Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > TOTAL MultiServer
Old 07-20-2005, 06:20   #1 (permalink)
Member: 158871
k750i to w800i using cruiser usb
Hi
im trying to flash my k750i with the usb cruiser cable (from 4-in-1 set),
but when pressin "on" on the phone, the phone really turns on, instead of just giving the signal.
Help?
Old 07-20-2005, 08:09   #2 (permalink)
gwaai's Avatar
Member: 49581
Thanks Meter: 73
try remove battery, remove cable ..
when the program is asking to turn on the phone
put battery into the phone
then connect the cable to phone
Old 07-20-2005, 08:44   #3 (permalink)
Member: 93807
same problem. it also turns on. first i turn it off, put out the sim-card, then battery in again, cable and it starts.... UC-10 cruiser cable...
as soon as I plug in the cable it starts loading the akku.
i also connected a 3V battery to the cable as described.
will it work someday with original cable?
rian79
Old 07-20-2005, 15:02   #4 (permalink)
gwaai's Avatar
Member: 49581
Thanks Meter: 73
it won't work with original cable
your 4-in-1 cable is no good, you have to use another one ...
I had this problem, too .... I had one that was working fine, and one day, it also turned my k750 on whenever I run cruiser ... and aftr changing to another cable, Cruiser runs smoothly again .. Change another cable ~ or find someone to re-solder your cable ~
Old 07-20-2005, 18:54   #5 (permalink)
Member: 158871
what other cable is there to use? this one is sold on tms reseller sites
Old 07-20-2005, 23:50   #6 (permalink)
muppet's Avatar
Member: 42570
Thanks Meter: 11
Zealow: this will help you. It's a common problem, many of the 4-in-1 cables are faulty.
The diagrams are available also in the Cruiser support forum. Once you've fixed your cable, you'll be able to use it!
Old 07-21-2005, 05:41   #7 (permalink)
Member: 158871
Hi again
Could you post me url to the diagrams also? sorry ..
im going to give it to the dude who sold me the cable and request a new one..since i don't know anything about soldering
Old 07-21-2005, 10:35   #8 (permalink)
dannyogolo's Avatar
Member: 18200
Sonork: 100.1608286
Thanks Meter: 82
I think Cruiser 4-in-1 is different from TMS 4-in-1.
My reseller actually sells both, so they couldn't be same
But Cruiser works with SeTools
Old 07-21-2005, 10:42   #9 (permalink)
Member: 158871
cable set
I've got this set :
http://www.totalmultiserver.com/cable.htm
if that is not the right set.. then i don't know.. maybe though.. there's an error with my cable.. and that it need to be soldered?
Old 07-21-2005, 14:28   #10 (permalink)
Member: 93807
i got the same cable as you zealow, and it doesn't work. don't know why. which battery are you using? why do i have to use a batter? will it ever work with original cable?
well i am on holidays 2 weeks, and hope theres a solution when i come back ;-)
Old 07-21-2005, 14:52   #11 (permalink)
Member: 158871
hmmm
well.. i don't think the original cable will work, but this cable should somehow work. You have to use 2 AA batteries 1,5 Volt in a batteryholder and connect the cables to it..
but i still don't know how.. im looking into it..
so much trouble, for just a little fun
Old 07-25-2005, 21:29   #12 (permalink)
Member: 158871
finally .. wohoo.. but what to do.. i got a w800i, and there's no software for it.. so i cannot make it work with my pc?
Old 07-25-2005, 21:53   #13 (permalink)
Member: 14392
Thanks Meter: 9
use 9v batt all will be ok :-)
Old 07-25-2005, 22:57   #14 (permalink)
Member: 158871
yeah.. i found out today.. thanks to matt at phonefunshop.co.uk big props..
but i thought about.. like pc suite.. i cannot transfer things to it
Old 07-25-2005, 23:37   #15 (permalink)
Member: 14392
Thanks Meter: 9
No its service cable I think the DCU 60 is the data cable for that.
Flashing a k750i to w800i which software to use ? 5assedmonkey Sony Ericsson 0 05-12-2008 21:58
convert k750i to w800i by cruiser fone Cruiser Suite 3 08-07-2006 20:42
k750i to w800i to k750i how? CZY277 Cruiser Suite 8 05-10-2006 11:22
K750i to W800i + IMEI Change...with USB Smart Mobile-madman SonyEricsson (USB-Smart) 0 02-03-2006 06:39
how to upgrade k750i to W800i?? tonytan Sony Ericsson 19 12-19-2005 03:51
Page generated in 0.20665 seconds with 10 queries
