05-16-2014, 01:47 | #1 (permalink) |
No Life Poster Join Date: Mar 2010
Member: 1271541 Status: Offline Thanks Meter: 35 | UNLOCK one touch 918 failed Phone detected (@oem99.inf,%mtk_preloader%;PreLoader USB VCOM Port) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) ERROR: Debug port not found ! BE sure the drivers from support were installed; Time needed - 00:03:18 |
05-16-2014, 02:06 | #2 (permalink) |
Member: 1271541 Status: Offline Thanks Meter: 35 | Searching phone; Phone detected (@oem99.inf,%mtk_preloader%;PreLoader USB VCOM Port) Preparing to start meta mode; Searching for debug port; (be sure drivers from support were installed) Debug Port found on FTEAM USB Serial Port (COM23); Preparing to connect meta mode; Meta mode entered; Baseband Chip: MT6573, E00 Sw version: MAUI.11AMD.W11.37.SP.V27.P18 Hw Version: JRD73_GIN_MODEM_GEMINI2_HW Reading phone info; IMEI: 860767-00-180236-5 Reading simlock info; Locked to: 208-01 code_cat_n: 30513859 enabled: yes tries: 1 code_cat_ns: 33496781 enabled: no tries: 10 code_cat_sp: 38343432 enabled: no tries: 10 code_cat_c: 21922636 enabled: no tries: 10 code_cat_sim: 12243172 enabled: no tries: 10 code_cat_ns_sp: 53297761 enabled: no tries: 5 code_cat_sim_c: 86817778 enabled: no tries: 5 Time needed - 00:01:13 thanks FURIOUS |
The Following User Says Thank You to gsmaroc For This Useful Post: |
