02-02-2018, 00:16 | #1 (permalink) |
Freak Poster Join Date: Mar 2017 Location: Haiti Age: 41
Member: 2697312 Status: Offline Thanks Meter: 75 | ZTE 820 Flash error [SOLVED] Please how to fix this error "ERROR: S_SECURITY_SECRO_HASH_INCORRECT" when flashing ZTE Z820 This is the log: Using library Brom_DLL_v7.1733.4 Searching phone in normal mode; [connect the phone powered off with volume up pressed to the usb cable] Phone detected (MediaTek USB Port (COM178)) Preparing to start flash mode; Preparing to open COM178 Connecting; Downloading DA; Initializing; Rid: f88e83d02d8e668e4bd2d17088f8d1a7 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem119.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM179; DEVICE INFO: BB CHIP: MT6735M [CA00, 00, 335, 05] HW_STORAGE_EMMC: 0x484A0190 0x65314738 0xA1C30705 0xF9924538 [SIZE=0x1D2C00000] IMEI1 [OTP 00FF]: 868485-02-182270-9 IMEI2 [OTP 00FF]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0xD6000000 SIZE: 0xF8480000 Loading the file ... Cfg done ... Formatting file system now... Done; Formatting NVDATA partition now... Done; Formatting METADATA partition now... Done; Downloading bootloader... Done; Downloading images... Done; ERROR: S_SECURITY_SECRO_HASH_INCORRECT Time needed - 00:07:39 Log file saved to: LOG_1_02_2018_13_27_39.txt |
02-11-2018, 13:53 | #3 (permalink) | |
Banned Join Date: Nov 2010 Location: :::LONDON:::
Member: 1442994 Status: Offline Thanks Meter: 899 | it stuck here ..please help me to flash..i unlocked it then keep restaRTING Quote:
03-22-2018, 12:27 | #8 (permalink) |
No Life Poster Join Date: Jun 2004 Location: Cameroon- Bamenda
Member: 69269 Status: Offline Thanks Meter: 175 | Zte Z820 flash failed Using library Brom_DLL_v7.1733.4 Searching phone in normal mode; [connect the phone powered off with volume up pressed to the usb cable] Phone detected (MTK USB Port (COM5)) Preparing to start flash mode; Preparing to open COM5 Connecting; Downloading DA; Initializing; Rid: 1a5de2e949555806f5cde74984dbe3bf Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (DA USB VCOM Port) TRYING TO OPEN COM22; DEVICE INFO: BB CHIP: MT6735M [CA00, 00, 335, 05] HW_STORAGE_EMMC: 0x51000115 0x4D533237 0xA89E0042 0x79B2926A [SIZE=0x1D2880000] IMEI1 [OTP 00FF]: 867117-02-279118-4 IMEI2 [OTP 00FF]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0xD6000000 SIZE: 0xF8480000 Loading the file ... Cfg done ... ERROR: S_FT_FORMAT_FAIL ERROR: S_SECURITY_SF_SECURE_VER_CHECK_FAIL Time needed - 00:15:07 Log file saved to: LOG_22_03_2018_12_09_47.txt |
03-23-2018, 07:32 | #9 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,569 | Quote:
Br | |
03-24-2018, 12:37 | #10 (permalink) |
Member: 69269 Status: Offline Thanks Meter: 175 | ZTE Z820 logo now OK First flash dump Using library Brom_DLL_v7.1733.4 Searching phone in normal mode; [connect the phone powered off with volume up pressed to the usb cable] Phone detected (MediaTek USB Port (COM16)) Preparing to start flash mode; Preparing to open COM16 Connecting; Downloading DA; Initializing; Rid: 1a5de2e949555806f5cde74984dbe3bf Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem69.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM30; DEVICE INFO: BB CHIP: MT6735M [CA00, 00, 335, 05] HW_STORAGE_EMMC: 0x51000115 0x4D533237 0xA89E0042 0x79B2926A [SIZE=0x1D2880000] IMEI1 [OTP 00FF]: 867117-02-279118-4 IMEI2 [OTP 00FF]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0xD6000000 SIZE: 0xF8480000 Preparing to write FULL_DUMP_PART0; Writing FULL_DUMP_PART0; Preparing to write FULL_DUMP_PART1; Writing FULL_DUMP_PART1; Preparing to write FULL_DUMP_PART2; Writing FULL_DUMP_PART2; Preparing to write FULL_DUMP_PART3; Writing FULL_DUMP_PART3; Preparing to write FULL_DUMP_PART4; Writing FULL_DUMP_PART4; Preparing to write FULL_DUMP_PART6; Writing FULL_DUMP_PART6; Preparing to write FULL_DUMP_PART8; Writing FULL_DUMP_PART8; Preparing to write FULL_DUMP_PART9; Writing FULL_DUMP_PART9; Success; Time needed - 00:23:53 Log file saved to: LOG_24_03_2018_10_46_17.txt 2nd, flash firmware Using library Brom_DLL_v7.1733.4 Searching phone in normal mode; [connect the phone powered off with volume up pressed to the usb cable] Phone detected (MediaTek USB Port (COM10)) Preparing to start flash mode; Preparing to open COM10 Connecting; Downloading DA; Initializing; Rid: 1a5de2e949555806f5cde74984dbe3bf Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem69.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM29; DEVICE INFO: BB CHIP: MT6735M [CA00, 00, 335, 05] HW_STORAGE_EMMC: 0x51000115 0x4D533237 0xA89E0042 0x79B2926A [SIZE=0x1D2880000] IMEI1 [OTP 00FF]: 867117-02-279118-4 IMEI2 [OTP 00FF]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0xD6000000 SIZE: 0xF8480000 Loading the file ... Cfg done ... Formatting file system now... Done; Formatting NVDATA partition now... Done; Formatting METADATA partition now... Done; Downloading bootloader... Done; Downloading images... Done; Success; Time needed - 00:08:22 Log file saved to: LOG_24_03_2018_12_29_42.txt Now phone is OK |
04-06-2018, 06:20 | #11 (permalink) | |
Freak Poster Join Date: Nov 2016 Location: Republica Dominicana
Member: 2653449 Status: Offline Thanks Meter: 58 | hi bro need help Quote:
just write part 0, I can see in your register writing several parts, I downloaded the file Using library Brom_DLL_v7.1733.4 Searching phone in normal mode; [connect the phone powered off with volume up pressed to the usb cable] Phone detected (MediaTek USB Port (COM30)) Preparing to start flash mode; Preparing to open COM30 Connecting; Downloading DA; Initializing; Rid: e34b8d34fa85e7b2ff0954681b2858c3 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem64.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM16; DEVICE INFO: BB CHIP: MT6735M [CA00, 00, 335, 05] HW_STORAGE_EMMC: 0x484A0190 0x65314738 0x24ED0705 0xA7526692 [SIZE=0x1D2C00000] IMEI1 [OTP 00FF]: 867117-02-054302-5 IMEI2 [OTP 00FF]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0xD6000000 SIZE: 0xF8480000 Preparing to write FULL_DUMP_PART0; Writing FULL_DUMP_PART0; Time needed - 00:00:40 Log file saved to: LOG_6_04_2018_02_18_03.txt | |
05-03-2018, 14:09 | #13 (permalink) |
Member: 2653449 Status: Offline Thanks Meter: 58 | hi bro need help If I have tried to place but do not write all the partitions, just write the partition 0 Using library Brom_DLL_v7.1733.4 Searching phone in normal mode; [connect the phone powered off with volume up pressed to the usb cable] Phone detected (MediaTek USB Port (COM66)) Preparing to start flash mode; Preparing to open COM66 Connecting; Downloading DA; Initializing; Rid: d2601ad958ad04455e474b490e7b2403 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem71.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM21; DEVICE INFO: BB CHIP: MT6735M [CA00, 00, 335, 05] HW_STORAGE_EMMC: 0x484A0190 0x65314738 0x847A0705 0x45A22CDC [SIZE=0x1D2C00000] IMEI1 [OTP 00FF]: 867117-02-225709-5 IMEI2 [OTP 00FF]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0xD6000000 SIZE: 0xF8480000 Preparing to write userdata Preparing to write FULL_DUMP_PART0; Writing FULL_DUMP_PART0; An error occured while restoring; Time needed - 00:01:33 |
05-03-2018, 15:06 | #14 (permalink) | |
Member: 2653449 Status: Offline Thanks Meter: 58 | help Quote:
Using library Brom_DLL_v7.1733.4 Searching phone in normal mode; [connect the phone powered off with volume up pressed to the usb cable] Phone detected (MediaTek USB Port (COM66)) Preparing to start flash mode; Preparing to open COM66 Connecting; Downloading DA; Initializing; Rid: d2601ad958ad04455e474b490e7b2403 Requesting baudrate change; Done; USB SPEED: USB_FULL_SPEED Switching to DA_HIGHSPEED_VCOM; Drivers location \usb_driver\Driver_Auto_Installer\SmartPhoneDriver \x86; If the detection fails, install manually the port from the device manager using usbvcom.inf; DA_HIGHSPEED_VCOM (@oem71.inf,%vcom_da%;MediaTek DA USB VCOM (Android)) TRYING TO OPEN COM21; DEVICE INFO: BB CHIP: MT6735M [CA00, 00, 335, 05] HW_STORAGE_EMMC: 0x484A0190 0x65314738 0x847A0705 0x45A22CDC [SIZE=0x1D2C00000] IMEI1 [OTP 00FF]: 867117-02-225709-5 IMEI2 [OTP 00FF]: 000000-00-000000-0 PROVIDER: N/A USRDATA INFO: 0xD6000000 SIZE: 0xF8480000 Preparing to write FULL_DUMP_PART0; Writing FULL_DUMP_PART0; Time needed - 00:00:54 Log file saved to: LOG_3_05_2018_07_04_57.txt | |
05-04-2018, 10:38 | #15 (permalink) | |
Br | |
