07-20-2005, 06:20 | #1 (permalink) |
Major Poster Join Date: Jul 2005 Location: Norway Age: 40
Member: 158871 Status: Offline Thanks Meter: 0 | k750i to w800i using cruiser usb im trying to flash my k750i with the usb cruiser cable (from 4-in-1 set), but when pressin "on" on the phone, the phone really turns on, instead of just giving the signal. Help? |
07-20-2005, 08:44 | #3 (permalink) |
Junior Member Join Date: Nov 2004 Age: 44
Member: 93807 Status: Offline Thanks Meter: 0 | same problem. it also turns on. first i turn it off, put out the sim-card, then battery in again, cable and it starts.... UC-10 cruiser cable... as soon as I plug in the cable it starts loading the akku. i also connected a 3V battery to the cable as described. will it work someday with original cable? rian79 Last edited by rian79; 07-20-2005 at 09:13. |
07-20-2005, 15:02 | #4 (permalink) |
No Life Poster Join Date: Jan 2004 Age: 45
Member: 49581 Status: Offline Thanks Meter: 73 | it won't work with original cable your 4-in-1 cable is no good, you have to use another one ... I had this problem, too .... I had one that was working fine, and one day, it also turned my k750 on whenever I run cruiser ... and aftr changing to another cable, Cruiser runs smoothly again .. Change another cable ~ or find someone to re-solder your cable ~ |
07-20-2005, 23:50 | #6 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Auckland, New Zealand
Member: 42570 Status: Offline Thanks Meter: 11 | Zealow: this will help you. It's a common problem, many of the 4-in-1 cables are faulty. The diagrams are available also in the Cruiser support forum. Once you've fixed your cable, you'll be able to use it! |
07-21-2005, 05:41 | #7 (permalink) |
Member: 158871 Status: Offline Thanks Meter: 0 | Hi again Could you post me url to the diagrams also? sorry .. im going to give it to the dude who sold me the cable and request a new one..since i don't know anything about soldering |
07-21-2005, 10:35 | #8 (permalink) |
No Life Poster Join Date: Nov 2002 Location: Nigeria
Member: 18200 Status: Offline Sonork: 100.1608286 Thanks Meter: 82 | I think Cruiser 4-in-1 is different from TMS 4-in-1. My reseller actually sells both, so they couldn't be same But Cruiser works with SeTools |
07-21-2005, 10:42 | #9 (permalink) |
Member: 158871 Status: Offline Thanks Meter: 0 | cable set I've got this set : http://www.totalmultiserver.com/cable.htm if that is not the right set.. then i don't know.. maybe though.. there's an error with my cable.. and that it need to be soldered? |
07-21-2005, 14:28 | #10 (permalink) |
Member: 93807 Status: Offline Thanks Meter: 0 | i got the same cable as you zealow, and it doesn't work. don't know why. which battery are you using? why do i have to use a batter? will it ever work with original cable? well i am on holidays 2 weeks, and hope theres a solution when i come back ;-) |
07-21-2005, 14:52 | #11 (permalink) |
Member: 158871 Status: Offline Thanks Meter: 0 | hmmm well.. i don't think the original cable will work, but this cable should somehow work. You have to use 2 AA batteries 1,5 Volt in a batteryholder and connect the cables to it.. but i still don't know how.. im looking into it.. so much trouble, for just a little fun |
Flashing a k750i to w800i which software to use ? | 5assedmonkey | Sony Ericsson | 0 | 05-12-2008 21:58 |
convert k750i to w800i by cruiser | fone | Cruiser Suite | 3 | 08-07-2006 20:42 |
k750i to w800i to k750i how? | CZY277 | Cruiser Suite | 8 | 05-10-2006 11:22 |
K750i to W800i + IMEI Change...with USB Smart | Mobile-madman | SonyEricsson (USB-Smart) | 0 | 02-03-2006 06:39 |
how to upgrade k750i to W800i?? | tonytan | Sony Ericsson | 19 | 12-19-2005 03:51 |
