12-20-2017, 11:24 | #1 (permalink) |
Major Poster Join Date: Jun 2015 Location: Mexico Age: 41
Member: 2404731 Status: Offline Thanks Meter: 109 | ZTE Z791 Reset frp problem Have the same problem with resting frp like here: http://forum.gsmhosting.com/vbb/f272...#post12815944: Code: Searching phone ... MODEL : QCOM SERIES 53 COMPILED DATE : Jun 7 2017 03:31:00 RELEASE DATE : Apr 26 2017 06:00:00 FIRMWARE INFO : MPSS.JO.2.0.c1-00179-8937_GENNS_PACK-1.95826.1.96615.1 IMEI : *********** BLUETOOTH ADDR : 00 00 00 00 00 00 DONE; WORKING; ERROR: SIMLOCK READ ! Error ... ! Log file saved to: LOG_20_12_2017_12_320_33.txt Time needed - 00:00:06 |
12-20-2017, 15:20 | #4 (permalink) |
Insane Poster Join Date: Jan 2010
Member: 1198084 Status: Offline Thanks Meter: 42 | ZTE Z971 successfuly frp and unlock done Smile ZTE Z971 successfuly frp and unlock done Software engine version: 1.0.0.10622 Searching phone ... MODEL : QCOM SERIES 53 COMPILED DATE : Jun 7 2017 03:31:00 RELEASE DATE : Apr 26 2017 06:00:00 FIRMWARE INFO : MPSS.JO.2.0.c1-00179-8937_GENNS_PACK-1.95826.1.96615.1 IMEI : 86372703038907-0 BLUETOOTH ADDR : 00 00 00 00 00 00 FIRMWARE: P817A22V1.0.0B16 close_event_report: OK; close_log_report: OK; close_message_report: OK; closing_com_port: OK; Starting the backup process; connect_server: OK; backup in progress: OK; Backup saved to: E:\FURIOUS GOLD BOX\PACK 5\QCOM_SMART_TOOL_v1.0.0.10622_Z_Edition\863727030 38907_20_12_2017_05_59_52.bkp switching_download_mode: OK; closing_com_port: OK; Preparing to open COM637 Connecting; Loading; Init; Port opened; Hello Received; BOOT Loaded; Getting config; Getting mem info; Found an eMMC memory 22D5 start_frp_reset: OK; frp_reset: OK; Log file saved to: LOG_20_12_2017_06_02_22.txt Time needed - 00:02:34 brother u must change usb port then will 100% work and check driver i had same problum i change usb port then work 100% |
01-17-2018, 20:54 | #5 (permalink) |
Major Poster Join Date: Jul 2017 Location: U.S / PALESTINE
Member: 2742088 Status: Offline Thanks Meter: 8 | Using library Brom_DLL_v7.1733.4 Searching phone in normal mode; [connect the phone powered off with volume down pressed to the usb cable] ERROR: Device not found ! ERROR: BOOT_PHONE; what im doing wrong im new to this box |
02-05-2018, 20:06 | #7 (permalink) | |
No Life Poster Join Date: Feb 2015 Location: Jamaican
Member: 2339843 Status: Offline Thanks Meter: 1,450 | Same problem Quote: | |
