11-07-2019, 12:13 | #1 (permalink) |
Freak Poster Join Date: Jun 2004 Location: Portugal Age: 50
Member: 68771 Status: Offline Thanks Meter: 1 | unlock Alcatel OT-2053x problem [SOLVED] |
11-07-2019, 12:25 | #3 (permalink) |
Member: 68771 Status: Offline Thanks Meter: 1 | [QUOTE=.:hack3r2k:.;13887390]You probably use an old version. Must use latest ! Im using latest my friend SPDTooL_v1.0.0.3730.zip Searching phone; For an successful connection do the following: 1. Power on the phone and power it off and leave the battery inside 2. Keep pressed firmly the boot key 3. Insert the usb cable inside the phone while keeping pressed the boot key Phone detected (@oem38.inf,%dvcdsc%;SCI USB2Serial) Preparing to sync; Port opened [COM5]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: Spreadtrum Boot Block version 1.2 Starting FDL2; FDL2 sent; Chip type: 6562:0001 Starting auth; HW IMEI : 000000-00-000000-0 Memory [CS0]: 00EF:0040:0016 - SIZE : 00400000 [00006087389BD342:B8A3] Reading phone info; PHONE INFO: 2053X-2AVDPT1 BT ADDR: E0:A0:0F:33:9E:88 SW IMEI[0]: 359161-09-098236-1 SW IMEI[1]: 352751-01-952326-7 SW IMEI[2]: 358570-01-010389-3 SW IMEI[3]: 910575-60-140046-8 SIMLOCK FLAG: ON FIXED NV BASE: 103B8000 Reading NV; Reading security; NV saved to : NV_000000-00-000000-0_359161-09-098236-1_65620000_7_11_2019_11_24_05.spd IMEI: 359161-09-098236-1 UNLOCK CODE: NONE Re-programming; NV programmed; Done; Phone unlocked; Remove battery and cable; Log file saved to: LOG_7_11_2019_11_24_27.txt Time needed - 00:00:57 SIM Limited again after original NV... Searching phone; For an successful connection do the following: 1. Power on the phone and power it off and leave the battery inside 2. Keep pressed firmly the boot key 3. Insert the usb cable inside the phone while keeping pressed the boot key Phone detected (@oem38.inf,%dvcdsc%;SCI USB2Serial) Preparing to sync; Port opened [COM5]; Mobile type: SPRD3 Connected; Starting; FDL sent; Syncing; Loader version: Spreadtrum Boot Block version 1.2 Starting FDL2; FDL2 sent; Chip type: 6562:0001 Starting auth; HW IMEI : 000000-00-000000-0 Memory [CS0]: 00EF:0040:0016 - SIZE : 00400000 [00006087389BD342:B8A3] Reading phone info; PHONE INFO: 2053X-2AVDPT1 BT ADDR: E0:A0:0F:33:9E:88 SW IMEI[0]: 359161-09-098236-1 SW IMEI[1]: 352751-01-952326-7 SW IMEI[2]: 358570-01-010389-3 SW IMEI[3]: 910575-60-140046-8 SIMLOCK FLAG: OFF FIXED NV BASE: 103B8000 Uncompressing; Done; Re-programming; NV is valid [size: 00006C2C crc: 7830] Simlock programmed; NV programmed; NV protect programmed; Done; Remove battery and cable; Log file saved to: LOG_7_11_2019_11_27_22.txt Time needed - 00:00:47 Asks for code |
11-07-2019, 12:39 | #5 (permalink) |
Member: 68771 Status: Offline Thanks Meter: 1 | |
11-07-2019, 14:08 | #6 (permalink) |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,570 | SPDTooL_v1.0.0.3731.zip added to the support. Try. Should be fine Br |
The Following 2 Users Say Thank You to .:hack3r2k:. For This Useful Post: |
