07-29-2006, 12:06 | #1 (permalink) |
Freak Poster Join Date: Feb 2004
Member: 55463 Status: Offline Thanks Meter: 635 | Siemens AP75 Unlock question i have furious gold, benq m300 cable and i try to unlock this damn phone but it wont work? doesnt matter if i use com1 (serial) or comX (ftdi), box wont communicate with phone, it says press red button and thats it. can someone please show me pic of the Tp (maybe i am using wrong one), and describing in a few words the unlock procedure, com1 or comX, what cable etc... ps. i tried on different pc's. everywhere the same thx in advance br |
07-29-2006, 12:13 | #2 (permalink) |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,568 | I think ur m300 cable is faulty. Wrong TP connections! It should be soldered together with Ground so TP will works. So please check. Br |
07-31-2006, 10:50 | #3 (permalink) |
Member: 55463 Status: Offline Thanks Meter: 635 | thx for the fast reply, still no luck. i tried 2 different cables, so cable should be ok, but also the phone is labled as TCM, so maybe that is also problem. or just................. br |
08-10-2006, 16:49 | #4 (permalink) |
Freak Poster Join Date: Aug 2005 Age: 51
Member: 170494 Status: Offline Thanks Meter: 9 | hi hi, i have the same prob. my cable is brand new and the phone too. i use F. Gold. the computer doenst get conection with the ****ing phoen and i have 10 pieces of this phone to unlock right now. if some1 knows hoe to unlock it with F. g, i wil be very geatfull. thanks |
08-10-2006, 19:30 | #5 (permalink) |
Product Manager Join Date: May 2001 Location: Los Angeles
Member: 4584 Status: Offline Sonork: 100.69564 Thanks Meter: 15,093 | don't know if this can help but here you can find tutorial how to unlock this phone : http://www.furiousbox.com/inside.php...model=BenqM300 BR. Steve. |
08-10-2006, 21:57 | #6 (permalink) | |
Member: 170494 Status: Offline Thanks Meter: 9 | hi Quote:
i have 2 cables the firstone is from my F. box II with a black tp wire and the otherone is from my F. Gold with a red tp wire. i tried with both cables and both boxes but no succes. nothing hapend after pressing red botton. i need ur help. and iam waithing. thanks | |
08-11-2006, 10:09 | #8 (permalink) |
No Life Poster Join Date: Aug 2005 Location: romania-bm Age: 40
Member: 174315 Status: Offline Thanks Meter: 123 | ap75 work fine with fb2 cable.be sure you do correct testpoint and retry. also be sure you use right comport settings.and keep red button pressed. |
08-11-2006, 13:20 | #10 (permalink) |
Member: 174315 Status: Offline Thanks Meter: 123 | here you have correct pinout.remember that red or green wire(depend on what cable you have) must be connected to gnd on cable conector http:///vbb/showthread.php?t=278276 |
01-14-2007, 12:58 | #13 (permalink) |
Freak Poster Join Date: Feb 2005 Location: Paris-Oujda Age: 46
Member: 121473 Status: Offline Thanks Meter: 1 | MODEL: Siemens AP75 UNLOCKING... PRESS RED BUTTON NOW ! WORKING... CALCULATING... DECODING... ENCODING... PHONE WAS NOT LOCKED ! WORK DONE ! Time needed - 00:00:30 100% ok |
01-14-2007, 13:20 | #14 (permalink) |
Member: 121473 Status: Offline Thanks Meter: 1 | MODEL: M300 UNLOCKING... PRESS RED BUTTON NOW ! WORKING... CALCULATING... DECODING... ENCODING... WORK DONE ! Time needed - 00:00:26 any problem ! furious gold |
07-06-2010, 10:31 | #15 (permalink) |
Freak Poster Join Date: Sep 2004 Location: Torredembarra - Spain Age: 48
Member: 84456 Status: Offline Thanks Meter: 6 | I have now the same problem with the same phone but can't see tutorial. maybe moved?? Can anybody post the new link??? Thanks in advance |
siemens AP75-unlock | robert_suban | Infinity-Box | 3 | 06-12-2013 11:09 |
Solution To Unlock Siemens Ap75 With Redbox Here!!!!! | massy | Redbox | 11 | 05-22-2007 21:11 |
siemens ap75...unlock... | Santiago LEE | DreamBox | 8 | 12-17-2006 22:09 |
Can I unlock siemens AP75 with martech | Mounir | SIEM Service Tools | 3 | 06-14-2006 16:26 |
Siemens C61 Unlocking Question | timc940 | S-Gold Based Phones | 0 | 05-30-2005 19:30 |
