error ... ! Operation Time - 00:00:19 need help on this on. Does fg really support unlocking this unit? Why i always get this error when i try to unlock unit. Even if i successfullly remove Rsa then try unlock. Or is there some thing wrong with my procedure. thanks in advance. b.r. |
02-23-2008, 04:41 | #2 (permalink) |
Member: 329609 Status: Offline Thanks Meter: 245 | tried again still same error!!! Press Power On shortly ! Phone detected ... Loading ... Loader version: 070129 1112 NGUCXC125872_DB2010_PRODUCTIONIDLOADER_P4D [PHONE DETAILS] Baseband IC ID: 8040 Protocol ver.: 0301 OTP Cert. ID: 50 OTP Lock Stat.: 1 OTP Imei : 35839701451356 PAF: 1 Color : RED Erom Cert. ID : 50 Flash Chip ID : 897E [PHONE INFO] MODEL: K510i MAPP CXC article: R4EA031 prgCXC1250242_ORANGE_CO MAPP CXC version: R4EA031 Language Pack.: ORANGE_GEN CDA article.: CDA102295/1 CDA version.: R2A Default article.: cxc1250246 Default version.: R4EA031 Operator: 234-33 Locked: YES Operation Time - 00:00:05 Press Power On shortly ! Phone detected ... Loading ... Loader version: 070129 1112 NGUCXC125872_DB2010_PRODUCTIONIDLOADER_P4D [PHONE DETAILS] Baseband IC ID: 8040 Protocol ver.: 0301 OTP Cert. ID: 50 OTP Lock Stat.: 1 OTP Imei : 35839701451356 PAF: 1 Color : RED Erom Cert. ID : 50 Flash Chip ID : 897E [FLASH INIT STARTED] Completed ... Restarting. Press Power On shortly ! Phone detected ... Loading ... Loader version: 060712 1520 HAN_DB2012_FLASHLOADER_R1A002_CXC1250695 [FLASH INIT ENDED] [CS AUTH STARTED] Loading ... Loader version: 060721 0900 GENCXC1327364_COMPACT_SEMC_CS_LOADER_1_R3B002 Connecting to server... Asking server for access ... Authentificated OK ! Account type: End user Account balance: 34 [CS AUTH ENDED] Disconnected. [SECURITY BYPASS START] Uploading data ... Please Wait ! Completed ... Restarting. [SECURITY BYPASS END] Operation Time - 00:00:55 Press Power On shortly ! Phone detected ... Loading ... Loader version: 070129 1112 NGUCXC125872_DB2010_PRODUCTIONIDLOADER_P4D [PHONE DETAILS] Baseband IC ID: 8040 Protocol ver.: 0301 OTP Cert. ID: 50 OTP Lock Stat.: 1 OTP Imei : 35839701451356 PAF: 1 Color : RED Erom Cert. ID : 50 Flash Chip ID : 897E [UNLOCK START] Press Power On shortly ! [UNLOCK END] Error ... ! Operation Time - 00:00:19 |
03-25-2008, 18:34 | #5 (permalink) |
Junior Member Join Date: Jun 2007
Member: 531985 Status: Offline Thanks Meter: 0 | Do you have the Sony Ericsson K750 cable provided with the Furious Box ? If so, don't forget to use the 9volts external power on the red and black cables existing on the K750 cable ! One more thing that may help is to remove battery and K750 cable from phone when it says "Press shortly..." then put battery and plug... Good luck |
k510 cid 50 unlock problem | cel_phon | SETool2 | 13 | 07-18-2009 12:34 |
How` to unlock k510 cid 50 | chitawira | DreamBox | 1 | 05-12-2008 20:24 |
How to unlock k510 cid 50? | kungpaoski | Universalbox | 4 | 02-22-2008 03:18 |
k510 cid 50 error in custumiz | karim deshne | Sony Ericsson Hardware Repair | 1 | 01-06-2008 18:37 |
problem to unlock W810 CID 50 | ..:: i-MAX ::.. | Cruiser Suite | 5 | 10-04-2007 15:33 |
