Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > TOTAL MultiServer
Old 10-20-2005, 14:46   #1 (permalink)
Member: 10695
Thanks Meter: 4
TMS & Failed Unlock K700i CREDIT
Hi all.
Hoping someone from TMS reads this.
I just tried unlocking my K700i.
All was going well, CREDIT was taken just before end.
Then got error.
TMS generated 2 files which i have emailed to the gmail account.
How do i get my credit back?
Thanks
Old 10-20-2005, 15:44   #2 (permalink)
Member: 151663
I would recommend contacting your particular reseller for initial support--they are responsible for providing you with credits and refills.
What is the current condition of your handset? Boots up, but remains locked to current wireless provider?
Sometimes there can be a timing problem with the USB port and is best to use the slowest port speed when unlocking. Another thing to check is to see if the service cable is in good condition as I have run into a some rare issues where the cable works intermittently giving a false sense that the cable was not the problem--check the contacts on both the cable and handset to make sure there are no bent pins and/or oxidation on the contacts. And of course, a 100% fully charged battery pack to avoid other issues.
Last question. Have you unlocked the K700i successfully with TMS before? If so, which version did you use (if you remember). Hopefully, we can try to resolve your problems shortly.
Old 10-20-2005, 22:10   #3 (permalink)
Member: 10695
Thanks Meter: 4
Hi.
Thanks for the reply.
The seller is TM itself.
Everything here is NEW using TM multicable purchased from them and a new phone and full battery etc.
I have sorted the phone out but not via TMS. Used Davinci and it worked 100% first time.
Tried to contact TM only by their forum as on h**p:/www.totalmultiserver.com
Thanks.
Old 10-21-2005, 03:35   #4 (permalink)
Member: 27266
Good luck. I think this is a TMS support site.
S60 Unlock Failed Please Return Credits Braycel Universalbox 7 12-16-2008 00:26
Nokia N78 unlock failed but 85 credits comsumed !!!! DanV Universalbox 2 11-07-2008 10:28
w910 failed to unlock but credits used chowdary Seking Server 1 04-28-2008 23:11
Flash, unlock & unbrand a K700i BL! Sony Ericsson 0 08-12-2006 13:05
Fail to unlock k700i (Orange branded) Ulman TOTAL MultiServer 0 05-18-2006 10:40
Page generated in 0.16730 seconds with 9 queries
