06-10-2009, 08:39 | #3 (permalink) |
Product Supporter Join Date: Sep 2004 Age: 39
Member: 81703 Status: Offline Thanks Meter: 1,332 | Use an unbranded software http://rapidshare.com/files/16329549...le_Connect.zip Or send on modem port using a soft like QMAT (www.revskills.de) following at command code: AT^CARDLOCK="UNLOCK_CODE" where UNLOCK_CODE is the code shown by our sw. BR Luskao |
06-20-2009, 15:06 | #4 (permalink) | |
No Life Poster Join Date: Apr 2006
Member: 268887 Status: Offline Thanks Meter: 91 | Quote:
06-20-2009, 18:15 | #6 (permalink) | |
0A 00 0A B0 .... Successfully Send Command Even though in Vodafone software it says Insert Correct Sim Card. When I try Huwaii software it works fine. Can I use Voda software to do the job or I must use Huwaii software. Or is there any way to debrand it. | |
06-20-2009, 19:01 | #7 (permalink) |
Member: 81703 Status: Offline Thanks Meter: 1,332 | You must use HUAWEI. Vodafone Mobile Connect Lite closed the opportunity to use other sim cards BR Luskao |
The Following User Says Thank You to luskao For This Useful Post: |
11-09-2009, 15:27 | #8 (permalink) |
No Life Poster Join Date: May 2006 Location: Welcome Back JAf Team
Member: 278954 Status: Offline Thanks Meter: 26 | how can i remove the vodafone dongle auto install function? everytime i plug in the vodafone dongle. it ask me to install vodafone software. But i always use HUAWEI orginal one. anyway to delet the install exe in the dongle? |
11-10-2009, 00:08 | #10 (permalink) |
No Life Poster Join Date: Oct 2009 Location: FuriouSGold Age: 18
Member: 1144248 Status: Offline Sonork: 100.1574721 Thanks Meter: 3,936 | I think also when you connect if keep pressed shift button it won't install it. Other way it's install a dashboard from huawei webpage with unbranded software Regards Furious Support |
how to unlock s8300? [SOLVED] | 79mobile | SPT BOX | 5 | 04-13-2010 10:05 |
HELP how to unlock iphone 3.1 | laksh007 | iPhone 2 / iPhone 3G / iPhone 3GS | 7 | 03-31-2010 03:22 |
cg225 how to unlock via FG i'm new user. pls help [SOLVED] | mymiela0419 | FuriousGold | 4 | 11-18-2009 07:49 |
LG GB102 how to unlock it? [Solved] | kariakala | Z3X-Team Products | 5 | 10-16-2009 06:30 |
